Question about Sub-Zero 661/F Side by Side Refrigerator
I have just noticed over the past few days that the refrigerator side is at 49-50 degrees. It is usually in the upper 30s. I am wondering if it is going out? My husband says it is because the kids stand in front of it with it open all the time. It does seem cooler in the morning. What should it be set at? It is approx. 12 years old. thanks for any tips or advice.
  • 944 Answers
Any one of this part may be defective.So we have to replace or repair accordingly.
Defrost timer:
Try turning the screw with screw driver in clock wise direction or anticlockwise direction and wait for 35 min to check Defrost timer has any problem.
Solution for If you have frost in the freezer and make the fridge work:
You could defrost the freezer by disconnecting the power to the refrigerator and letting it sit for at least 24 hours with both Doors.
Top-freezer Leaking:
If the Top-freezer leaking it turns into ice and eventually filling the air ducks with ice blocking airflow to the fresh food section causing it not to cool.To fix this, remove the evaporator cover, (back or bottom of freezer) and then remove all the ice. Once all the ice is removed, you need to unclog the drain. You can do this by forcing hot water down the drain.
Start relay problem:
Start relay problem-clicking noise in 2-5 minute intervals and it shuts of the compressor.so your fridge will send only warm air.You have repair the start relay.start relay plugged on to the side of the compressor and unplug it and shake it.If you hear any
rattle sounds its defective part.
Openings in the door:
Keep a paper in the door and close and check it are you able to pull it out easily.The
electrostatic force should not allow you easily pull the paper.If it so you have to replace the hinges or the hinges out of line or the cabinet distorted.
Often opening door will also allow the cool air to get out.So you should not allow your children to play.It will also increase the fridge energy.so your electricity bill will get increased.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Aug 30, 2010
The cooler side of fridge does not work properly. Why?
Brand name and model number would help. It should be inside the refrigerator section usually on the upper right wall.
Link to youtube videos about this problem is below. One or more of them should help with your problem.
Go to http://searspartsdirect.com/ and enter your model number. If your model is sold by sears you can see diagrams, parts lists, manuals and get help and order parts.
side by side refrigerator not cooling YouTube
Sep 12, 2014 | Refrigerators
Freezer defrost
If the unit is less than 10 years old going into defrost at least 3 times a day is totally normal and not harming anything.
Mar 01, 2014 | Frigidaire PLHS67EGSB Stainless Steel Side...
Our ice maker makes a little ice , and it doesn't drop. What is wrong with that? Also the house was built in 2005, but the previous owner hasn't live here. How come it can be that? Thanks
Turning the fridge temp down a degree or two will create more ice and at a faster pace. It usually takes a few hours to notice the increase in ice production.
Jul 04, 2011 | Sub-Zero 695/O Side by Side Refrigerator
I opened the door on GE Profile side by side refrigerator this morning. Not only was the the refrigerator not blow cool air. It was actully blowing hot air, it was like opening the oven. The temperature on...
Check if it is still under warranty - I think that it is usually 2 years.
When in this condition, was the compressor still running ?
There was one issue that occurred occasionally on some models - the fridge door has a height adjustment so you can level the 2 doors up. Sometimes, it drops a bit too much, and on models with the fridge door light switch on the top (not the side), it meant that it wasn't turning off the light. Some have 2 lamps (commonly 40W or more each), so you effectively have 80Watts or more of heating running constantly. If your (exact) model has the door switch on the side, this is Unlikely to be the issue.
If the compressor was not running, I could say something like "it might have got stuck in a defrost cycle", but this DOESN'T really fit with the operation of these fridges (no defrost elements in the fridge side).
Does this help in any way ??
Dec 10, 2009 | GE Profile PSW26P Stainless Steel Side by...
Side by side refrigerator in unheated space not working in cold
Good day,
GE recommends minimum ambient air temp above 55 degrees,
and that's pushing it.
Move it inside.
As an example. If the garage temperature was 10 degrees and the machine was left unplugged. What would the temp be in the fresh food section. If you said 10 degrees, you would be right.
P.S. Insulation does not prevent an area from getting cold, it just delays the time.
Nov 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge and Freezer losing cooling
thermostat control to deice the freezer is malfunctioning need a service tech to replace it so it doesn't keep the deicer on . Its exactly that, a warmer to deice the coils.
May 27, 2008 | Fisher and Paykel Active Smart E522B...
Sub-Zero 661/F Side by Side Refrigerator Logo
52 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
