Question about Microwave Ovens
Hi, I hope you can help me. I can't get a plastic part removed from under the sink so I can pull up my kitchen faucet. The leak is coming from the top and there is a plastic thing that won't unscrew off. It just turns and turns and turns. Did this make sense? I don't know my model number. Thanks in advance, Julia
    President:
  • 1,070 Answers
Welcome to FixYa Dear User Check for any Hidden Screws to be Unscrewed.Sometimes it may be locked clips.So gently unlock it[you have to properly examine that portion]. Also check this Link. Thanks for Connecting FixYa
Posted on Aug 30, 2010
The small round metal mesh discs inside the kitchen tap have fallen out & will not stay in when re-inserted. Now the water squirts out at weird angles drenching the kitchen work surfaces. Do I need a...
Hi Jean,
These mesh discs and the part they go into - along with a few other small parts - make up what is called "an aerator".
Most aerators simply screw on threads at the end of your faucet. You can remove it by twisting it. You may need a wrench to loosen it first. Wrap the aerator in thick cloth / towel so that the wrench does not dent or scrape the finish on the aerator body.
Some aerators thread up and inside the faucet - rather than at the end - and need a special wrench to remove
Once removed, you should reassemble the parts and reinstall on the faucet. You may find replacement aerators in Home Depot, Lowe's, etc. if you're missing parts, etc. If changing it out, be sure to bring the old one with you to match.
I hope this helps & good luck!
Sep 22, 2011 | Microwave Ovens
I'm trying to change the kitchen faucet and the shut off valves under the sink will not turn, I've tried to spray them with WD40 but they still won't turn. I live in a Condo so I cannot shut...
If you can't work the shutoffs on the water lines under the sink, your only choice is to contact your condo maintenance people. They need to have some way to shut the water off to your unit when they make repairs. They can tell you if there are some more valves in another area that you can access, or they may have a maintenance closet somewhere and can turn the water off for you so you can make the repair.
Sometimes you can turn a sticky valve by using a large set of channel-lock pliers or similar type on the knob so you can get leverage. They look like this if you're not familiar with the type:
If it's been a while since the valves have been used, they often don't want to move without help. Once free, they may work fine, but sometimes it's a good idea to replace the shutoff valves as part of the new faucet installation. They're not expensive and you'll know they will work if you need to shut them off in the future. Get "ball-valve stops" which make a positive shutoff. Stops that use a rubber washer can sometimes let water trickle through (or more than trickle!) when shut off. Depending on the kind of valves currently installed and the type of pipes supplying your water, you might want the condo maintenance people to do the replacement. But if 1/2-inch copper pipe is what you have and there's a couple of inches between where the pipe comes through the cabinet back or bottom and the current valves, you can just cut them off with a tubing cutter. Then you can replace them with valves that just slide over the pipe and are fastened by tightening down a compression fitting (tightening a nut, in other words).
You should also plan to use new supply lines from the shutoffs to the faucet. Again, they're cheap and the old ones can sometimes leak when you try reconnecting them. Corrosion and mineral build-up from hard water can lead to poor sealing. The current ones may also be clogged with minerals, and new ones will give your new faucet full flow.
Once you've got that problem of turning off the water supply solved, it's usually not too difficult to change the faucet. Make sure you have a basin wrench on hand; on many faucets it's impossible to reach the supply connections with any other kind. The box from the new faucet may tell you if can get away without one.
Good luck with the project, and thanks for using Fixya!
May 28, 2011 | Microwave Ovens
Moen 7600 kitchen faucet leaking from around handle
You will need to replace the cartridge....
here is tutorial on how to do that...
http://www.ehow.com/how_7241891_do-repair-moen-7600_.html
If you find that the cartridge will not come out you may have to purchase a Moen cartridge removal tool... you can get them at Lowe's or many othere plumbing supply houses....
http://www.bing.com/search?q=moen+cartridge+puller&form=HPDTDF&pc=HPDTDF&src=IE-SearchBox
heatman101
May 14, 2011 | Microwave Ovens
I have a moen 7637 single handle kitchen faucet that leaks around the stem. How do I take the lever off.
1) Use a small sharp-pointed knife and pop out the little plastic Moen logo at the bottom of the front side of the handle (and don't lose it!)
2) Lift the lever up a bit (the water may turn on) until you can see a small screw with an allen wrench socket.
3) Unscrew the allen-head screw; the handle will lift straight up.
Look down into the faucet; there's a philllips head screw. The leaking may simply be caused by this screw being loose.
May 01, 2011 | Microwave Ovens
My Grohe Ashford faucet is loose from kitchen sink. For the price - the things seems cheap to me - under the sink some traingular piece of plastic holds it in - but no apparent screw to tighten? What am I...
Sorry, I got your solution and was about to post and at the same moment supply went off. I don't use a ups. sorry for my fault. I will not let your money flush out, Indeed I will fix your sink. I'm barely on my bike battery because no supply is here kindly give me another few hours because we are facing a torando out here. I will make sure that you will get your output more than your investment.
Apr 02, 2011 | Microwave Ovens
I purchased the Danco 80701 "Repair Kit for Delta, Aquasource, and Glacier Bay Faucets with #70 Ball" so that I can repair a leak in my Delta kitchen faucet. The instructions on the package are...
Sounds like the old style center-control delta type faucet, rubber washers describe older type but still good. The rubber seats have holes in middle, supply water to the cylinder which diverts water to the spout, and has a seal over top of ball allowing stem for handle.
Think they are talking about flex-hose type faucet accessory getting clogged, Maybe: lift the flex-hose faucet housing off the center-control faucet body? Water to it runs directly from center-control faucet and if broken seat gets in narrow line could inhibit spray.
Kitchen faucet spout too has an O-ring under where it connects to the faucet body. Unscrew large nut where meets the faucet body unit (slip-joint pliers), once free of threads, spout should pull straight up, easy or slight tug. I use bent paper clip to remove old one trying to save it in one piece so as to get exact size (that's important) to replace, push on one side then other.
Jan 13, 2011 | Microwave Ovens
I have a Franke faucet in my kitchen. (It has 3 levers - Hot, Pure and Cold). The faucet developed a slow leak. I tried to tighten the screws on all 3 levers and broke 1, so I have to replace it. To...
The cause of leaking is the ceramic gasket. Yes you can replaced it. Find your local hardware store then buy a repair kit for that faucet. If you can bring the sample bring it.
Please rate my help.
Thanks for using fixya.
Jan 10, 2011 | Microwave Ovens
I have a Moen 98043 kitchen sink faucet that is leaking water from the top, any ideas how to fix
Hi Adonish,
If you give Moen a call at 1-800-BUY-MOEN someone will be able to assist you and figure out what the problem is.
-Olivia
Jan 03, 2011 | Microwave Ovens
I have a Kohler Fairfax K-12177. The faucet is leaking, major leak, out of the back of the body of the faucet. It appears that its leaking from a manufactured hole.
I have a Kohler kitchen faucet with the same problem. I called their customer service (1-800-456-4537) and they are sending a new valve and vacuum breaker free of charge.
Sep 02, 2010 | Microwave Ovens
Microwave Ovens Logo
11 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
