Question about Motorola Mobility Motopure H12 Bluetooth Headset
Pairing Motorola H12 Bluetooth Ear Piece with Vtech LS6245 Home Phone. It seems to power up, pair ( flashing blue/purple ), and indicate it is connected ( slow blue pulse ). Volume is on max, tones indicate so, but when I make or receive a call I get no sound out of the earpiece. So it indicates it is working but I can't hear or talk into it. Vtech phone found the device and lists it in its devices as active. Manual is very sketchy. I purchased this at Costco on a whim. It looks like it works but is in MUTE mode or something similar. Any ideas?
SOURCE: Motorola H700C Pairing with LG VX8700
im having a problem with my h700c and my lg too it was paired with a samsung and i got the lg now the phone phone the BT fine it just wont pair,wat can it be?
Posted on Feb 09, 2008
SOURCE: H700 Motorola Bluetooth works fine except when I talk
I used this solution and it worked...good luck with yours: http://www.geocities.com/jconkwright/H700fix.html
Posted on Apr 06, 2009
SOURCE: For some reason, My Motorola H700 quit going into
I have had this problem as well. Just to recap the problem. When you push the talk button and it turns purple, then you flip the speaker boom the unit starts flashing blue and will not pair. If this is the case then you should try unclipping the ear piece on the unit. Then repeat the pairing feature on the unit only this time hold the unit open with additional force. Not so much that you break the speaker boom, but enough to help the unit make a connection when it is flipped open. The problem with these units is that sensor inside does not always make a good connection especially after time and use. This should resolve your problem.
Curtis
Posted on Jun 24, 2010
nonontech
  • 4737 Answers
SOURCE: H12 bluetooth earpiece speaker has
This happens only when the speaker itself is bad or damaged or bad. The only thing you can do is replace the Speaker (if it's possible from the Motorola Service Center) or if it's still under warranty, claim it.
I am sorry to say this, but if you don't have idea on how to replace or where to find the spare, it's not possible to Fix It Yourself and never a recommended solution if you still wish to get it worked. Most frustrating thing is that this speaker type isn't available in the market except at the Service Centers.
If you need further help, let me know.
Good Luck.
Thanks for using FixYa.
Posted on Dec 16, 2010
vqcb43
  • 1623 Answers
Mobile Phones and Acessories
    Verified Fixya Pro
    SOURCE: How do I get my Motorola Elite Flip bluetooth headset to stop echoing on the other end?
    Alesia-
    Try a reset: ELITE FLIP Reset to factory default
    Try changing setting: MotoSpeak 3 0 Noise Cancellation settings
    What device are you connected to? I see other have reported after an android update on NON-Moto Devices: Headset echo problems after Android 4 3 update Verizon Wireless Community
    Mark
    Motorola Support
    Posted on Feb 11, 2015
    For some reason, My Motorola H700 quit going into pairing mode? No matter what I do I can't get it to go into pairing mode. I have a Motorola Droid, and have had it connected to it before, but now it...
    Curtis
    Jun 04, 2010 | Motorola Mobility H700 Wireless Headset
    How do i place a h555 motorola bluetooyh in pairing mode
    Step A - ENSURE HEADSET IS IN PAIRING
    MODE
    Power on headset by sliding the Call button
    towards the microphone to initiate easy
    pairing. After a few moments, the indicator
    light will be steadily lit in blue to indicate
    headset is in pairing mode.
    Step B - SET YOUR PHONE TO LOOK FOR
    YOUR HEADSET
    On your Motorola phone, press (Menu) >
    Settings > Connection > Bluetooth Link >
    Handsfree > Look for Devices.
    The phone lists Bluetooth devices it finds.
    Select Motorola H555.
    Select OK or Yes to pair your headset with
    your phone.
    Enter the passkey: 0000
    Select OK.
    When your headset successfully pairs and
    connects with your phone, the indicator light
    changes from steadily lit to flashing blue.
