Question about Refrigerators
Power surge in the neighborhood, due to rain storm, caused the unit to not turn on compressor. Fan works but compressor will not turn on
  • Mike Smith
    Mike Smith Aug 30, 2010
    Brand and complete model number important for this resolution .
  • 17,130 Answers
Can be failure of the starterr relay which is coupled with the compressor. remove and check, if bad replace. If power goes to click in the relay and the compressor does not work then it is the failure of the compressor.
Estimate the cost of overhauling to the cost of a new one. make sure that power is on to the compressor before it can be confirmed.
Also checck the resistance from the outside and if there is coil leaking or open. check the capacitor also which can be faulty and will not start the compressor.
Posted on Aug 30, 2010
We had a power surge from the campground electrical hookup. Now our usually quiet ac in the rv is running very noisy. What could cause this?
A power surge can trash the motor inside the compressor and the inside fan motor. Now comes the question will the repairs cost less than a whole new unit?
May 12, 2017 | Heating & Cooling
I turned my AC off during a 3 day cool rain spell. When I turned it back on to dehumidify the upstairs only the fan ran. I can hear that the unit is energized but the compressor
possible bad capacitor for compressor. or burnt wire connection at several locations inside the unit. a look see at the capacitor can tell if the cap is swelled up-it's bad. it is possible for a voltage spike ,during a storm, to cause these problems.if you remove the electrical panel door,of the unit, be sure to turn off high voltage to the unit at the breaker. remember that a capacitor stores a charge that will electrocute you even if high voltage is turned off at the breaker!!!!!!!!
Oct 12, 2015 | Heating & Cooling
My D-Link 2750U router is not working from last evening due to the heavy rain, lightning and storm. What should I do?
If you have lost three devices I'm sure you had ALL your computer devices on a UPS/Surge protector? Always connect ALL computer devices to a Power strip, UPS, or even better, unplug or switch off when not in use. A power strip with Surge Protection will help, most have a power switch/ Circut Breaker, to shut down ALL devices connected when not in use.
Feb 14, 2013 | Computers & Internet
Won't turn on
This is a clear failure of the power supply or the control panel due to the power outage and so will require that the power to the unit internally is checked. Sometimes this can be due to a fuse blown out or a control panel failure within the unit due to the intermittent fluctuation.
Nov 30, 2011 | Pool & Spa
Power went out for 3 seconds electric storm warnings but did not see/hear any lightning strikes. Central air-conditioning fans spins But the compressor doesn't turn on. There is one condenser and looks...
During these storms power gets shut down fora sec and comes back with a tsunami type surge. why? Because the generators are going full blast at the electrical plant in your area. No load is applied anf they sky rocket into Zapland babes! Any slight glitch or momentary outage causes a surge. It goes away but it comes back with a fury. So if your AC's run cap is a little old and tired from workin that condenser like it ain't not thang, Then the resulting surge will zap that puppy and it will look like this:
themobilian_2930.jpgRemove the power from the outside unit and look at that capacitor. It prob has went under. If it is leaky or preggers, it is bad. Replace it and party on! More here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 28, 2011 | Heating & Cooling
My desktop board is P5NSLI, suddenly when i'm working with it, a lightning splash because its raining, i turned off my computer 'cause i'm worried if what may happened, after the rain i get back to work...
This may have been due to power surge. Try replacing the power supply. Also, inspect the motherboard and other components for any physical damage. Motherboard may get damaged due to power fluctuations, which requires replacement.
CreativeTECH
Nov 23, 2010 | ASUS P5NSLI (0610839134670) Motherboard
Hi, My Hampton Bay ceiling fan died after a power outage due to a surge in the neighborhood. My question is if the motor is damaged or only the remote electrical unit. How can I test the motor? After I...
as the motor is a brushless induction motor , the possibility of damage from a spike is remote
however electronic units will suffer damage so get in an electrician or replace the control unit and start/ run capacitor for the motor
Sep 06, 2017 | Hampton Bay 24002 Ceiling Fan
Goodman ckl49-1 fan doesn't work after a really bad storm.
It is possible that the rain has washed out the bearings and the motor is frozen up. You may need to replace the motor. Also you don't need to put more oil in the compressor. The compressor comes with oil already sealed in it and it does not need to be changed or any more oil added to it.
Aug 05, 2009 | Heating & Cooling
Replacement of air conditioner's compacitor
I am assuming this is a split system with the condensor outside and the air handler inside. What is the model of your unit? Is the capacitor a dual run capacitor? Is the compressor running? If the compressor is running and your condensor fan is not you need to immediately shut power off to the compressor or you will probably ruin your compressor. If the power went off due to a storm and you don't have power to the condensor fan did you check to see if the circuit breaker to the condensor was tripped. I would check that first. Even if the circuit breaker doesn't look like it tripped go ahead and flip it off and back on again. Even you suspect it is the capacitor you need to determine if it is a dual run (controls the compressor and the fan) or does it just run the fan? If it is a dual run capacitor you will have to get the numbers off the capacitor and try and find a match at the local hvac supplier. If you have a Grainger's in your city they probably will have a match. When working on your unit don't forget you are working with high voltage that can KILL you, If you don't know what you are doing call in a professional. If you decide to tackle it yourself make sure you turn off the power to both the inside unit and the condenser. I always pull the disconnects inside and outside, flip the circuit breakers and turn off the thermostat just to be safe. Then I double check by using my digital multi-meter to ensure the power is totally off. The capacitor stores power so you will have to discharge it by using an INSULATED screw driver and touching the blade across the terminals. Discharge the capacitor AFTER THE POWER IS SHUTOFF. Before you pull the wires off the capacitor terminals I suggest you make a drawing of where the wires are connected. You should have markings with a "C", "F" and "Herm". Even better, I like to take several digital pictures from different angles of the connections. After you remove the capacitor, I would suggest you take it with you to your hvac parts supplier so they can match it. Once you get the right replacement capacitor it is just a matter of connecting the wires back to the original configuration. Then restore the power by flipping the breakers, plugging the disconnects back in and turning the thermostat back on. Most units will not start up right away. They have a 5 minute delay built in to protect the compressor. Good luck and post back and let us know how it goes.
Jun 25, 2009 | Carrier Heating & Cooling
I have ge simon 3 which suddenly says phone not
you may have had a lighting strike to the phone line causing a surg to your unit. it may be fried. try completly powering down the system and powering it back up, then try to send a signal to your monitoring station. also you my have your monitorimg station try and connect to your system and check the programing it may have been scrambled.
mj
Apr 02, 2009 | GE Security Simon 3 Wireless Home Security...
Refrigerators Logo
75 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
