I have not used my camera that much and have managed to lose the book already, nearly every time we record something it stops with the error message, "video management file is broken, to record/playback video, recovery is required".
you might need to download and install a messenger program which will incorporate using a web camera skype yahoo messenger
If you choose to install skype or another messenger program you will have the options to join make/id or if already a member to sign in
an Id must consist of letters and numbers just one number will do the Id must be unique skype will automatically search to see if your Id you have made is available eg: loosey9
hope this helps
I resetted many times after recovery but it did not work.
I had the same problem aftre putting a 32 GB in the Aslot.Put 2 different sd in the slots.put the largest one in the B slot,that solves the problem.i put a 4 gb in A and a 32 GB in B.