    Troubleshooting: Make sure that any devices previously pairedwith the headset are turned off. If the indicator
    light is not steadily lit in blue, turn off both the
    other device and headset, wait 10 seconds,
    then turn headset back on. Wait for the indicator
    light to become steadily lit in blue, indicating
    the headset is now in pairing mode.
    User Manual
    Aug 22, 2009 | Motorola Mobility Bluetooth Hands Free...
    How do I connect my motorola bluetooh headset S9 to my LG Vu920?
    When using your S9 for the first time, follow these
    steps to pair (connect) to your Phone:
    Important: If you are pairing separate Bluetooth
    devices for handsfree calls and streaming music, it is
    recommended that you pair your S9 with your
    handsfree device (phone) first.
    1 Ensure the Bluetooth feature is enabled (turned
    on) in your phone.
    2 Turn on your S9 by pressing and holding (|) button
    until the indicator light flashes three times in
    blue.
    After a few moments, the indicator light will be
    steadily lit in blue to indicate your S9 is in pairing
    mode.
    3 From your device, perform a Bluetooth device
    discovery/search. .
    When pairing your S9, use
    the following steps to perform a device discovery
    from your phone:
    After accessing the Settings Menu, go to bluetooth.
    to add a new device, tap [New].
    1. Tap [New] key to search the device that can be connected and which is
    within range.
    finds.
    b Select Motorola S9.
    c Select OK or Yes to pair your S9 with
    your phone.
    d Enter the passkey: 0000
    e Select OK.
    When your S9 successfully pairs and connects to
    your device, the indicator light displays blue with
    10 quick purple flashes. If wearing your S9, you
    will also hear an audio tone indicating successful
    pairing and connection to your device.
    4 To verify your S9 has successfully established a
    handsfree calling connection with your phone,
    dial a phone number you want to call and press
    the Send key on your phone.
    When successfully connected, you hear ringing
    on your S9. A Bluetooth Handsfree Phone (HFP)
    connection is now established with your phone
    Jul 13, 2009 | LG Vu CU920 Cellular Phone
    Motorola Bluetooth Headset MOTOPURE H12
    My H12 manual has the passcode as 4 zero's for most phones.
    Feb 05, 2009 | Motorola Mobility Motopure H12 Bluetooth...
    Motopure H12 will not pair.
    have you tried charging ur h12 headset until its full? if so then the internal battery inside the headset is probably getting old or dying out, suggest you bring it to ur nearest local Motorola store for details on repairing the headset.
    Feb 03, 2009 | Motorola Mobility Motopure H12 Bluetooth...
    Help pairing my H12 bluetooth
    I successfully paired my bluetooth by going into the connection phase, just using my common sense on what to do next once I turned the bluetooth on. Since it was not paired to anything, it automatically went into pairing mode. Thanks anyway!
    Dec 29, 2008 | Motorola Mobility Motopure H12 Bluetooth...
    Motorola bluetooth pairing
    1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
    3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
    4.Select H700 once a connection is detected.
    5.The passkey "0000" is now entered to confirm the connection has been made.
    6.The cell phone screen will now read "Bluetooth Connection".
    Tips:
    1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
    2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
    3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
    please give good rating if the solution works.
    Aug 09, 2008 | Motorola Mobility H700 Wireless Headset
    H700 bluetooth ear piece - Pairing with new phone
    Press and hold the call button while the boom is in the off position for 4 to 5 seconds. The blue indicator light should come on and stay on. The unit is now in pairing mode. Initiate you phones feature of searching for bluetooth devices and pair the two together. The default passcode for the H700 is "0000" four zeros.
    Good Luck
    Jun 22, 2008 | Motorola Mobility H700 Wireless Headset
    Bluetooth pairing
    1.Explore blue tooth devices from your motorola phone.
    2.it will sure find your blue tooth headset.
    3. Make sure your blue tooth headset is on
    4.in pairing function select your blue tooth headset
    Dec 22, 2007 | Motorola Mobility Bluetooth Hands Free...
    Motorola Mobility Motopure H12 Bluetooth Headset Logo
    130 people viewed this question
    Top Motorola Mobility Radio Communications Experts
    Lawrence Oravetz
    Dennis
    Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
