Question about Brother MFC 210C All-In-One InkJet Printer
Dcp115c brother unable to clean
Need resett procedure
  • Anonymous May 25, 2008
    Hi! After carrying out the reset procedures, it shows machine error 4F. May I know how to solve this problem? Thanks!
  • guest555 May 25, 2008
    Hi! After carrying out the reset procedures, it shows Machine Error 4F. May I know how to solve this problem? Thanks!
  • 1,512 Answers
Hi willjenks
Here is the procedure to reset the printer.
1. press the Menu & Mono start keys. next press the up arrow key 4 times to make the machine enter the maintenance mode.
2. Enter 8 & 0 by using the up arrow key & SET keys.
3. press the mono start key several times untill the purge count appears on the LCD.
4. enter 2 7 8 & 3 by using the up arrow key & set keys to reset the purge count to zero
5. press the stop/exit key to return to the initial stage of the maintanance mode.
6. enter 9 twice by using the up arrow & set key's to exit from maintenance mode
If you still have problems, post back to me here and we can go further. Thanks for using FixYa, a FixYa rating would be great for this info. Cheers :)
regards
robotek
Posted on May 08, 2008
Unable to clean... how am i suppose to do... thanxx...
Posted on Nov 24, 2008
Unable to clean
Posted on Oct 15, 2008
Very clever - Just remember that if you reset the purge counter but dont replace the ink absorption pad then you will eventually find a rather nasty un-washable stain under your machine.
Inkjets have an ink absorption pad for a reason - to collect the excess ink, if you force the machine to re-use it then your silly.
BTW, i work for brother and have had many calls about ink leaking due to the customers following the instructinos on the net to re-set the counters, just remember, your machine will void all warranty if you decide to go into maintanence mode and change any of the settings (Brother can pull of a report to see if anything has been changed)
  • 4 Answers
Resetting anything on the machine for a specific problem does NOT guarantee solution.please call our customer service about this to provide the specific troubleshooting steps and know what the exact problem is.THANKS.i work for brother also
Posted on May 26, 2008
Unable to init
Check the small Plastic ribbon which goes from left to right of the machine when you are looking at the printhead and there should be dirt somewhere. clean it carefully and it will work
Mar 29, 2014 | Brother Any 12 Inks Dcp-115c Dcp115c Lc900...
Brother dcp115c unable to print error
High probability it is a waste ink count or "error 46" code fault. There are purge count reset codes available on line, but you should also remove and clean out the waste ink chamber. It is a messy job and given the age of the machine, you may be better off replacing it
Nov 12, 2017 | Brother DCP 115C All-In-One InkJet Printer
My printer brother DCP115C ''UNABLE TO CLEAN error code 50''
Machine error 50 is a error in Purge unit.You can't fix it by yourself and your printer need service.In most case the cost of repair is more than cost of new printer.
Nov 03, 2009 | Brother DCP 115C All-In-One InkJet Printer
Keeps wanting to initialize unable to use fax function
My 'BROTHER DCP115c' printer unable to initiate (error 4f). Please can you solve itfor me?
Nov 17, 2008 | Office Equipment & Supplies
BROTHER INTERNATIONAL
ATTENTION: CoDEC0012 "JOHN" email oblacks_pit@yahoo.com
UNABLE TO CLEAN?
1. TO ENTER MAINTENANCE MODE: PRESS MENU, MONO START, 4X ON ARROW UP (WITHIN 2 MINS)
2. USING ARROW UP BUTTON LOOK FOR THE FOLLOWING
a> 8 then press SET
b> 0 then press SET
3. USING MONO START, JUST PRESS IT UNTILL THE WORD "PURGE XXXXX" COMES PUT.
4. USSING ARROW UP BUTTON LOOK FOR THE FOLLOWING: "FLUSH"
A> 2 THEN PRESS SET
B> 7 THEN PRESS SET
C> 8 THEN PRESS SET
D> 3 THEN PRESS SET
THIS IS TO RESET THE PURGE COUNTER
5. USSING ARROW UP BUTTON LOOK FOR THE FOLLOWING
A> 0 THEN PRESS SET
B> 1 THEN PRESS SET (TO RESET UNIT)
C> 9 THEN PRESS SET
D> 9 THEN PRESS SET (TO EXIT MAINTENANCE MODE)
THAT'S ALL FOLKS JOHN
Jul 24, 2008 | Office Equipment & Supplies
Brothers dcp115c
search fixya forum for error 46. you need a new waist ink absorber box!
Jun 15, 2008 | Brother DCP 115C All-In-One InkJet Printer
DCP 115c How to disable auto cleaning?
did you already install your printer to the PC ?? have the installation disc ?? if yes , go to MY COMPUTER , DO A RIGHT CLICK at the icon of the printer and click PROPERTIES ,THERE you should be able to disable the command .
Apr 24, 2008 | Brother DCP 115C All-In-One InkJet Printer
Always Cleaning...
no. no tool.
set date and time. leave machine ALWAYS power plugged in.
machine automatically do some cleaning to keep air bubbles away and the nozzles working. this consumes very little amount of ink.
Brother dcp115c
cause the waist ink absorber box is fed up with ink. you have to replace the box and to reset the eeprom. search error 46 or unable to clean here. its written very often how to do that (same procedure for all brother inkjets)
Mar 17, 2008 | Brother DCP 115C All-In-One InkJet Printer
Unable to clean error on Brother DCP115C
Pls refer below to clear the "Unable to Clean" error:
1. Enter MAINTENANCE MODE: Press MENU, MONO START 4x on ARROW UP within 2-3 sec
2. Using the ARROW UP botton, press botton and wait for the ff #:
a. 8 then press SET
b. 0 then press SET
3. Using the MONO START, just press until the word "PURGE XXXXX" comes out
4. Using the ARROW UP botton, press botton and wait for the ff #:
a. 2 then press SET
b. 7 then press SET
c. 8 then press SET
d. 3 then press SET
e. Press Stop/Exit
(This is to reset the purge counter)
5. Using the ARROW UP botton, press botton and wait for the ff # to appear:
a. 0 then press SET
b. 1 then press SET (to reset unit)
c. 9 then press SET
d. 9 then press SET (to exit maintenance mode)
If after this procedure you still encounter problem, see your service center
Hope this will solve your problem "unable to clean".
epc.
Mar 10, 2008 | Brother DCP 115C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
1,198 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
