Question about Samsung SpinPoint V60 SV0813H 80 GB ATA-100 Hard Drive
My desktop computer is done and I need to get the information from the hard drive. It is a Samsung Spin point Sv0813h/TGM. I bought the IDE to USB kit. How do I make it all work?
    Sergeant:
    Champion:
  • 286 Answers
It is really easy. If your using Windows 7, plug the IDE to USB connector to your Samsung Hard drive. Then using the provided USB cable, plug in the USB cable to the Hard drive. Then plug it into an available USB port on your other PC. Window will automatically install the needed drivers for you. Then navigate to Start/Computer/Local Disk E. Assuming there is no 2nd hard drive or partitions installed. And there will lye your Samsung Drive.
Posted on Dec 08, 2011
I want to download all info from my desktop and motherboard into mylaptop
Hi Eva!
If your desktop is crashed, then you will need to verify if its internal hard drive is still working, and then conect it using an USB/SATA/IDE adapter to your Laptop. This is one: http://www.sataadapter.com/SATA-IDE-ATA-66-ATA-100-ATA-133-COMBO-ADAPTER/sata-ide-adapter-usb-hard-drive-sata-drive.html
If the problem with your desktop is with its hard drive, then... you need to take your computer to its manufacturer technnical service center.
Sep 27, 2012 | Sony VAIO PCV-W600G PC Desktop
CAN I USE MY HARD DISC WITH USB CONNECTION
Yes, you can. You'll need a little more hardware however. You can find "hard drive enclosures" at many computer stores, ebay and electronics stores. They look like these. In order to make this work, you need to determine the physical size and interface of the Samsung hard drive first. Most notebook drives are 2.5" and most desktop drives are 3.5" types (regardless of capacity). You'll need to find an enclosure for the drive size and interface type.
The Samsung drive is likely to be either and IDE type with a SATA (serial) or PATA (parallel) interface. Pictures of SATA cables are here, and PATA cables are here. You would select the enclosure depending on 2.5" or 3.5" size and SATA or PATA interface type. Lastly, would be to choose either a USB connection between the computer and enclosure, or an ESATA type. ESATA simply means External SATA. If your computer offers an ESATA jack on the front or rear panel, you might consider using it as it is much faster than USB. If you do not have an ESATA jack, stick with the USB type. All but the most oldest computers support USB 2.0 standard speeds, newer computers have a faster USB 3.0 speed (5Gbit/S) standard, but this hardware is fully backward compatible to the USB 2.0 & USB 1 speed (480Mbi/S) and hardware standards. If your computer has the original USB 1.x standrad speeds, you might consider purchasing a USB 2.0 or 3.0 expansion card as the USB 1.x standard is very slow (just 12 Mbit/S). Check these links for pictures of ESATA, USB 2.0 and USB 3.0 If you look closely, you can see the slight differences. USB 1.0 and USB 2.0 look identical.
Some enclosures will require / include a power adapter for the drive. Make sure you get what is required to get the drive to spin up properly. After your computer is up and running, connect the external drive to the USB jack and let the computer install drivers as needed; then use it as any other thumb drive etc. ESATA however may be different. In any case, follow the instructions included with the enclosure you purchased.
After copying good data, you might be able to format and scan the Samsung drive and map out the errant portions. Even still, I would not use the drive for important information or day to day uses. If you do, be sure to maintain frequent backups.
May 23, 2012 | Computers & Internet
Ok maybe i should give more detail.....i have a samsung hard drive i used as a slave in my old computer......i recently bought a new dell computer and it doesnt support the older ide/molex connections so i...
if you just need the data of this hard drive you might need USB 2.0 To SATA IDE 3.5 2.5 Hard Drive Adapter Cable kit
i have one of these myself and they work a must have to retrieve any data of my old hard drives
cheap recovery
$8.69 + Aus 95c postage
http://www.ebay.com.au/itm/120738767650?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649 you could get this on Ebay if you dont have an account you will need to create one
https://scgi.ebay.com/ws/eBayISAPI.dll?RegisterEnterInfo
Add Email adress
Add Bank Acc
Add Credit Card
also add your postal adress
also add a paypal account
when you get to the paypal login page at the bottom you will see new to paypal sign up tab
paypal to create an account
paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress
http://www.paypal.com/
be very specific when you type in the search
always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described
you will even see the pictures of your item so you cant make a mistake and get them home delivered
hope this helps you
Apr 12, 2012 | Samsung SpinPoint T133 Series (HD300LD)...
