Question about Steiner Commander V: Binocular w/ Compass
Compass is too cloudy to read. Need to get it repaired. Steiner Commander 7x50 Pilot S model
4 Suggested Answers
  • 3 Answers
SOURCE: Steiner Commander Compass not working - possibly low of fluid?
Check this post for lens covers.
http://www.bluewaterweb.com/MarineHardware/Hardware.asp?
Posted on Jul 02, 2009
  • 73 Answers
I would contact Steiner. The Commander has a 30 year warranty. Unless there has been some damage caused by you it shouldn;t have leaked. To remove the compass would compromise the seal between it and the body. The body is nitrogen filled and the gas will escape. It's not a home repair job and needs to be sent to the company.
To get your year of manufacture look between both barrels at the front. The disc on the hinge pin will have a number. If it is a ten digit number. The first and third digits will give the year eg: 908245 etc is 98 or 1998.
If it is a five or seven digit number then it is the first two numbers eg 97123 is 97 or 1997.
Posted on Sep 01, 2009
  • 8 Answers
SOURCE: I have lost my eye pieces to mu Steiner Commander
Steiners tel is (800) 257-7742
Thomas E. Kuenzli Eagle Optics 800-289-1132
Posted on Dec 23, 2010
How do I tell the power & range by the serial no.
There should be a label near one of the oculars that shows something like 7x50, which would mean the power is 7x and the objective lens is 50mm. You would have to contact the manufacturer to ask questions with respec to serial number.
Dec 17, 2014 | Steiner Optics
I need a new compass for tasco 322 BCW waterproof binoculars. Any ideas where I can find one?
Open the battery door, clean all inside with Alcohol & Q-tip. Check that the AG10 or 389 batteries are positive up. Now the compass dial pivots on a shaft. It seems to get caught. Take a strong magnet and rotate it above the compass lying horizontal and spin it until it spins freely. Take it away slowly. Does the compass settle down to accurate heading? If so place back in the top of the model 322BCW observing the glued in marks on the clear window area. Re-screw in, press brass button red LED should light.. If NOT recheck for corrosion. Regards, Don
Jul 03, 2012 | Tasco Optics
INEED A MANUAL FOR TASCO OFFSHORE BINOCULAR OS36 7X50 RANGE FINDER COMPASS
http://mrcirl.org/whale/Binocularsmanual.pdf, little late, this might help someone out there......
Jun 16, 2012 | Tasco Offshore Binocular Os36 7x50 Range...
7x50 Marine binoclars, Fujinon w/compass. How do you swing the compass to get it to read more acutely? The compass rose, while viewing through the lense, is slightly off kilter (not centered in the view)....
I've been thinking about this for awhile, and it seems to me you're experiencing a factory defect. I don't have one of these devices, or I'd know what "normal" was for compass, but if you can't easily have the display centered, something is out of kilter. Was it always like this, or did it just start occurring recenty? Your best venue would be to contact Fujinon support and see if they will replace or fix the problem. Here is their site:
http://www.fujinon.com/NewsAndEvents/PressReleases/pr.aspx?id=84
Good luck, and hope this helps.
Dec 31, 2010 | Fuji Optics
Sep 01, 2009 | Fuji Mariner WP-CF Binocular
Eye rubber for 7X50 military marine
You can get the green eyecups for the military marine model from steinerpartsdirect.com I can also recommend changing the standard neck strap with a neoprene one for an older Steiner Nighthunter that is non cliclock. Makes for a much more confortable carry. Just make sure it is one that loops and isn't click lock.
Aug 10, 2009 | Steiner Navigator Pro Binocular
I have a pair of leica binoculars model 102351 which has vitical and hrizontal markings in the lens, I presume it has something to do with a range finder but I have no idea how it works. I would appreciate...
You are correct that the lines are for rangefinding. This is what is called a reticle. Without seeing how they are set up it is hard to determine the scale used. Most scales are in meters, some in yards, but they all work the same. Go to any of the following websites and download the instruction manual.
Go to Tasco and search for the Offshore OS 36 or 54 manual. OR go to Steiner Optic and download the manual for the Military 7x50 or Commander or Navigator models.
These instruction manuals have details and diagrams of how to read a rangefinder reticle.
Basically if you know the distance to an object you can estimate its height or size. OR if you know the size of an object you can estimate the distance to the object.
Jun 11, 2009 | Optics
Feb 15, 2009 | Steiner Military/Marine 7x35
Fujinon-Mariner WPC-XL Lens Cap replacement
You can order a replacement set at: http://www.bakermarineusa.com/index.php?id=17&cat=38&prod=137
Dec 02, 2008 | Fujinon Mariner WPC-XL Binocular
Steiner Commander V: Binocular w/ Compass Logo
51 people viewed this question
Top Steiner Optics Experts
Tony Parsons
Tony Parsons
Are you a Steiner Optic Expert? Answer questions, earn points and help others
