Question about Nikon D70s Digital Camera
Flash wont close is there an adjustment - Nikon D70s Digital Camera
    Scholar:
  • 170 Answers
In a D-SLR, the flash does not close automatically. You have to push it down.
Posted on Aug 30, 2010
3/4 hp Craftsman garage door going back up when closing.what shiuld i do?
If it completely closes and then goes back up and the lights are NOT flashing adjust the down limits (its going down to far). If the lights flash repeatedly then something is tripping the safety sensors. Finally if its going almost all the way down and then comes back up adjust your down force.
Oct 30, 2016 | Building Materials
Oven door wont close properly chef gbc5266wng
Wow Must be a very old oven. The closes model number I can get is GBC26CK. But most hinges have no adjustment to them. They just need to be changed out.
http://www.on-timeapplianceplano.com
Jul 23, 2012 | Kitchen Ranges
Start light flashing. Unable to adjust
water not entering machine start light flashing and alarm sounds
Nov 13, 2010 | Tecnik TDW2677 Built-in Dishwasher
03 Jeep Liberty Sport sunroof wont close.
03 Jeep Liberty sunroof wont close. I have 4 sunroof buttons; Open, Close, Vent and ASC. Open and Vent buttons are working fine. Close button is not responding. ASC button is flashing red and green but does nothing when pushed. I have no way to get it closed
May 08, 2010 | 2003 Jeep Liberty
I think something blocked my door from closing properly as there was water on the floor now the green light is permantly flashing and wont work.
I am not familiar with that make of machine but most machines have an adjustable door lock latch, often they are only secured by a single screw and if this has become loose it may cause your door not to seal tightly and in turn leak. As for the green light it may have a sensor connected to the door latch to indicate it is not properly shut. Try checking the door latch, Adjusting and re-tightning screws.
Nov 04, 2009 | Indesit 24 in. IDL700 Built-In Dishwasher
All of a sudden our garage door stopped working and the light flashes 10 times. Liftmaster Model 2265 1/2HP. Any ideas?
We just had the same problem this morning (cold weather can mess these things up). Not sure what you mean by "not working". Ours would open part-way and then stop (or close part-way and then stop), but could open/close all the way if we held the button on the wall down the entire time it was lifting. After much research online, we ended up checking the sensors at the bottom of the garage door tracks to make sure that the green light was solid (not flashing). Ours flashed a bit, so we cleaned the "eye" and tightened it in place. Once the green was solid, we thought we were done, but still had the problem.
Then we began adjusting the screws on the unit itself that show pictures of the door opening and closing. We thought we were adjusting the torque in the unit (because we read online that cold weather can make it more difficult for the motor to work), but in reality we were adjusting the opening and closing "distance". Apparently cold weather can also do something to the tracks, which can require adjustments to be made. Something to do with ground swelling...
Anyway, we also discovered that when we had closed the door manually (red pull-cord) the night before for lack of a better solution, it never properly locked back into position, which was adding to the problem.
So, first, try cleaning the sensors. You need a solid green light for them to function properly. Second, if you have used the manual cord, make sure the arm that it attaches to is locked back into position. You can accomplish this by pulling the manual cord, manually closing the garage, and then pushing the button on the wall. The door arm should lock into place. Third, try using a screwdriver to adjust the open/close distance. Start with a 1/4 turn for each position, and play with it until you find the right setting.
If these suggestions don't address your problem, this link worked for us...http://forum.doityourself.com/doors-windows/368278-garage-door-wont-go-down-cold-weather.html
Oct 10, 2009 | Electrical Supplies
Rear trunk wont close, power trunk wont close mechanisms seem to be fine just wont latch
You can adjust the trunk lid by loosening the bolts at the hinges. If that wont work then there is a micro switch incorporated within the trunk latch. You will need to replace the entire latch unit unfortunatly.
May 16, 2009 | 2000 Volkswagen Beetle
Cannot get flash to fire in Macro mode
The manual says the flash range is 1' to 1.6 feet with setting the ISO speed to auto.
Feb 11, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Close Flash On Xti
Turn off the camera and remove the batteries. Then try to close the flash by pushing it down lightly. If it still won't remain closed, your camera is faulty and you should bring it back for a repair/replace.
Hope this helps,
/Chris
Jan 17, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Nikon D70s Digital Camera Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
