Question about Black & Decker SpaceMaker ODC325 Coffee Maker
My black and decker coffee pot won't brew. It tries but the water won't come thru. Its warming and making the gurlging noise, but nothing comes out. I have had it on the clean cycle for an hour with vinegar, but still nothing. Maybe the line is clogged.can I take it apart and fix it? It model #cm1010b
  • 2039 Answers
SOURCE: Coffee pot turns stops brewing in the middle of the cycle
i know you said you clean it but did you use a decaler calcium kill those machine pour 1solution 1part water put it on rince very good the decaler is nasty stuff hope it work cheers
Posted on Jan 20, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Cuisinart Grind and Brew will not emply all the water
The two most common reasons for overflow or underflow have to do with the carafe lid and the filter basket - they key to smooth flow with this coffee maker is making sure the filter basket and carafe lid are making the proper contact with each other so that the center knob on the carafe lid pushes slightly up on the filter basket spring. Make sure the carafe lid is completely closed. Make sure the filter basket is pushed all the way down. Make sure you are not using the gold tone filter and a paper filter at the same time. For some reason, I get better results when the handle of the carafe is resting against the right side wall. If everything is in place, I would suspect a problem with either the filter basket being clogged or some problem with the carafe lid - call Cuisinart as they should be able to order these parts for you.
Posted on Sep 29, 2009
freetek
  • 5568 Answers
SOURCE: Coffee maker brews MUCH slower and makes less coffee
It may not help but won't hurt; put a couple of cups of plain vinegar into the water chamber, turn on briefly until it starts to pump, then turn off and leave overnight - at least, if not longer. The mild acid content may clear some lime buildup.
Posted on Apr 14, 2010
SOURCE: black and decker spacesaver coffee maker
I need the replacement part of the coffee maker that keeps the water in the tank, black round gasket with a spring tell me more or where I can go and get replacement parts for it.
Thank U
Star Litle
Posted on Sep 24, 2008
SOURCE: Coffee Maker Model CM1010B Carafe spills when pouring
Solved the problem by taking it back to retailer..
Posted on Jan 06, 2010
What can I do if my 12 cup black and decker coffee maker wont brew. Power is on
These devices are unfortunately made cheaply these days. If it is fairly new, say within 6 months, contact the manufacturers customer support line (found on documents or their website) and they often just ship you a replacement.
Otherwise, if the water is not coming out and spilling over, make sure that the release in the brew basket is opening when the pot is placed under it. Some of them stick and then the coffee overflows.
Oct 01, 2016 | Applica Black And Decker 12 Cup...
Cuisinart coffe maker does not allow water in
Common problem, it is hard water issue, these coffee makers do not handle even slightly hard water as deposits build up quickly blocking water flow to element. Try one of the many coffee pot cleaners, but if it is as bad as described, may not be enough to clean out coils.
CERACOAT-NANOTECH.com
Apr 21, 2015 | Cuisinart Coffee Makers & Espresso...
We can't get our spacemaker coffee pot to start brewing. This was working great until we didn't make coffee one day and now it won't start to brew. Pot warmer is on but no water moving. What can I do to...
This problem seems to happen quite often. If the symptoms are similar to those posted in this string try the solution posted at the bottom. It seems to fix it most of the time.
Apr 04, 2010 | Black & Decker Spacemaker 10-Cup Coffee...
My mr. coffee coffee pot won't brew. it will make the sounds like its brewing but nothing comes out. what do i do?
Try running a cupfull of vinegar through it followed by a pot of plain water.This will remove any hard water deposits which may be blocking the tubes.
Nov 05, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
I put in 6 cups of water and only 5 cups brew. It
The amount of water you put in the carafe isn't the same amount you'll get out of the coffee maker, as some of the water is normally lost as steam vapor during the brewing process.
I would also look at the water level gauge inside the reservoir or on the sight gauge to make sure I have added the right amount to make the amount of brewed coffee I want.
As to the filter pre-soaking issue, it shouldn't matter since you likely made several pots since then and the filter has likely expelled any residue already. I would run a full pot of just water with a filter in the basket, just to see if you're getting a full carafe after brewing, making sure you have a full reservour to begin with.
As to the grind of the coffee, I find that a medium coarse is best for all but expresso coffee. However, you might want to experiment with your grind settings until you find the setting that makes the coffee to your likeing and taste. Coffee is all about what you like to drink, so take some time to find what you enjoy.
I use a high-end filter for all my drinking and coffee brewing water to get the best possible taste as it does make a difference.
My nieighbors have the same coffee machine and use the same coffee brand, etc., but don't filter their water. They've noticed the difference and always comment that they need to get a filter for their water.
When I run white vinegar thru my machine, I always run at least two (2) full pots of plain water thru the unit before I start making coffee again, to rid the reservoir of any vinegar residue.
Hope you find this helpful and best regards!
Aug 06, 2009 | Cuisinart DCC-1200 Coffee Maker
Black and decker spacesaver coffee maker
There are two heat stages in the Spacesaver. One is the carafe heater you can see while the other is an assembly within the main housing. This assembly contains a heater, thermostat, and a section of metal tubing with high temperature silicon connectors at each end. when the water storage tank is inserted it fills the heated section of the tube and when activated the water boils as it passes through the one way valve and forces the water into the coffee container. This steam driven surge repeats until all water has been moved to carafe. There are several failure modes associated with this assembly an I have two. 1. is the heater opening which I have and 2. is the thermostat degrading causing incomplete transfer and ultimately no transfer because it brings the temp down prematurely. Another is crud on the check valve so many problems - no solutions
Sep 20, 2007 | Wega Mininova EPU Espresso Machine
Black & Decker SpaceMaker ODC325 Coffee Maker Logo
3,247 people viewed this question
Top Black & Decker Coffee Makers & Espresso Machines Experts
eyecam
iandunn_tms
Henry  Thomas
Henry Thomas
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
