Question about Samsung Dryers
What does error message three (e3) mean on the front loading dryer. We thought it was overloading. But we took some out and that didnt fix the problem.
  • 1314 Answers
SOURCE: Error e3?
i need your serial num its important 17
Posted on Jan 04, 2008
fitnessbalan
  • 59 Answers
SOURCE: E3 Error
here are the codes i found
E-1 Electrodes were not firmly grasped. Grasp the electrodes correctly.
E-3 Hands are dry. Slightly moisten hands with
a wet towel.
E-4 Body Fat Percentage and BMI values are outside themeasurable range. verify your personal data is
correct.
E-5 and E-6 Irregular Operation Turn the unit off, then on. Take another measurement. If the error occurs again contact Customer Service at 800-634-4350
have a great weekend!
Posted on Mar 13, 2009
  • 34 Answers
SOURCE: We are getting error code E3. What does this mean
Looks like you have either a stuck drum (does not spin) or an electrical fault that make the washer think the drum is not moving.
From a 2006 Technical Bulletin:
E3: Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Specifically, it could be:
1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause.
2. Hall Sensor (integral part of motor) fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Unless you are really overloading your machine you likely have an electrical fault, or a failure in the drive train--especially if the problem is intermittent. Probably time to call in a technician.
Posted on Aug 13, 2009
blueextc3221
  • 15935 Answers
SOURCE: WHAT DOES F01 ERROR CODE MEAN AND HOW DO YOU FIX
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 21, 2010
  • 239 Answers
SOURCE: received apparent error message "E3" for upper
E3 is a fan error. This is usually caused by poor connection to the fan. Remove all connectors and reinstall assuring tight connection. This should remedy it unless the fan is bad, which is very rare!
Posted on Jan 13, 2011
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
fixitnow.com/.../troubleshooting-the-e3-error-code-in-maytag-mah6700-...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ...
www.shopyourway.com > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
www.appliancerepairlesson.com/.../how-to-fix-3e-error-code-on-a-samsu...
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
Amana front load washer error E3
https://www.youtube.com/watch?v=fx7Lrj7gEy4
Jul 06, 2015 | Amana NFW7200TW 27-in. Washer Front...
Lg wd-3245rhd LE error message
This seems to be a fault in the motor wiring harness, check all the connectors to and from the motor, check the male and female connectors. Also check the sensors to the motor which can cause this motor to show up as overload.
Jan 14, 2013 | LG WD-3243RHD Front Load Washer / Dryer
Its flashing E3 and chiming. and stopped washing
Hi
E3 is an overload error and indicates that the washer motor is not running properly. You can take out some clothes and then restart the cycle by pressing the START/PAUSE button. After this, if the error appears again then check the motor connections, if everything appears fine then the motor should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 04, 2011 | Maytag MAH6700AWW Neptune Front-Load...
We get an e3 error message and we have no idea what that means. The machine will start but then at some point it simply stops. we have been able to use the rinse and spin cycles to get the water out of the...
It's an over load error. Don't put alot of laundry in the drum.
Copy and Paste from the service manual
- Motor overloaded due to too much laundry (Nonsensing)
- The motor hall sensor terminal is not connected.
- PBA fault
- The motor driving error from the PBA is weak.
: Unstable relay operation, etc.
This error
occurs when an
interference is
generated due
to too much
laundry, etc.
Dec 28, 2009 | Samsung WF337AA Front Load Washer
Samsung front load washer keeps getting E7 and E3 what is this?
E3 - MICOM is attempting to drive the motor but is not getting any
response signals from the hall sensor. Visual check shows
motor is not running. (Locked, Defective Hall Sensor or
Overload)
Im not locating an E7 error. Did you mean 7E?
This information may or may not relate to your washer since you did not provide a model number.
Nov 25, 2009 | Samsung Washing Machines
Aug 13, 2009 | Maytag Neptune MAH9700 Front Load Washer
E3 error code will not wash, what does this error code mean?
i have a maytag washer and it says E3 and it will not work,does anyone know what that means please let me know...thanks
Apr 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
Bosch washer error code e3 what does it mean?
Error "E3" on a Bosch front loader means there is a problem with the door. Either it is not closed properly (user error or a blockage) or the locking mechanism has a fault. Check to see that there is no object shoved in the latch hole (our 2yo just did that) preventing the door from closing properly. If it is not that, a technician is advised. I tried to get into the machine to fix out issue but could not get to where the issue is.
Aug 02, 2008 | Bosch Washing Machines
Dryers Logo
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
