Question about Buck Alpha Hunter Fixed Blade Knives Gut Hook
I recently dropped my knife with the blade open it fell into some rocks and the blade tip broke on impact.
You can re-shape the tip with a few steps.
Do not use a grinding wheel, it will heat the blade too much, and you will lose the temper of the blade.
First, use a file to take off metal. Start by filing off the 45 degree at the cutting edge caused by the break. After you get the right shape, a whetstone will smooth the edge out, and let you sharpen it. I fixed a Buck 110 folding knife fir my brother a few years ago. It is obviously shorter now, but holds a good edge and works fine.
Posted on Nov 12, 2011
Poulan self propelled 22in blade hit a rock broke tip of blade starts then stalls
Did you bend the crankshaft. To check this out remove spark plug wire and tip mower on it's side and turn blade by hand and watch the shaft the blade is fastened on to. There should be no wiggle motion what so ever and if there is it may be bent causing the engine to not operate properly.
Sep 27, 2014 | Garden
What is the difference between a pizza wheel cutter and a pizza rotating knife?
A pizza wheel cutter is a metal wheel that rotates through the pizza so you can cut it even when it's hot. A pizza rocking knife is a thick metal blade with handles that you can use to rock backwards and forwards through the pizza to cut it.
Jan 10, 2013 | Home
I dropped my psp and it broke and won't turn on. I
Something more than likely chipped off/broke from the impact of the drop. Have you tried opening the PSP? *Note - opening your PSP will void your warranty.
Apr 04, 2012 | Sony Video Game Consoles & Games
I unscrewed Stanley 10-379 Interlock retractable knife and now I don't know how to put back the gizmo that fell out or the three blades that came with it.
Google: how to change blade in Stanley 10-379 utility knife. Stanley website shows how knife & blade look on the outside. Put it together so it looks like that. Sorry, but ain't don't know how to send the picture to you.
Oct 21, 2010 | Garden
Gerber Multi - Plier 600 Needlenose: my knife broke on my gerber 600 a friend has an ol...
no need,send your knife to gerber and they will replace it.gaurenteed for life.
May 16, 2010 | Gerber Blades Multi-Plier 600 Needlenose
Just purchased a Stanley FatMax 10-778 retractable knife. Cannot figure out how to load the blade for use.
1. Make sure the side lock is unlocked.
2. Push the thumb tab all the way to the front of the blade handle.
3. Insert the blade in the opening, you may notice two notches on the top side of the blade.
4. Press the small blade release button as you slide the blade into the knife. You may have to jiggle up and down to get the two notches on the blade fully into the handle.
If properly inserted, the exposed area of the blade should look very close to an equilateral triangle.
make sure both notches of the blade are inside the handle. They notch into the thumb lever.
good luck
Mar 20, 2010 | Stanley Fatmax Xtreme Retractable Utility...
Stanley 10-777 utility knife: I need to reinsert the retractable blade slide back into the knife body. I try but the knife won't close.
I had the same trouble. The blade holder was out of the knife and would not go back in. I fixed it this way: open the screw knob all the way to the least tension. Slide the two parts open but not all the way- there is a tab on the blade holder that gets in the way if you try to drop it in at the fully open position. With the two halves SLIGHTLY open- slide the blade holder in making sure that the tab is seated in it's slot. Depress the thumb tab and bring it to the most forward position and the two halves should be able to be seated together again.
Oct 27, 2009 | Stanley Hand Tools
No running manual 4 summasign pro D610 vynal cutter
You can get assistance and possibly a manual for your Vinyl Cutter from a Summagraphics Repair facility such as
ADVANCED GRAPHICS
1027 N. MAIN STREET
TEL: 210-227-9393
SAN ANTONIO, TX 78212
I hope this helps. Toni Gallucci, Glass Act
Mar 17, 2009 | Computers & Internet
Stanley knife blades fell down drum and under
Probably the best thing to do in this situation is to empty the washer out, then unplug it and turn the water off at the spigot.
Then invert the washer, leaning it back, so as to reach the blades under the drum.
Mar 04, 2009 | LG WFT1071TP Top Load Washer
Buck Alpha Hunter Fixed Blade Knives Gut Hook Logo
412 people viewed this question
Top Buck Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Buck Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
