Question about Whirlpool LER4634J Electric Dryer
I press start and it won't start. It sounds like a clock ticking
    President:
  • 1,554 Answers
The usual cause of this problem is a blown thermal fuse which is located on the blower housing. It is wired in series with the motor and the dryer will definitely not start if the thermal fuse is blown. Disconnect power to the dryer then remove the rear access panel by removing the screws securing it to the cabinet.
Once the access panel is removed, look for the thermal fuse on the blower housing as shown.
Bypass the thermal fuse by taping together the wires connected to its terminals or jumping a wire between the wires then plug in and start the dryer. The thermal fuse (part number 3392519) is indeed blown and needs to be replaced together with the cycling thermostat (part number 3387134) if the the starts with the thermal fuse bypassed.
Simply unscrew both parts then screw the new parts in place. It's better not to disconnect the wires yet until the new parts are secured then connect the wires to where it should be connected on the newly installed parts. This avoids messing up the wires upon reconnection.
Do not use the dryer with the thermal fuse bypassed to avoid incurring further damage to other components and due to fire hazard reasons.
Posted on Aug 30, 2010
No sound icon
Hi Right click over the clock select properties, this opens menu with tick boxes for clock volume etc. click in volume box and press enter.
May 30, 2012 | Dell Inspiron 1720 PC Notebook
My car won't start. The key is put in the ignition and there is a ticking sound. The lights come on, the break is hard to press but when i do the ticking noise stops. 2002 honda civic. only 40,000 mi....
Your battery power has been drained. First thing I would do is to charge the battery via using another car to jump start the car and let it run for an hour or two. Or get a charger and jump the car. Either way I would run it for an hour or two recharge the battery. If that doesn't work then you will have to replace the battery.
Nov 07, 2011 | 2002 Honda Civic
Upon turning key, car won't turn over. There is a consistent ticking under the dash and steering wheel. It sounds like someone sending a telegram in Morse code. The ticking tones down when turning the...
no idea without a good look myself as this sort of problem from a description is difficult to answer unless your a dealer fitter who works on these cars all day long .Sorry i cannot be of any help but all i can suggest without a good look myself is a bad earth on the relay ?? But???
Jul 27, 2011 | 2006 Ford Freestyle
97 Merc Grand Marquise just started a loud
If sound comes from under the dash, it might be an hvac actuator that is having a problem? Sometimes you can put your hand on it and feel the vibration? Sometimes with a relay, you can do the same thing.
Mar 13, 2017 | 1997 Mercury Grand Marquis
I have a SMEG colonial style oven (SI850APZ5) with an analogue clock and timer which is constantly making an irritating ticking sound! Sometimes when I have used the timer, it starts ticking even louder. ...
Yea they make a racket don't they.. I never really heard one as bad as yours sounds... a lot of the older day ranges had loud tickers too, a common fix I believe was to use vasaline/grease and pack it around the gears? but maybe a new one would be quieter.
Feb 17, 2010 | Kitchen Ranges
No Manual
To set the clock:
1. Press the clock key 3 times until the hr/min icon flash.
2. Press the + or - key until you come to your desired time.
3. Press the confirmation (key or tick) key.
Jun 08, 2008 | Gaggenau EB 270/271 Electric Single Oven
Whirlpool LER4634J Electric Dryer Logo
149 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
