Question about NetGear RangeMax WPN824 Router
My rangemax wpn825v3 router is great. There is only one problem. Every time a wireless device connects or tries to download something, the router resets. It is extremely annoying as the whole point for getting a router was to allow multiple people to research, surf the web, and most importantly, print. But because the router crashes, only the desktop pc is good for all of that, and it is unbelievably slow. Please help me to fix this problem. As I said, it has the latest firmware and also has wpa security. My laptop is also using the recommended USB adapter. But the router still drops. Again, please help. Thanks.
    President:
  • 1,768 Answers
1. ENABLE QOS ( Quality of Service) to allow no more than80% of the total bandwidth for each user. This is done in the router advance tab.
Posted on Aug 30, 2010
How many computers can the netgearN150 run at the same time?We r trying to run Xbox live, desktop ,mini hp notebook and a ipod...Is this to many devices?
No problem if you are connect using the wireless, but if you are connecting by LAN cables then it is limited by the number of LAN ports on the Netgear router unless you attach a LAN hub to the router to increase the number of LAN ports.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Feb 14, 2011 | NetGear WNR1000 RangeMax 150 Wireless...
How do i connect my netgear rangemax wireless router
You should have a manual/setup guide.
BUT, the basics of setting a wireless router are.
Connect an ethernet cable from your MODEM to the WAN port on the rear of the ROUTER.
Connect an ethernet cable from one of the LAN ports (usually 4) to your computer.
You now log on to your router via your web browser, set your wireless security (using WPA2) choose your password.
Save and exit from the router setup, disconnect the ethernet cable from your computer to the router and try and connect wirelessly
Your support page is here, choose which version of the router you have and download your manual
http://kb.netgear.com/app/products/family/a_id/1299
Aug 11, 2010 | NetGear RangeMax WPN824 Router
Slow upload speed of NETGEAR RangeMax Wireless-N 150
check if you have wireless WPA key enable, change in every 15 days the password, normaly you have open connection to all neighbours who like to use your internet connection. and you pay the bill.
Jul 15, 2010 | NetGear RangeMax WPN824 Router
The remote device or resource won't accept the connection
Try restarting your router. If that doesn't work than check if you didn't accidentally hit the wireless button on your laptop as many people tend to do this and not realize it.
Apr 09, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
This router is not working
Try the reset button to put it back to factory default. If it's still not working, it's time for a new router.
Feb 26, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
Wireless light is not on
To restore the factory default configuration settings without knowing the administration password or IP address, you must use the Default Reset button on the rear panel of the router. 1. Press and hold the Default Reset button until the power light blinks on (about 10 seconds). 2. Release the Default Reset button and wait for the router to reboot. If the wireless router fails to restart or the power light continues to blink or turns solid amber, the unit may be defective. If the error persists, you might have a hardware problem and should contact technical support.
Nov 27, 2009 | NetGear RangeMax WPN824 Router
Connecting a router to a gateway
Sure, you just need to change the ip address of the Rangemax. Netgear usually uses 192.168.0.1 for their router ip addresses. Plug the ethernet cable from your PC into the Rangemax. Open a web browser and put 192.168.0.1 into the address bar. You should reach the home page of the Rangemax. Change it's ip address to 192.168.0.2 and save.
Run an ethernet cable from one of the four ports in your Netgear gateway to the internet in port on your Rangemax and all should be well.
Jan 15, 2009 | NetGear RangeMax WPN824 Wireless Kit
Netgear rangemax wpn824 incorrecty or won't detect wireless conn.
Check ISP configuration to match Router settings with your supplier requirements.
Your issue seems related with wrong settings on Router WAN configuration.
Check if DHCP is required on your router or if it has tio be configured as a BRIDGE.
Your ISP should be ready to support you. (Or Netgear)
Dec 31, 2008 | NetGear RangeMax WPN824 Wireless Router...
Can not install my router
First of all power off the net gear wireless adapter and than try to install the rangemax. if it dosen't work than please check the dhcp range in both the wireless router are the of the same range. than kindly the change the range of dhcp of this new rangemax wireless adapter. you can change this dhcp range my connecting the router to your computer and login by default ip . e.g http://192.168.1.1 and login with userid "admin" and password "admin" than go to lan management option and try the same.
Dec 03, 2008 | NetGear RANGEMAX WNR834M Router...
Internet connection
The problem may lie with your WiFi adapter on the 2nd computer.. these days NICs (adapters) have a Power Off capability and they will go to 'sleep' to save power.. you can try to resolve this through the Device Manager > Network Adapters > and the Properties of your WiFi adapter.. look for a tab on the Properties named Power Management..
Otherwise, it this is occuring on the WiFi Access Point, look for something in the interface to maintain Persistent Connections.. Since I do not use Netgear, I would have to find the manual to be sure.. but lets try the first option before we go on..
Dec 17, 2007 | NetGear RangeMax Next Wireless Router...
NetGear RangeMax WPN824 Router Logo
90 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
