Question about Kenmore Ovens
I have a 30" electric oven, Kenmore Easy Clear with 4 heating coils, Model C880 6506190, Ser IME3431871, Type 30S. Problem: a) Two heating coils, left front and left rear are not working; fuses ok b) Heating coils of the oven are not working; fuses ok
  • josemagllane Sep 03, 2010
    Thanks a lot Silverdragon... with your comprehensive inputs, Ive gone deeper to the problem.
    It turned out that the infinite switches of left front, and left rear heating coils were badly pitted-off and contacts were erratic. So changed switches and the problem solved.
    Secondly, the thermostat that control the oven heating coils was likewise bad; no continuity on whatever position the knob was turned. So, changed thermostat and the problem solved too.
    Replacement parts (2 infinite switches and 1 thermostat) cost = $228. Its maybe sad but Im still glad to learn things from pros like you...
    Thanks again Silverdragon and more power...
    Josemag
  • Kenmore Master
  • 1,711 Answers
Your problem seemd to be from the very simple ones.
The first for both coils you need to replace the infinite switches, their internal contacts are damage by years of use.
For the oven is a similar problem but you have to replace thermostat knob for the same reason.
Thanks for using FIXYA and remember to vote Thumps up if you are satisfy
Posted on Sep 08, 2010
  • Kenmore Master
  • 12,061 Answers
Hi, well elements are very easy to test, you need a multimeter set to OHMS, now the elements should have a resistance equal to OHMS law for the Wattage.
EG: 3000 Watt element, Mains Voltage 120 V AC, therefore, to get the Resistance = First, we must use a two stage calculation, extract the Amps, from the Watts, (Formula, Watts divided by Voltage), then we divide the Voltage by the AMPS to get the Resistance in OHMS,
OK so, 3000 Watts, divide by the Voltage, 120 V AC, this then gives us, an answer in AMPS, of 25 AMPS.
Therefore we have 25 AMPS. Now using OHMS law, to find Resistance we must Divide the Voltage by the Current, that then equals, 4.8 OHMS. This is the resistance of a 3000 Watt element, This also factors up and down, so if the Voltage stays the same. 1000 Watt = 14.4 OHMS --- 5000 W = 2.88 OHMS. 10000 Watts = 1.44 OHMS.
As Resistance goes down, the Current & Wattage goes Up.
Right now you can measure your elements, to see if they are OK.
As related usually they go open circuit, if so, then with the mains ON, and the Element switch ON to FULL, we should have a Voltage across the terminals of the element itself, more or less the full 120 V AC. MEASURE VERY CAREFULLY.
Usually elements that do not work are Open circuit or a Very high resistance.
the only other place that we may have a problem is in the actual element controller itself.
For best DIY results one simply must get a service manual. find your one at this link below.
http://appliancejunk.com/forums/
Posted on Aug 30, 2010
My oven is on warming mode from last six hours. Please adivse
First, check the back of the oven. See if the lil red button can be pressed in. Then check the IR Element, usually you can see the wires burned or damaged where it enters the oven by the snap rings. This was a design flaw from the manufacturer of the element of which turbochef has taken care of.
COMPONENTS
IR Element
The IR element - a dual coil type heater - is located
in the bottom of the oven cavity. The first coil is the
heating coil. The second is the IR thermocouple
wire. The heating coil outputs 3000 watts at 208
VAC. The heating coil's resistance is 14.4 ohms at
room temperature.
The thermocouple coil is a Type K thermocouple
with a resistance of approximately 20 ohms at the
splices located approximately 6 inches from the
heater and 40 ohms measured at the extension wires
at the I/O control board.
The IR element is controlled via the K5 solid state
relay and the IR thermocouple via the I/O control
board.
Its typically an easy quick fix.
Nov 02, 2010 | TurboChef TORNADO Electric Oven
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
My Kenmore oven, model 790, displays and beeps the F10 Fault
June 8, 2010
Same thing happened to mine this morning....cut the circuit breaker for a hour....open oven and let it cool....
mine stopped, finally. Dont know if its a long term fix yet.. but at least it stopped the beeping.
May 06, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Nothing on the oven works, however the burners work on top, but when we turn the oven on nothing happens I even grabbed hold of the heating element in the stove and felt no heat or burn myself or anything
Check the thermal fuses / sensors mounted on the top exterior of the heating chamber and also the heating element. Both accessible from the rear of the oven. The element is most likely to have gone. It will be a 2 or 3 turn coil type with the fan mounted to the middle of it or a flat element with no fan. You will need to check the number of turns of the coiled element and also the mounting holes to ensure you get the right type. Turn off the mains power at the breaker or distribution point. You can get to the element behind the rear plate of the oven cavity by removing the side shelf slides, and rear panel by undoing the securing screws on the plate (2 or 4 depending on the exact model you have). Often a good idea to take a photo of the element mounting and take the model and serial no of the oven so that you can take this to the domestic appliance shop or email it to an online supplier to make sure that the element they supply is correct for your exact oven.
Nov 08, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
My Kenmore gas oven does not light.
Remove the oven Racks. Remove the oven base plate. Turn the oven on. You can then see the oven ignitor next to the oven burner. If the oven ignitor does not glow a bright orange,replace it. About a $90 part.
Oct 05, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Kenmore stove oven does not shut off
Wow, this post is going to be extremely late. Actually, I was able to get a new control unit for my Kenmore gas range from Sears Parts Dirext for $156.06. That includes shipping and tax. The burners work without it. We just cannot use the oven until the new board comes in. It's very easy to replace. Remove the panel screws on the back (just the top) and you have access to unplug the unit and remove the 4 screws holding the assembly in.
Jun 05, 2009 | Kenmore Ovens
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Dec 16, 2008 | Ovens
Kenmore Ultra Bake Oven Won't Heat Up
Turn the breakers off and wait 10 minutes and then on.  If this doesn't clear the problem, you'll need an electronic timer module.  Electrical spikes cause problems like this.
Nov 17, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Bottom Coil on Oven not Heating Up
yes it is most likely the element (coil) itself burnt out. inexpensive and easy to replace.
Jun 28, 2008 | Kenmore Ovens
Ovens Logo
119 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
