Question about McCulloch 13HP 338 Cc Portable Generator # FG6000MK
My fg6000mk i think the rod cap that connects the rod to the crank has broke or just came off. i can remove the spark plug and the piston is at full stroke. i can take a small 12inch 1/4" extension and push the piston down and slowly pull the cord and the piston pushes back up to the end stroke position. about to pull it apart but i was told it is hard to find the parts.? need help locating parts and part numbers for that piece so i can fix it.
    Scholar:
  • 97 Answers
Tear it down if indeed this happened i highly suggest you replace engine that will interchange with one that you can fix cheaper and easier the old engine with that damage will not be worth fixing hope this helps
Posted on Aug 30, 2010
My Briggs and Stratton is only running on one cilinder. I've changed plugs and the coil on the dead hole and still no change. Don't know where to go next.
sounds like a connecting rod may have broke. take the spark plug out and put a screw driver in the hole and turn the engine over slowly. as the piston rises it should push the screw driver out of the hole. if it don't a connecting rod broke. don't let the screw driver get in a bind. it should move around freely. and the piston will push it back out as it rises.
May 20, 2016 | Garden
Can you change a piston with out pulling the motor.
Remove the oil pan and unbolt the connecting rod from the crankshaft on the damaged piston and push it up. It will come out without removing the engine
Mar 01, 2016 | Cars & Trucks
While driving truck there was a popping noise, motor turned off . Distributor cap and rotor along with spark plugs and wires changed. Truck still won't start. 2003 dodge ram 1500 5.9 litre
5.9 aren't prone to this, But pull the distributor cap. Have someone crank the engine and watch to see if the rotor moves. Also put the number one piston on top dead center on the compression stroke (remove the spark plug to check compression side). See where the rotor sets compared to a diagram At top dead center.. Sounds like the chain broke (unlikely) or jumped.
Sep 08, 2014 | Dodge Ram 1500 Cars & Trucks
How to remove crankshaft for campbell hausfeld compressor
I assume you have removed the valve head-valve plate-cylinder assembly from the base and pistons. Remove the four bolts holding the bearing cap assembly on one side of the crankcase and remove the cap. You have to pull on the crank to get the crank bearing out of the opposite side of the crankcase. Move the crank forward and turn it until the rear bearing will clear the crankcase and the whole thing will tilt and come out the top. Campbell sells the entire crank, con rods, pistons & rings as an assembly under part number VT040600AJ. This is the best way to go as they don't have con rods to go on the crank if you were to get the journals turned down. NOTE: During reassembly, the bottoms of the cylinders have a taper so you don't need a ring compressor to get the pistons in the cylinders. Just be sure the oil rings are in properly before pushing the cylinder all the way down. The thin oil scrapper rings have a tendency to fold over and get caught between the piston and cylinder.
Jan 29, 2012 | Air Tools & Compressors
40hhp evinrude will not crank, even with pull cord?
First take the spark plugs out and take a peak in and see if anything looks bad like a burnt or broke piston. You will need to take the head off to fully inspect the cylinders and pistons but sounds like one is seized or broke. If they appear fine and nothing obviuos then we will need to take a look at the gearcase for broken linkage or gears and lst but not leaset your connecting rods to the crank could have bad bearings and not allowing the motor to turn over. There is not an easy fix for these items and may involve a rebuild of the engine if something is locked up. If the motor has been sitting for a long time you could possibly free it up by using a penetrating oil in the hole for the plugs and let it sit overnight and then try and crank it over.
Oct 02, 2011 | Boating
Hit stump with lawn mower, engine has no compression, replaced particially sheared key, still no compression, what do i need to do? Engin is 12.5 briggs
You may have a broken connecting rod. Remove the spark plug and see if you can observe movement in the piston. if you can turn the crank and the piston follows ... it is probably OK. You are saying no compression which would indicate no piston movement due to broken con rod.
I could be wrong ...
Thanks for your interest in FixYa.com
May 31, 2010 | Garden
ENGINE KNOCK
It's related, The connecting rod pins may have gotten damaged and needs to be replaced. The knock you are getting sounds like the piston slap due to the connecting pins being damaged and the piston is moving around the cylinder walls and connecting rod. When the spark plugs wire was crossed the wrong spark plugs fired while the piston was still on it's way up the cylinder as to having it fire on the way down. This will cause stress to the valve's, piston, connecting pins, crank shaft, and main bearings. In short all the internal lower moving parts to an engine. Good Luck and have a compression test on all the cylinders and the one that is damaged will be the lowest compression reading.
Jan 05, 2010 | 2004 Buick Regal
I put a 91 engine in to 88 body every thing fit but my engine wont start
Only three possiblities. no gas, no spark, or the timing of the 2. So first follow the full lines and disconnect and turn on the ignition. That will start the full pump. you should see gas flow. Next remove a plug wire and dont hold it but place it near a plug or anything metal on the engine. You should see a spark when cranking the car. Finally its the timming of the two. remove spark plug from number 1 cylinder, with a wrench turn the crank shaft around untill the cylinder comes to top dead center. Look through the spark plug hole you should see the piston top. Now take off the distrbuter cap and look to see which terminal the rotor is touching. follow the wire and make sure it is the same wire that goes to the number 1 cylinder. Of course if the distributor rotor isnt rotating then of course your timing belt is broke. Good Luck.
May 22, 2009 | 1985 Mazda RX-7
Engine cranks slowly after overhaul
the only thing i can think of is
1. did you check the journal clearance to the main and rod caps? if this isnt within specs could be too tight.
2. did you put the rod caps and main berring caps on the same way you took them off....ie did you mark every thing 1 for #1 2 for #2 ect. if you installed the berring caps the oppsite way or didnt keep them in order some thing could be out of round causing tightness.
3. the same goes for pistons.......the mark should be pointing front for all. (ch approiate engine rebuild for info)
i would recomend trying to remove all spark plugs and try to turn the engine by hand( DO NOT TURN IT BACKWARDS>see which way the starter turns the motor) feel how it turns. if its hard then easy some thing is out of round poss installed wrong. personally id take down the pan and check the install. also take valve covers off ck the clearence of rocker arms. check your pushrods valve motion ect. you might also might want to break it down before you do some expensive damage.
tip.....if you didnt mark the rods and main berring caps and might have put them together incorrectly, remove the berrings and look at the honing marks. with patience and a good light you can see if they are lined up(cap and block for mains and cap and rod for connecting rods.) ie the cross marks line up.
good luck
Jul 28, 2008 | 1986 GMC Safari
McCulloch 13HP 338 Cc Portable Generator # FG6000MK Logo
91 people viewed this question
Top McCulloch Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Are you a McCulloch Electrical Supply Expert? Answer questions, earn points and help others
