Question about Refrigerators
I have inherited a Jenn-air model # jcb2389grs and I notice the refrigerator is not cooling properly. I do not notice any air circulating to the top shelf when the freezer door is closed, but when the door is opened then I can feel the cool air com through the vent. The freezer is working fine, but I have noticed frost build up along the hinge side of the door. Can you tell me what the problem could possibly be?
  • Refrigerators Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 30, 2010
Jenn air jcb2389grs
Compressor running? Is the freezer iced up on the back of the panel?
May 12, 2013 | Refrigerators
First refrigerator stopped cooling, next freezer. Seemed like it was trying to defrost but their was lots of ice built up on coils. Jen-Air side by side, counter depth model number JCB2388ARB.
Causes of ice build up on coils:
Not enough freon (leak). Coil defrost heater not working (Coils on all freezers freeze up, but you should not notice). Coil defrost timer not working. Compressor thermostat not working (or end fell out of proper location).
:o).
Jun 04, 2011 | Jenn-Air JCB2388G Side by Side...
Frozen @ bottom, warmer(but cool) @ top
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5167095&diagram_id=1325654#d1325654
what your looking at is the pictorial break down of the freezer compt.
If the fan is important for airflow i would inspect part 3 as well, this is your defrost t-stat and controls when you need to go into and out of defrost, with extra frost i would tend to think your not goin inot defrost and its building up, not allow the fan to circulate the air properly.
while your in there you might want to check the heater as well
take a multi meter, and check the heater for continuity, sometimes these bend all out of shape as well and dont connect they way they should
Oct 17, 2009 | Jenn-Air JCD2290HES Side by Side...
I have a Jenn Air side by side model # jcb2389grs and I have noticed the last couple of weeks that it is leaking underneath, mainly by the freezer side, it seems. I inherited the fridge and don't have an...
sounds as if when it goes into defrost there is a tube that runs down the back of the unit inside the exterior casing. This tube empties out onto a small tray the sits right on top of the compressor in the back bottom of the fridge What this does is use the heat from the compressor to evaporate the water from the defrosting cycle. Check the back of the unit to see if the tube is sitting in the pan if not place it there and your problem is solved. Good luck on your repairs
Dave
Sep 15, 2009 | Refrigerators
Frig not stayng cool. Freezer not freezing
most fridges have a evaporator dish or container.
it must be emptied ...and cleaned and disinfected.
now-a -days they are usually mated with the compressor and cool this unit down. notice there is no coil along the back of the fridge...it is usiually behind the fridge at the bottom with a cardboard or plastic access cover...
this will make the unit cool better and return the cooling to normal....
\next
clean out your freezer...i bet it's full of 4 month old packs of something you'll never eat....this will let the freezer breathe and circulate air to the coil ...i bet it has 3 in of ice on it...yikes...your not alone...most people do this...\
get a freezer if your getting ready for the apocalypse and liberate some room.
good luck
May 18, 2009 | Jenn-Air Jenn Air Side by Side Counter...
The damper control is not working but I cant get to remove the cover in order to replace it
against the back panel there are 2 finger holes on that cover, at the same time stick your fingers in the holes and pull down to avoid the locks and then slide the cover out.
May 07, 2009 | Jenn-Air JCB2389G Stainless Steel Side by...
Jenn-Air JCB2389GRS Fridge not cooling properly
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
puiodf
Mar 15, 2009 | Jenn-Air JCD2389G Side by Side...
Jenn-air refrigerator model #jcb2389grs
You need to replce the adaptive defrost control that is located in the refgerator section of the unit . it is the upper right hand corner of the contols you must disasemble to find it . you must also defrost your freezer
Aug 17, 2008 | Kitchen Ranges
Refrigerators Logo
156 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
