Question about K and N Kawasaki 750 Brute Force K and n Air Filter 0507
I have a kawasaki 750 brute force that cranks and idles good but when you give it gas it acts like a rev limitor kicks in and wont let it run wide open what should i do to fix this problem ? i have change the plugs and cleaned the fuel injectors, pulled off the exhaust incase it was creating back pressure and unplugged and replugged every electrickle connector and still runs the same
You need to reset the computer its under your seat there are 2 plugs by your fuse panal just unplug them and plug them togather turn key on wait 7 seconds them plug them back up right
Posted on Nov 30, 2010
Or its your fuel pump mine did the same and i tried everything even thought it was not the fuel pump because i tested it and it seemed ok but i ordered and new fuel pump motor off ebay (about $600 cheaper) and now it runs right i tried everything b4 that
Posted on Dec 24, 2013
My 06 Kawasaki 4 wheeler. Backfires when light switch is on going down highway. Is it battery related ?
Problem with Brute Force, please save my 4-wheeler from shop ...
www.kawieriders.com > ... > Kawasaki Brute Force/Prairie/Bayou
Nov 16, 2011 - Problem with Brute Force, please save my 4-wheeler from shop! ....2007 kawasaki 750 4 wheeler backfire problem ... should I save for my brute force 750? moe, Kawasaki Brute Force/Prairie/Bayou, 3, 10-18-2010 06:55 PM. Backfire thru exhaust
Feb 24, 2011
Low RPM Backfire Through Carb
May 24, 2010
four wheeler keeps backfiring
May 9, 2010
06 brute force 750 poping and backfire
Feb 18, 2010
More results from www.kawieriders.com
Oct 08, 2015 | kawasaki Motorcycles
05 kawasaki bf 750...battery was low......put a new one in..........now backfires out the exhaust.......tried the belt reset.....didnt help......suggestions.?.....
Brute force backfire problem - YouTube
? 1:06
www.youtube.com/watch?v=VFxGBYoVFqk
May 5, 2013 - Uploaded by gubba1957
I bought this 2006 750 it had a backfire problem when I bought it so I cleaned ... 2005 Kawasaki Brute Force 750 - Stock Exhaust Modification ...
Oct 03, 2015 | kawasaki 2005 Brute Force 750 4x4i
Brute force 2009 750 runs but will back fire an stop
How long since the oil has been changed? Is the oil level OK? It sounds like you have a sticky valve that hangs open once in a while.
Jul 31, 2014 | kawasaki 2009 Brute Force 750 4x4i
Why does my brute force four wheeler barg down when I give it gas then it backfires
The float in the carburetor is possibly sticking. have the carb cleaned or run some carb cleaner through it.
Aug 27, 2013 | HMF Kawasaki Brute Force 750 08-11 Swamp...
Kawasaki brute force 750 cranks over then locks up it won't turn over by pulling the rope
sound to me you got faulty security switch check them 1st, specially the kick stand, most bike locks up if you try to place it in gears while the kick stand is still on. hope it helps
Dec 24, 2012 | Motorcycles
My kawasaki brute force 750 was running great all winter with no problems,except for the odd tough time starting due too weather condition. But my problem all started this morning, everything seems normal...
Hey Belbowski,
Has it been sitting for a while?? Sounds like it could be several things..
1. The needle and seat in the carb may be dirty/clogged/sticking and not allowing a full flow of fuel into the float bowl.. when the bowl fills, it will run fine for about 20 - 45 seconds then "run out of gas.. it will restart and repeat this over and over.
2. The petcock/fuel tank may be stopped up/clogged/blocked and not allowing a full flow of fuel to the carb... causing the same symptoms as #1.
3. ..maybe..you may have a vacuum leak causing the fuel pump to not pump enough fuel to the carb. = Symptoms #1
4. Fuel pump might be bad. = Symptoms #1
Once you eliminate these items... repost with results.
Jun 12, 2017 | kawasaki 2009 Brute Force 750 4x4i
2002 Kawasaki ZR-7S. wont rev up.
Check you main jets ccccccthey could need a good wiring through with needle wire cleaners or try running it without any air cleaner unit .If it runs well then could be an air filter problem.
Mar 13, 2010 | 2002 kawasaki ZR-7 S
Quad bike engine
kawasaki brute force 750 will crank for like 3 to 4 seconds and then loose its spark u turn the key off and turn bak on and will crank again and then u have to repeat this over and over wont stay runing
Sep 02, 2008 | 2008 Hummer H3
K and N Kawasaki 750 Brute Force K and n Air Filter 0507 Logo
402 people viewed this question
Top K and N Toys Experts
ray gallant
Are you a K and N Toy Expert? Answer questions, earn points and help others
