Question about Frigidaire Affinity ATF8000FS
I have an affinity washer, stackable, model atf8000fs1, it runs for 15 minutes and quits, help
    Scholar:
  • 97 Answers
Sounds like it has a bad timing cycle when it reaches that point the catch for the next cycle don't engage if this is the case the timer will need replacing i suggest contacting a service dept hope this helps
Posted on Aug 30, 2010
Why does my frigidaire affinity front load washer model FAFS4272LWO beep every 15 minutes when it is not running?
Bring the unit out of sleep by pressing any button, wait about 5 seconds and the press AND HOLD start/pause and CANCEL an E followed by numbers should appear in the display. Tell us what those numbers are..
Jan 20, 2017 | Frigidaire Washing Machines
Frigidare affinity stactable front loading dryer. runs for 10 to 15 seconds then shuts off. plenty of exhaust air. it has heat inside. tried resetting to factory specs but still have the same problem
Good Morning Percy, thank you for your inquiry!
From the information you have provided you Frigidaire dryer runs for 10 to 15 seconds and then will shut off. It sounds like it could be a possible problem with your thermostat or control panel. A reset may help with any internal miscommunications inside of your dryer. You can reset your dryer by disconnecting power from it for at least ten minutes. If that does not help your issue I would recommend having a professional technician out to perform an accurate diagnosis on your dryer to avoid any unnecessary part purchases. I hope this information is helpful to you. -Matt
Aug 12, 2015 | Frigidaire Affinity Series Stackable...
ATF8000FS1 washer is stuck in pause. Any suggestions?
Hi friend, thanks for your inquiry!
If your washer continues to display an error code of "PAU" it could be an issue with your door lock but if the door strike is not sitting properly within the latch your washer will continue to provide the error code "PAU". Additionally, if your control panel is registering that the door is closed you may continue to experience the "PAU" code. I would recommend having a professional come and properly diagnosis your washer to prevent any unnecessary part purchases. I hope this is helpful. -OOS
Oct 12, 2014 | Frigidaire Affinity ATF8000FS
Error 66 on frigidaire affinity washer ATF8000FS1
Hello Jacqueline Sanchez, thank you for your post!
I understand that your Frigidaire washer is showing you an "E66" error code. I show that "E66" stands for the heating element relay failure, which means you could be experiencing an issue within your heating element or main control board. I would recommend performing a reset to your appliance which you can do by flipping the circuit breaker for roughly ten minutes. If that does not correct the issue I would recommend having a technician come out to properly diagnose and repair your appliance. -Matt
Aug 16, 2014 | Washing Machines
I have a frigidaire front-loading Affinity model #atf8000fs1 washer with the stack kit placing the dryer on top. During the spin cycle, it dances frantically and when I canceled the cycle and opened the...
Go to www.repairclinic.com and enter atf8000fs1. You will see a list of common replacement parts (including the gasket) and may be able to view a generic Frigidaire video showing disassembly.
Apr 16, 2017 | Frigidaire ATF6000ES Front Load Washer
My front load stackable dryer is making very load squeaking noises when it starts up for about 15 minutes
The rear bearing for the drum needs to be greased. If you don't grease it and ignore it, eventually the dryer will stop working because you will be overloading the motor, and the motor will start drawing additional current that it will trip the breaker. Greasing the rear bearing is a 15 minute job. You need to purchase high tempo grease. Frigidaire sellsthe high trmp grease that is required.
May 24, 2009 | Frigidaire Affinity ATF7000E Front Load...
Affinity front loader ATF7000FGO E23 ERROR
E23 error code means the drain pump relay on the control board failed or wire off pump. You already replaced control board so check the wire at the pump and make sure it's secure.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/134879700.pdf
<a href="http://tclaundryrepair.com/">St Paul Appliance Repair</a>
Feb 25, 2009 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity ATF8000FS Logo
288 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
