Question about Maytag MAH8700A Front Load Washer
Won't drain or spin and makes a noise in drain pump
You probably have a coin stuck in the water pump...i had the same thing happen to me last year...5 min fix...cost me $75 service call...i know better now...easy fix ...
Posted on Aug 31, 2010
Enter service mode, GE GTWN5650FWS washing machine. won't spin or agitate...just makes clicking noise. drain pump works. timer counts down.can I check the transmission operation by putting mac
NOT SURE WHAT UR MACHINE WILL DO IN SERVICE MODE BUT DOUBT IT CHECKS TRANNY? THE LIKELY CULPRIT IN UR CASE MAY BE A DEFECTIVE DOOR SWITCH? OR WORN MOTOR COUPLER ( BETWEEN TRANNY AND MOTOR) DOUBT ITS UR TRANNY?
Sep 26, 2014 | Washing Machines
GE Washing Machine WWSE6260B1WW won't spin out water makes a rattle noise
use a putty knife to remove the front panel , you can remove it by pushing the putty knife into the 2 black tabs between the top and front panel. from there you can get to the drain pump . inspect by taking the hoses off the pump and remove debris. If nothing found replace the pump. hope this helps, let me know
Feb 19, 2013 | Washing Machines
Crosley 5000 front load washer won't spin
Hello - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if water pumps out. If it does not, the unit could possibly be experiencing an issue with either the pump, door lock assembly or timer. Contact a professional to move forward accurately.
Nov 24, 2012 | Crosley Washing Machines
Frigidaire washer won't drain or spin
Hello - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if water pumps out. Supposing that it does not, I would suggest contacting a professional to move forward accurately. The unit could possibly have a faulty pump, timer, or door lid (if it is a laundry center).
Oct 11, 2012 | Frigidaire Washing Machines
Washer won't spin after rinse cycle
Hello Dorothy - Does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have either the pump or timer diagnose.
Sep 29, 2012 | Frigidaire FEX831CS Top Load Stacked...
Won't drain and won't spin ,makes a clicking sound
sound as though the drain pump has something hitting the impeller making the clicking noise,and the filter basket next to the pump is blocked by debris and not letting it drain
Sep 01, 2012 | Maytag MAH6700AWW Neptune Front-Load...
The machine won't pump water or spin and makes nasty noise. When I turn the drum by hand there is no noise and feels normal.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jul 08, 2011 | Bosch Washing Machines
Makes buzzing noise and won't spin or drain
Sounds like something is stuck in the drain pump.  If nothing is stuck in the pump replace the pump.  It won't spin until it drains, so fixing the drain problem will fix the spin.  You can get at the drain pump by taking off the bottom panel.
Dec 19, 2009 | Frigidaire GLTF2940ES Front Load Washer
Maytag MAH8700A Front Load Washer Logo
61 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
