Question about Whirlpool ACC184PS Thru-Wall/Window Air Conditioner
You can set the temp for the unit to come on and it comes on and runs and cools for a few minutes then the compressor cuts off then the fan a little later. After a few minutes it comes back on and does the same thing. It never cools down to the set temp. The coils are wet but not frosting.
  • Whirlpool Master
  • 17,130 Answers
Is the AC set on an energy saving mode. Together with this program if the thermostat is defective the same symtoms can appear. So please check on the thermostat and replace.
Since the compressor is cutting off the cooling does not take place to the extend that is set.
Posted on Aug 30, 2010
Auto/On set to ON. Fan runs.
Sounds like the thermostat, the way to verify is to unplug indoor unit, remove thermostat, take pic of wiring with phone or label the wires as to the terminals. Carefully twist the yellow,(Y) Red (R) and the green (G) together. Plug the furnace back in, if the unit operates normally, replace the thermostat. I am basing this on the fact that the blower speed is changing. This could also be an anomaly within the circuit board in the furnace section, not likely though as the outside unit (condenser) is not controlled n by the indoor board unless this is a heat pump. hope this helps. D
Jul 21, 2015 | Dometic Rooftop RV Air Conditioner
When I turn my window unit on, it will cool for 2 - 3 minutes. Then the fan turns off and the compressor continues to run for maybe another 90 seconds, then shuts off.
Make sure the filters are clean. Check what mode it is on as well. On heating, it is normal for there to be a delay before the unit starts up and then "run on" when turned off. Also check what temperature is set on it. If the temp is too high, the machine will cycle on and off as it thinks it has already reached the temp you want.
May 25, 2015 | Heating & Cooling
4 ton Amana -heat comes on sporadic in spring and fall (Every season change) Heat worked through 20 degree weather. Thermostat at 74. Today is 100% humidity and 52 degrees outside and heat won't work. By...
Assuming this is a heat pump I'm guessing you have a bad temp sensor. Your outdoor fan is likely controlled by a temp sensor so it only runs as needed during heating. Fan not coming on and compressor still needs cooled therefore compressor protection kicking in?????
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Aug 12, 2017 | Amana Heating & Cooling
Subzero 611 freezer not cooling
Could be but before that check if settings are working. Set the freezer settings to coolest and see if cools. If ok, set to desired temp.
Dec 30, 2013 | Refrigerators
Air handler fan cuts on runs a few minutes and then cuts although thermostat is set to off.
your thermostat could be wired in to a energy recovery venilator which will bring the unit on for a certain amount of time every hour some thermostats have recirculate mode which will do the same thing to help filter the air
Apr 16, 2013 | Goodman Heating & Cooling
Intermittent colling in Samsung Window AC
so your reported figures show that the unit is operating as planned
the closer to ambient temp the shorter it runs for
the further away from ambient temp the longer it runs for
when the desired temp is reached , the compressor will stop but the fan will continue to run to circulate air past the thermostat so that it will switch back on when the room temp reaches too high temp
and that is why it is recommended to set the temp at 25 C as that is the most economical temp to run it at
Oct 30, 2017 | Heating & Cooling
Freezer not making ice pressures -5 suction 170 head and 1.1 amps what do u think the problem is?
Hi!!
How about thermostat settings? Set it half way for freezer and one setting below for fridge, control.
Also check:
a) evaporator fan, (the one in the freezer) it should come strong on if you let freezer door open for a couple of minutes.
b) cooling fan underneat fridge and make sure air can circulate.
c) when compressor kiks in, should stay on for a while, if not, check thermal protection bimetal switch, (little round plastic device w/ a wire coming out of it, inserted in compressor common prong) you should be able to hear a click when it cuts juice to compressor. Check compressor temp. at cut off.
Let's work on this for right now, let me know if helpful, if not, will try something else..
Good luck
Apr 02, 2010 | Refrigerators
The unit runs for a few minutes and completely shuts down
Without the model or make sound like a bad thermostat..check amps the the compressor and voltage... if the compressor is locking up or the thermostat cutting voltage to it..
Hope this helps
Apr 05, 2008 | Refrigerators
Whirlpool ACC184PS Thru-Wall/Window Air Conditioner Logo
167 people viewed this question
Top Whirlpool Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
