Question about KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher
KitchenAid 24" KUDI01ILBL1 Stainless Steel Built-in Dishwasher All of the Control lights are flashing. I need the reset code to reset the control panel.
SOURCE: how do I change door panel and disconnect the control panel?
I am actually looking a stainless steel panel myself. Where would you able to buy one?
Posted on Jun 07, 2008
THENTHEREWER
  • 131 Answers
SOURCE: KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher
sorry stclairn,if its new & you have a waranty let them deal with it(why through good money after bad)hope this helps.thanx for using fix-ya.
Posted on Nov 16, 2008
  • 833 Answers
SOURCE: Food left on dishes
Scrape your dishes of food.  Dishwashers remove whatever is left.
Posted on Nov 26, 2008
  • 10865 Answers
SOURCE: Stainless panel for Kenmore 3631532 dishwasher?
I have two options for you to consider. One is to take your panel to any sheet metal fabricating shop and have them make a stainless steel version for you. The other is to get a spray can of stainless steel appliance paint and apply it. i have used the stainless steel paint on entire appliances with excellent results.
Posted on Jun 05, 2009
  • 37 Answers
SOURCE: kitchenaid dishwasher, control panel is not
I don't know your technical ability, but there is a fuse located next to the control board inside the console, this is a good place to start. Kitchen Aid is good about putting tech sheets on the back of the kickplate and it should have wiring and diagnostic info there. Just be sure to put the sheets back so the next service tech to work on it will have them :)
Posted on Sep 01, 2009
Clean light flashes and dishwasher will not work
when the clean light flashes its displaying a fault code based on the number of times it flashes...if it flashes 7 times then pauses then flashes 7 times again its displaying error code#7 if 4 times then pause its code#4 ect.
This tip i wrote will tell ya how to reset the board since sometimes its just electrical anomilie..reset the board and if it again flashes let me know how many times in a row it flashes and i will determine which error code it is , heres that tip to reset the control board http://www1.fixya.com/support/r10357661-get_whirlpool_dishwasher_start_when
GENE
Sep 26, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
The "clean light" is flashing
Indicates control hasn't sensed a rise in water temp during heat cycle. Make sure you hear the water being circulated during wash cycle. If so the heater, control board, thermostats or wiring are most likely bad. If heater, therms, and wiring check good its usually the control. When fixed press Heat dry- Normal-heat dry-Normal or High temp- air dry-high temp- air dry to reset control.
Sep 25, 2011 | KitchenAid 24 in. KUDI02IRBS Stainless...
Clean light flashes 7 times then restarts, but dishwasher won't run
This issue means that your dishwasher isn't heating. There are a lot of things that can cause this issue. Go to the link to see all the possibilities of what can cause this issue and how to reset the control board.
http://www.appliancerepairlesson.com/dishwasher-2/dishwasher-clean-light-blinking-7-times/
Good luck
If you need parts you can always go to Appliance Parts Pros in the link below.
AppliancePartsPros.com
Mar 04, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
The clean light flashes clean, seven times. I can reset the machine, but the problem persists. How do I determine if it is the heating element?
Kitchen Aid models with the stainless steel tanks flashing clean light requires changing out both the heating element and the electronic control due to a change in voltage on the heating elements. By ordering the heating element, it comes with the electronic control. For your particular model it is a part #8194200. Just shop around to the different parts stores online, to get the best price. This will fix your problem.
Jul 30, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Clean button will just flash need to know how to reset
The clean light is flashing due to a failure in heating the water properly. Follow the link below for instructions on resetting the control and information on what may have caused the failure. Let me know if it was helpful.
Clean light flashing
May 30, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Control lite just blinks no mater what button i push wont start
HI,
If it is the green clean light flashing then you may have a problem with the water heating up. I have put together some instructions on what might cause that and how to reset the control so you can use the dishwasher again. Follow this link and let me know if it was helpful.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
May 04, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
My KitchenAid dishwasher will not run. Start light is blinking
Make sure the controls are not locked. Some units have the ability to lock the controls so that kids cannot turn on the dishwaher. You can also try unpugging the power to the unit from under the sink for about 10 minutes and then plug it back in. This may reset the control board if it has a fault and stopped from error code.
Sep 26, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchenaid custom 21 dishwasher will not turn on
Hi, this is a control fault that is localized in the logic sector of the control board. the logic chip which holds all wash programing is damaged. you will need to replace the control asap if possible...
thank u
rate me!!
Jul 27, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
"Normal" light flashes
You need a new control bd. #W10084141. If the diagnostic mode will not work then the board will have to be replaced.
Mar 06, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher Logo
106 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
