Question about Frigidaire Dishwashers
Frigidaire Ultra Quiet 3 dishwasher- top arm does not seem to be getting enough water pressure to spin. Looked at hose on outside of washer - does not appear to be clogged - the bottom arm spins great.
  • 901 Answers
If two pumps are driving the arms, check the pump connected to the
low pressure arm.
Posted on Aug 30, 2010
Frigidare ultra quiet 1 top wash arm not cleaning properly
Hello ezideas - First I suggest verifying that there is enough water pressure coming into the unit and that it is at least 120F. Do you noticed if the spray arm will rotate freely or if it is damaged? If so, the spray arm assembly may need to be replaced. Connect with a professional to accurately pinpoint any potentially more serious issue.
Jan 14, 2013 | Frigidaire 24 in. FDB1050REC Stainless...
My frigidaire ultra quiet spray arm doe's not move.Water trickles out the holes,no pressure.
water does not spray on the top arm until a later cycle...only one arm spins at a time... a fridgidare thing
May 11, 2010 | Frigidaire 24 in. FDB126RB Built-in...
TOP RACK NOT CLEANING DISHES
Possible that the motor impeller has good particles in it, causing poor water pressure, which would be most evident on the top rack. You would have to remove the spray arm, then the filter, then the torx screws to get at impeller....unfortunately, that model of dishwasher isn't the greatest in the first place for washing, since it only has the one spray arm.
Apr 04, 2010 | Frigidaire 24 in. FDB126RB Built-in...
Arms don't seem to be spinning
please check the pressure of the water in the inlet if pressure is low then clean the water filter by removing the inlet hose and clean the arm rolers.
Nov 10, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
You need a new wash motor, the impeller is stripped.
Dec 21, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
I have a Frigidaire Ultra Quiet Plus dishwasher. The top spray arm isn't spinning during wash. The bottom spins fine and I can spin the top freely by hand. It appears there is not enough water pressure...
I may have the answer. I had what sounded to be the same problem. I found the dishes were dirty after they were cleaned, but I found there may have been a big pot lid blocking the upper arm. I decided to run the machine again, and after a bit opened the dishwasher after to make sure it was not a problem with the arm. Sure enough, the arm wasn't moving. However, I found out on the Frigidaire webpage that some models have an alternating spray cycle, where only one arm spins at any given time. After reading this I checked again, and it had moved by that time. I checked a few times more to confirm this. So it ended up it was an arm blockage after all. Hope this helped...good luck.
www.frigidaire.com/support/FAQ-Dishwasher.asp#6
Oct 20, 2008 | Frigidaire Dishwashers
Frigidaire ultra quiet I dishwasher
Sounds like the water may not be turned on to the dish washer.
The arm spins with water pressure
Oct 16, 2008 | Frigidaire 24 in. FDB510LC Free-standing...
Arms are not spinning
If the spray arms arent clogged up then you have a clogged filter.
Please Rate this !
Jun 23, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire 24" fdb641rj dishwasher
the check-ball runs the top spray arm both arms don't run at the same time and that's the correct fill for this model whats your problem
Feb 07, 2008 | Frigidaire 24 in. FDB126RB Built-in...
Dishwashers Logo
604 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Garth Jackson
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
