Question about Frigidaire FMV157GM Microwave Oven
Timer counts down but it wont turn on - Frigidaire FMV157GM Microwave Oven
  • Frigidaire Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Aug 30, 2010
MicrowaveSvc
  • 9098 Answers
SOURCE: TIMER COUNTS DOWN, MICROWAVE DOES NOT TURN ON
To actons2 - This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Note to Austin8181 - Your problem is not quite the same.
Please report as a separate request and of course please include your brand and model number.
Posted on Mar 06, 2009
  • 212 Answers
SOURCE: timer counts down but nothing happens
one of three of your micro switches that monitor your door is bad. easy to fix. remove control panel and u will see the switches that the roll cam for your door hits.
Posted on Jun 22, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: MCM1290A Microwave Oven: the timer counts down but it wont heat or the turn...
Probably a bad door switch. See this file.
Posted on May 06, 2010
MicrowaveSvc
  • 9098 Answers
SOURCE: Light on ,timer counting down but not turning or
See this file on door switches.
Posted on May 16, 2010
MicrowaveSvc
  • 9098 Answers
SOURCE: frigidaire model cfmv156fmc allows programming,
If the inside light comes on when you try to cook, but the turntable and internal cooling fan do NOT, then that's a bad bottom door switch or that switch's mount.
See this helpful text file.
If the inside light, turntable, and internal cooling fan DO all come on when you try to cook, but it does not cook, then you have a bad relay or connection on the control circuit board, which we can repair for $39.95. Details here.
We have the service manual and have uploaded it to our site here to help you.
Posted on Jan 11, 2011
Cook works microwave timer stuck
If by "manual timer" you are referring to a knob that you turn to set the cook time, then you may have a failure of the motor that turns the timing mechanism, or a lack of power to it.
May 10, 2014 | Microwave Ovens
Microwave timer works but will motor will not run/cook.
If everything works on the unit, but you do not receive any heat or possibly the turntable does not turn you have a faulty magnetron (controls heat) and a faulty motor (controls turntable). You would require service on the unit, if parts are available. Some microwaves are so small in cubic foot size, that manufacturer's do not have parts available for purchase/repairs.
Dec 24, 2012 | Frigidaire FMV156DC Microwave Oven
Kitchenaid KCMS185JSS
The problem is one of the door switches has failed, usually caused by food partical buildup, switch must be replaced for normal operation.
Mar 12, 2012 | KitchenAid Microwave Ovens
The timer counts down but the microwave doesnt turn on.
I have a FNCB115GC Microwave problem. The microwave has a icon on the left hand side of the panel that looks like a opened book on a stand with lines on top. This is best that I can descibe it. The microwave turntable does not move or the microwave does to come on but the light comes on and the timer will count down. I have cleared the microwave and unplugged it with no results. Please help. Thanks in advance.
Jun 03, 2010 | Frigidaire FMCB115GC Microwave Oven
May 13, 2010 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
JVM1190 wont cook
You have a blown actuator. This is the device that creates the microwaves that cook the food. The cost of one of these will be as much as a new unit.
Nov 09, 2008 | GE JVM1190 Microwave Oven
Microwave Oven EM-804T
You need to trace the power feeding the high voltage transfomer. Because the table doesn't turn, it implies that a door switch or safety interlock is the problem.
Jan 01, 2008 | Microwave Ovens
Frigidaire FMV157GM Microwave Oven Logo
71 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