Samsung SV0813H Unmountable_Boot_Volume ERROR
If you recently made any hardware upgrades check that the hardware is fully compatible with your machine.If nothing like that has been done, reboot the pc in safe mode by pressing F5. Some machines are F8. Check your programs and features for any newly installed software or updates. Remove any conflicting software or updates and restart the pc normally.
Oct 31, 2011 | Samsung SpinPoint V60 SV0813H 80 GB...
Dell Dimension 8400 running xp has died. Can I put the hard drive into a spare slot in a Windows 7 PC to get the data off the XP HD?
Two Options:1. Yes you can as long as your Windows 7 PC has the correct connection for your hard drive. Most likely you need an IDE connection. If you have an IDE hard drive and the Windows 7 PC has an IDE connection, then you will need to make sure to "slave" the hard drive by moving the jumper on the hard drive to slave mode.
2. If your Windows 7 pc doesn't have an IDE connection, the purchase a USB to IDE cable adapter:http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2329300&CatId=3770
This way you can plug your hard drive into any computer through USB.
Best regards,AbdielComputer repair plantation
Oct 27, 2011 | Dell Dimension 8400 PC Desktop
Hi, I am trying to work out what kind of connector I need for my old HHD's (I have 2) I am thinking of buying an outside casing so that I can transfer my old data from these two drives to my current HDD,...
Hi. Thanks for your question.
Your Hard drives connection type is IDE. You can but adapter for your hard drives to connect them via USB port to your current machine. This is link to one of adapters like this on ebay so you can have a look at what I mean http://cgi.ebay.com/USB-2-0-IDE-SATA-S-ATA-2-5-3-5-5-25-Adapter-Cable-/280501660830?pt=LH_DefaultDomain_0&hash=item414f33ac9e#ht_3091wt_1139
Buying adapter like this would mean that you could still use your drives and keep files on them. Use them as external drives. Only connect when you need them. I hope this helped you. Please do not hesitate to ask more questions if this is needed.
Dec 06, 2010 | Samsung SpinPoint V60 SV0813H 80 GB...
MY HARD DISK SV4002H 40 GB IS NOT DETECTED BY THE SYSTEM AND I NEED THE DATAS. WHAT IS TO BE DONE
If the computer cannot boot up then to retrieve your data then remove the hard drive from the computer and connect it to an USB hard drive adapter. Then plug the adapter into a working computer's USB port. This computer will detect this as an external storage device. You can then click on this device and open the folders and files to copy and backup your data files.
Nov 10, 2010 | Samsung (SP0822N) 80 GB Hard Drive
Is my hard drive broken? Cant get it recognised on other PCs
I'm having a similar problem with the same Akasa integral enclosure, so far I have tried 3 different hard disks and not one of them will work properly and on two different computers.. , all of the hard disks I've tried are Samsung .. but I'm sure that makes no difference. I plan to send back the enclosure to where I bought it from and get a different one from a different manufacturer.
Dec 10, 2009 | Samsung SpinPoint P120 SP2514N 250 GB IDE...
My Motherboard wont recognize my Hard Drive
Is it Sata or IDE?.Also is your boot order set to the CD rom as the first device.The O.S is bootable only if the CD runs it first. Windows should format it later in the install process.
Nov 25, 2008 | Computers & Internet
Samsung SpinPoint V60 SV0813H 80 GB ATA-100 Hard Drive Logo
74 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
