I wish to clean the head - Office Equipment & Supplies
    Problem Solver:
  • 15 Answers
If you remove the cartridges you will see a coper with fine pins sticking out. use alcohol or spirit on a cloth and rub the pins gently then use same process on the cartridge side were the pins meet.
Posted on May 13, 2008
  • 89 Answers
I am not sure what kind of printer you are talking about but if it's inkjets use rubbing alcohol and a lint free cloth.
Posted on May 09, 2008
Use a damp cloth just water, which should solve the problem.
Blurry colorwashed photos from canon pixma pro9000. What can I do to fix this?
Hi there, I located this video about removing the print head and cleaning it. I've had to clean my print head from time to time, so take a look at this video and see if it can give some help. Your printer might not look exactly the same, but you should be able to remove the print head. If cleaning the print head doesn't clean up the color issue, try contacting Cannon support: Canon Contact Us. I wish you best of luck!
-Mr. W
Feb 25, 2015 | Canon PIXMA Pro9000 Printer
Eats Tapes
Well I can tell you how to clean the heads but I doubt it will cure the tape chewing problem.
First you need a can of Servisol Video 40. You can get this from electronic shops such as Maplin (UK) or Radio Shack (USA). Amazon and e-bay also sell it.
Remove the top cover of the VCR. You can unplug it if you wish, but you might want to use it with the cover off later. You should be able to see the video head - the large cylinder. Spray the sides of the head with the Servisol. With a cotton bud wipe the sides of the head. The head should be shinny and clean when you have done. Now locate the other video heads. These will be square shaped with wires coming out of them. They will have shinny surfaces too. Spray the shinny surface and wipe with a bud. You might also want to clean the rubber roller, simply spray and wipe. It's a good idea to clean all the surfaces the tape touches. If you don't know which, watch the tape playing when you first take the lid off. If you watch the tape playing it will show you which part is chewing the tape. Often it's caused by the rubber roller which is worn.
Allow the Servisol to dry before putting any tape in. It will dry very quick. If spots appear on the picture, then clean again.
Mar 22, 2014 | Sharp VC-H810U VHS VCR
How to clean canon iX5000 print heads print nozzles etc ive got white lines appearing in the prints
Hi, Try first with cleaning tests on maintenance mode.Make sure all cartridges are not empty.If not help try manually cleaning.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If this not help you need to replace the print head. Thank you for your time and best wishes for your effort.
Jan 06, 2011 | Canon PIXMA iP5000 InkJet Photo Printer
My printer prints blank pages. I've already cleaned heads. unplugged it, restarted it and even reinstalled it. It still does not work.What should I do now?
Lost electricity to head micropiezo. Take to epson service centre for replacing board and fix short circuit at head. If you wish to reapir yourself, find similar solution on aicaxz solution.
May 24, 2010 | Epson Stylus CX7800 All-In-One InkJet...
Problem with cleaning heads on Epson Stylus R290
Hi, enter the set up, scroll down to maintenance, click on the maintenance, different options will pop up, click on cleaning the cartridge head and make sure you also align the cartridge after cleaning the head, the alignment is under the maintenance option.
I wish you best of luck.
Jan 07, 2010 | Epson Stylus R290 InkJet Printer
I would like to clean the print heads on my Epson Workforce 500 but don't know how to get the print heads out?
Hi, enter the printer set up, scroll down to maintenance,under this, you will see clean cartridges, click on this and you have the printer head clean.
You can also check the user manual if you can get something like that.
Jan 06, 2010 | Office Equipment & Supplies
My printer prints blured letters
Hi, have you clean the printer head, if yes, have you done maintenance check on it, because all this will help put your printer in good post, if yes, i suggest you change the printer head for effective performance.
Jan 04, 2010 | HP DeskJet F380 All-In-One Printer
In print test, seems some nozzels of the black print head are clogged. how can I clean them? I understand the ink cartridge and the print head are seperate. so how to get and disassembled the head and with...
You need to dissasembly the hole printer to take out the print head.In case you wish to do this don't use alcohol. Use hot water or some degreaser.
Principle from Brother claim in genuine cartridge have a unclogged preparation.If you don't use a genuine cartridge buy one black, put it on printer, start cleaning and wait for one day.The nozzle will unclogged, but this is not 100% sure.
Oct 19, 2009 | Brother MFC-5440CN All-In-One InkJet...
Pixma IP4000 Printer
OK, Canon will hate me for posting this!!!!!
Remove cartridges.
Remove print head.
Go to sink or tub (stianless steel, not pastic type), pick up roll of paper towel on the way.
Fold several layers of paper towel and place on flat surface.
Run HOT water till HOT.
Turn hot water to dribble.
Run hot water through print head, careful not to wet contacts.
When water is clear coming through print head, place print head on paper towel.
Repeat process until no colour on paper towel.
DAB print head (DO NOT WIPE) inside and out to dry.
You may wish to let print head air dry overnight but I replace it after drying.
Replace print head in printer and replace cartridges.
Start printing again
I do this on all my Canon printrs every 6 months
Jun 30, 2008 | Office Equipment & Supplies
Canon I470D not printing
may be your cartridge is empty or try out head cleaning to run the flow of ink into the new head.wish u success!
Jun 04, 2008 | Office Equipment & Supplies
160 people viewed this question
k24674
jasbo
jasbo
