Question about Ovens
Wiring diagram for a efg-201 thermostat multi select 240vac 16a invensys. T150 541-1-913
2 Suggested Answers
tbreeze47
  • 3083 Answers
SOURCE: I have purchased an oven
My Adobe Reader isn't working on .pdf files, but this header on google mentioned your unit, so perhaps it has a wiring diagram:
http://www.google.com/#sclient=psy&hl=en&q=EFG-201+wiring+diagram&btnG=Google+Search&aq=f&aqi=&aql=&oq=&gs_rfai=&psj=1&fp=f66f1a25e5eaf8db
If you go to the following website, they have many diagrams and parts lists and wiring schematics for ovens:
http://www.appliancepartspros.com/
Just enter the model number and a page will come up if they have it.
Good luck, and hope this helps.
Posted on Sep 26, 2010
Need wiring diagram for old 1960's General Electric Wall Oven
55de40b.jpg Hopefully this will help. Don't know if it is the same model, but it is a 60s GE built in oven.
Jan 26, 2008 | Ovens
Thermadore WO-16A electric oven but the thermocouple has gone out.does anyone know of a replacement part?or at least part #?
I believe you mean a thermostat. Contact a distributor such as Automatic Appliance Parts at 800.323.0270
Nov 15, 2014 | Thermador Ovens
How to wire t71th thermostat?
Try here, select thermostat model scrool to the bottom, wiring diagram available
http://www.macspares.co.za/stoves-microwaves/type-591035-71th-thermostat-6mm-shaft-bush-mount
Jun 04, 2014 | Ovens
Simpson evolution 804 oven element changed
possibly check continuity with power unplugged. that will give you an idea if switch is defective
Dec 24, 2017 | Ovens
JTP56 Electric Double Oven Dead after self-clean. Power Pigtail comes into back of top control enclosure in flex conduit. The three red,black,white conductors are spliced to 2 molex connectors. I am...
I doubt there is a fuse on the pigtail, it sounds like your black wire is grounded somewhere. Check black to red, if you get 120 or close to it, your black is shorted to ground.
Jun 07, 2011 | GE Profile JTP56 Electric Double Oven
Wiring diagram of a Satchwell type70th thermostat switch
need wiring diagram for defy gemini petit chef oven switch
Dec 07, 2010 | Ovens
Smeg fan oven not working, all other functions ok
You need to place use a multimeter to check the element for continuity if that is ok then the next step is to check for 240v being
switched to the fan and element array.
With the unit switched off at the wall put the test leads onto the correct points ( Use the earth post for the Black lead) switch the meter to a range to cover the 240vac and then switch on the unit
If there are no readings then you need to go back up the wiring to check the input to the thermostat
Feb 24, 2010 | Ovens
GE J BP27G R1AD Oven Not Heating Fully
Hi Jeff. You should have a wiring diagram with the range. Check for an envelope on the back of the range, inside the back splash, or taped to the inside side wall of the range if you remove the lower drawer. That all being said, first check to see if the start or stop time knobs on the timer have been pushed in (and possibly turned). If the clock runs, it will clear this out within 12 hours, but on these old ranges often times the clock no longer runs. Make sure these knobs are turned until they have "popped" out or you won't get the necessary voltage where you need it. Secondly, when a bake element burns out, it can cause damage to the electrical contacts in the oven selector switch (part number WB22X5122 ) which can be tested with an ohm meter if you can find the electrical diagram. Also, the oven thermostat (part number WB21X5320 ) can be damaged in the same way. Unfortunately, these parts for these old units are not very cheap.
The little bit of heat you are getting in your oven now is most likely only from the 120 volts going to the broiler element when in Bake. During Bake, your bake element should get 240 volts (until thermostat is satisfied). Setting to Broil should give 240 to the broil element.
Dec 14, 2008 | GE Ovens
Ovens Logo
458 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
