Lid switch is not working, and is leaning away from thewasher. the lid is not able to trigger the cycle.
  • Washing Mach... Master
  • 43,501 Answers
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Aug 30, 2010
Washing machine will not start washing when lid is lowered
ya. not a big problem it seems. here it goes
when ever you close the lid the tip of lid touches a sensor which signals the control board to start the rinse cycle.
now these many days that sensor has been in dying stage. that is why you were often closing it to let the cycle open.
now that sensor has completely dies.
just replace the sensor at the point where the lid touches the opening.
after that enjoy washing.
Jan 04, 2008 | Washing Machines
Why will it only wash through a whole cycle if i am leaning on the door?
For safety reasons manufacturers started to put switches on washer lids so machines would not run with lid open. Your problem is with your switch. It may have wore out, or through use broken a small piece off it's end, not allowing the switch to fully engage. When you lean on the door, you are helping the switch fully engage. Look around the perimeter of your lid and you will find the switch. GOOD LUCK FRIEND.
Nov 17, 2014 | Kenmore 24" Built-In Dishwasher with Ultra...
I have a Kenmore washing machine: Model 110 20722990. When it gets to the final spin cycle sometimes it works sometimes it doesn't. You can hear it going but the agitator is not moving and it does...
ok first, i need you to do a little test,,,put unit on final spin ,does it spin at this time ,,yes so pick the lid up every so lightly ,,did it stop ...put the unit in final spin again unit does not spin push down on unit lid and it spins..in both cases you have a bad lid switch.,,the part # is 3949238 the picture is how it look,,if you need help installing just repost...good luckonthejob5130_1.png
Sep 09, 2011 | Kenmore 24032\24036 Top Load Washer
My Kenmore 400 washer does the following. If I start a wash cycle it goes through entire wash cycle without draining ever, just washes until it ends. If I lift and close the lid when the timer gets...
lid switch stops machine from spinning when the lid is open, Make sure the lid is fully closed. Loose screws on the lids right side not holding metal arm properly, or the arm is not positioned properly (the end which is pointed down when the lid is open needs to be slightly farther away from you, towards the back of the machine, to actuate the switch fully: or the lid switch itself which is underneath the top,
Jan 03, 2018 | Kenmore Washing Machines
My washer will not spin in any cycle
you have a defective lid safety switch it is normally under the lid,lift up the lid and look for a tab sticking down from the lid that goes through the top cover,this is the piece that triggers this switch
May 08, 2010 | Frigidaire ATF6000ES Front Load Washer
Lid switch
Yes...replace your lid switch. It is not normal to have to use an ink pen, lean on the washer lid, slam on the lid, or use any other means to operate the washer outside the normal functions that it was designed for. In many cases, you actually cause more damage to the appliance by not investigating the cause of the problem. A lid switch is a very simple and inexpensive fix. The following link explains how to replace a lid switch:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
In many cases a simple inspection of the lid switch is all it takes to fix it. It could be loose or not making proper contact. Repeated slamming of the washer lid or using a foreign object to get it work, however, may have damaged it. Check the mounting screws that hold the switch in place, first. If the screws are loose or missing, that may be all this required to get the switch to line up correctly with the lid strike. The lid strike is a small plastic piece that is physically mounted to the washer lid. The strike activates the switch through a slot as the lid closes. If the lid strike is broken or missing, this will also cause the same symptoms.
If the model number you have this listed under is correct, you can find replacement parts at searspartsdirect.com. Just type in the the model number and you can locate what you need under the "Top and Cabinet" heading. The lid switch is item number 11 (part #3949247) and the lid strike is item number 20 (part #358684).
I hope you find this information helpful. The total cost of your repair is less than $50 if you follow the instructions in the link I provided. Repair it yourself, save yourself from an expensive repair, and potentially get some longer years of use out of your washer. Let me know if you require additional assistance.
Sep 08, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer quit
sounds llike a bad lid switch assy, not realizinf the lid is shut, for safety reasons wont run, can you hear any "click" just before the lid actually closes, it should be triggering the lid swith, if no t reppalce the lid switch assy, reall common issue
Apr 17, 2008 | Washing Machines
Wash cycle will not start
you may have leaned on lid and damaged the lid switch , so the washer thinks the lid is open all the time unit will fill then stop with lid up.
Apr 13, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
