Question about Xerox Phaser 7300DN Laser Printer
Paper james at the fuser, i replaced the fuser but it still jams
    Scholar:
  • 92 Answers
Try resetting the nvm settings (Pag 3 of the attach PDF under Support Menu >> Service tool Menu) And the next time you try to print configure correctly the paper settings on the printer and on the print driver. Please make sure your are configuring the paper weight correctly so that the fuser applies the right heat and pressure.
Posted on Aug 30, 2010
Jam 4201 message
home sancor error poblem
Aug 16, 2016 | Kyocera FS-6525MFP
Plain paper jaming in fuser unit
must be fuser unit, look for these signs :
1- upper roller damaged
2- does not have a "polished " finish
3-lower roller has ripples /waves on it
Apr 08, 2014 | HP LaserJet 1320 Printer
Canon lbp 2900 paper jam
if paper jam at the half of of fuser unit then problem is with fuser or spong roller tell us location of jaming
Mar 31, 2014 | Office Equipment & Supplies
Brother Fuser Unit not feeding paper
It is possible the gloss stock is gumming up the printer.
Jan 08, 2014 | Brother HL4570CDW Printer
IR2230 jamming after the fuser. any suggestions?
Hello, if the paper jams in the fuser you first must check the separation fingers. If the paper comes out of the fuser unit and gets jamed you must check the delivery rollers to be clean and the sprokets to be in good working condition.
Let me know what you find.
Nov 17, 2010 | Canon IMAGERUNNER 2230 Copier
Code : H5-01
Check for paper jam in or by fuser unit. Remove paper. On the keypad press P * C * and SIM 14 to reset copier. If you get 5 jams at the fuser unit in a row it gives this code. If it keeps jaming double check for paper, my have a faulty sensor.
Aug 31, 2010 | Sharp MX-2300N Color Copier
Paper jamed
Sounds like the fuser is causing the jam. Anything from a dislocated pic finger to other paper debry can be causing these types of jams.
If you open the back door, will the page exit the printer fine of does it still jam?
If it still jams the fuser is definatly the problem. If it dosen't, then it might be the delivery assembly causing the jam.
You might be able to see where the jam is happening if you print something and watch it though the back to see where the paper catches and jams.
Nov 19, 2008 | Brother HL-2040 Laser Printer
Paper Jam
If you are getting a lot of jams in the fuser then there is a problem in the fuser unit !
Is it jamming like an accordion? if Yes, then the problem is w/ the little fingers in the fuser, they are worn and need to be replaced. The rollers in the fuser should be shiny and smooth if not they ca also cause jams.
What black thingy are we talking about and where? if it's the fuser rollers ( where the paper exits and gets hot then try cleaning w/reg soap & water rag then wipe off.
Nov 17, 2008 | Sharp AR-153E Copier
Error paper jam
ellow bkadam,
there something little piece of paper stuck at you fuser there.that why appear paper jammed...try to open u fuser cover...maybe it can help
Nov 07, 2008 | HP LaserJet 2840 All-In-One Printer
Media Jam- Fuser
thx m8. Media jam: Fuser i had...
new there was no paper jam so looked about for the sensor and found that the little arm thing that gets liffted up as the paper pass was not falling back down so it thought the paper had jamed. i just took the back panal off and put a small bit of soft foam under it so it always got pushed back up.
works a treat now.
thx again
Oct 02, 2007 | Konica Minolta magicolor 2430 DL Laser...
Xerox Phaser 7300DN Laser Printer Logo
135 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
