Question about Casio EXILIM ZOOM EX-Z60 Digital Camera
Won't autofocus - Casio EXILIM ZOOM EX-Z60 Digital Camera
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 30, 2010
While seeing through display area it shows blurred vision
Your camera has a feature called MF (Manual Focus) if it is switched to MF, the autofocus won\'t work. If on the right side of the screen is MF, you are sure the camera is in that mode. You can change that in Recording Menu 2.
The manual is still online.
Success
Jan 13, 2014 | Sanyo Xacti Cameras
Canon Rebel XSi won't autofocus and makes grinding sound
There is nothing that auto-focuses except the circuit in the body - all the motors, gears etc. are in the lenses. If this is a 18-55 lens then more than likely the long shaft gear has broken teeth - a very common problem.
Mar 30, 2013 | Canon Rebel Cameras
Aperture ring won't turn
When the camera is set to autofocus, let the camera do the focusing. If you want to focus manually, turn off the autofocus so you can turn the focusing ring.
Sep 30, 2012 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Why wont my Nikon af nikkor 70-300mm G lens autofocus its self with my D5000 camera
The D5000 does not have a focus motor in the body, relying on the lens to have one. The old 70-300mm G lens does not have a focus motor, relying on the camera to have one. Thus, this combination will not autofocus.
The newer 70-300mm AF-S G lens, as well as the even newer 70-300mm VR AF-S lens, do have the autofocus motor and thus will autofocus on the D5000.
Dec 26, 2011 | Nikon AF 70-300mm f/4-5.6 G Nikkor Lens
The auto focus does not work properly with this lens on either my Nikon D5000 or D7000. I have tried all possible combinations of AF settings. Typicaly, when I use single point to focus, the subject I...
Hi, It wouldn't autofocus on the D5000 as the body doesn't have an auto focus motor in the body and since that lens is AF, not AF-S, it won't autofocus. It should autofocus on the D7000 though, how far away are you from the object you're trying to photograph?
Aug 28, 2011 | Tamron SP AF 17-50mm f/2.8 XR Di II LD...
Hi there. i have D7000 with 50mm F1.8D. what would be the best camera setting for in-house and outdoor photography?
That would depend on a lot of factors. Are you doing the outdoor photography in the day or at night? Are you doing the indoor photography in the day or at night? With just existing light or with aritificial light? What do you want the photos to say to the viewer?
I'm going to go out on a limb and assume you want to take pictures for real estate sales purposes. If not, please reply to this post and say what you want the photos for.
Outdoors, I'd just put the camera into the Program (P) exposure mode. Since the house and shrubbery aren't going to be moving very fast, the autofocus setting doesn't matter much (just make sure it is set to one of the autofocus modes, not manual). Leave the white balance on auto.
Indoor, if there's enough daylight coming in through the windows, go with Program exposure, any autofocus, and auto white balance. If you have to use floodlights, set the white balance to match the floods. The camera's built-in flash won't evely illuminate a room (nearer stuff will be much brighter than the farther stuff), so don't use it. You can use an external flash with a diffuser or bounced off the ceiling or a wall.
Aug 20, 2011 | Nikon Normal AF Nikkor 50mm f/1.8D...
Will polaroid 52mm lens filters fit my panasonic fz45 camera
Your FZ45 accepts 52mm filters. You can use any 52mm filters you wish on this lens.
There are two types of polarizing filters: linear and circular. The linear polarizing filters are for film cameras and *some* digital cameras. Circular polarizing filters are needed by many digital cameras because the linear polarizing filter types interfere with the autofocus programs. If you shoot in manual focus modes only, it won't matter which you buy. If you do use autofocus, you ought to try the linear before buying - otherwise, purchase the circular polarizer.
I hope this helps! If it did, please rate my reply "4 thumbs up". Thanks!
Aug 01, 2011 | Cameras
Can i use my 500mm mirror lens with my EOS Rebel?
Assuming the lens has a Canon mount, yes. You won't get autofocus, of course, and metering probably won't work, forcing you to set the exposure manually.
May 31, 2011 | Cameras
Casio EXILIM ZOOM EX-Z60 Digital Camera Logo
255 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
