Question about Samsung LN-T4671F 46 in. LCD Television
Hi. it takes about 1 minute to turn it on. - Samsung LN-T4671F 46 in. LCD Television
  • saveliev Aug 30, 2010
    Do you know how much it would be to fix it professioanally or where can I get these capacitors myself. Thank you.
    very helpful. thank you
  • Samsung Master
  • 12,061 Answers
Hi, well this usually indicates a Power Supply problem, usually a Capacitor, (Or similarly affected component) which is a high Resistance at first, as the current flow through the capacitor, it breaks down, and temporarily "Heals" then it starts to behave as it should, then when turned OFF the current leaks out, and it returns to it's high resistance state and thus the whole process is to be repeated, this will occur until that or something driving or being driven by, fails completely.
you really must obtain a service manual if you wish to DIY.
I have searched but was unable to find your exact one, however i have included a training manual, right at bottom, this is what is used to train the engineers on these sets and gives valuable insight into how they work and what to do.
It is my professional opinion, though, that everyone should take their units to their manufacturers approved service center, contacting a head office, of your units manufacturer, Samsung, in your case, & getting an approved service center is just SO important, even worth the extra to ship it, you see, at those places, the Engineers, are trained on the equipment you have, they usually have parts on hand, and do the job quicker. Anyway do that and get a "Quote". from them before allowing any work to commence. This way, at least, you'll know weather to repair or replace.
http://www.scribd.com/doc/26351010/Samsung-Lcd-Lb350-650-Training-Book
Posted on Aug 30, 2010
  • 4,472 Answers
This is actually a fairly common occurrence with these samsung tv's. Most likely you have failing capacitors. If you take the back off the tv and inspect the boards for bulging/leaking capacitors you should find the culprit/s. Replace them if not all that are like them as well. This should fix your problem. If you need to find a local quality repair technician who can do the soldering.
Thank you,
Lee
  • Lee A.
    Lee A. Aug 30, 2010
    You can get the capacitors online you just have to know their values. As far as repair costs for a technician it all depends on a lot of factors. If you bring the tv in somewhere it could be like 50$-100$ or more. if/when you find this information helpful please take a moment to accept/rate it accordingly.
    Thank you,
    Lee
Code F5E5 after using self cleaning on KEBC107 Kitchenaid.
Hi, f5e5 stands for clean temperature not reached after 30 minutes. You should check your door gasket, hinges and you latch to make sure the door is sealing. You can take a piece of paper like a receipt and put it in the door and pull it out with the door closed to feel for resistance on the paper. If there is no resistance on the paper then the door is not sealing. you can try hitting the stop clear button for 3-6 seconds if that does not take the error code off then turn the breaker off for about 30 min.
In some instances, this could just be a glitch and a reset could be performed:
  • Press and hold any key for 1 minute to clear R failure code from memory.
  • F2 will appear.
  • Press CANCEL and observe for 1 minute to ensure operation is correct.
Nov 10, 2010 | KitchenAid KEBC107 Electric Single Oven
I have a hayward H400 serise propane heater. I replaced the gas valve. When it goes tot turn on it takes about a minute then starts clicking to ingnite the gas. SSoem time it lights but then goes out other...
0. Check the spark ignitor conection to the board
1. Check the water by-pass valve if you have it
2. Check your gas pressure. (5-7"wc for natural gas, 9-13"wc for propane gas)
3. Clean your filter for your water system or remove it and try again
4. Check the Hi-limits on your heater
5. Replace the thermostat
May 27, 2010 | Hayward H Series Pool & Spa Heater 400k...
My Samsung LCD TV takes 1 minute to turn on with purple spots
could be the power supply board (most likely) or the main board.
Nov 17, 2009 | Televison & Video
My hhr
your security system has locked u out, try this procedure, 1st lock and unlock the driver door with the key, then follow these instructions.
PASSKEY LOCKOUT RESET GM CARS 1999 UP
1) Put the key in the ignition and turn to the "ON" position. Leave it that way for 10 minutes. After 10 minutes turn the key and take it out. Repeat this process (2) more times (3 times, 30 minutes total) This should reset the PASSKEY system to recognize your key
Sep 10, 2009 | 2006 Chevrolet HHR
Camera turns on with a bit of a tremble but shutter locks
I have an 5D with the same problem, It looks like the Anti shake does not initialize properly, The only bypass I found that worked (except for a real repair) is to set the display light timeout for 5 seconds, The standby timout for 1 minute, Turn the camera off, and on again, Wait for 5 sec then the display goes blank, wait for 1 minute then the camera goes in standby, (light from CF card flashed red 1 time) Then touch any button to re-activate the camera and... voila... everything works, including taking normal pictures and the anti-shake !!! So it only takes a minute everytime to startup..
Jun 05, 2009 | Konica Minolta Maxxum 7D / Dynax 7D...
Boot problem thinkpad r50e
Your PC may be doing a complete memory check, this does take time although your 1 minute boot time might make some of us jealous.
Check your BIOS settings to see if you have a 'Fast Boot' option. If it does, make sure you are using it. It then will make only a cursory check of memory and it is probably OK otherwise you would have other symptoms that would let you know.
Dec 31, 2008 | IBM ThinkPad T40 2379 Notebook
Tv unexpectedly powers off
Hi i has the same probleme..... My tv has 1 years and 6month... since two days.... the tv turn off itself...I have just take 15minute, unplug tv, and i have open in the right side the little panel...And i have clean inside!!! And i have do the same thing with the big panel in the back of the TV...After i have clean the fan...After this clean my tv is number one... and nothing turn off
Apr 21, 2008 | Toshiba 42HM66 42" Projection HDTV
Takes about 5 minutes for picture to appear... Then every one to two minutes the picture disappears. It comes back on for 1 - 2 minutes then repeats. When set if first turned on, the stereo/stand-by...
Takes about 5 minutes for picture to appear... Then every one to two minutes the picture disappears. It comes back on for 1 - 2 minutes then repeats. When set if first turned on, the stereo/stand-by light (red) flashes on/off until just before picture first appears .if your tv is very old than it might be due to crt getting weak crt base loose loose contact in power supply thanks
Sep 09, 2007 | Sony KV-32S12 32" TV
Everything freezes with a red light after I take a picture
Hi
I had simular prob,,
ended up it was my batt
got new 1 on e-bay camera fine now
May 29, 2007 | Vivitar ViviCam 4000 Digital Camera
Samsung LN-T4671F 46 in. LCD Television Logo
378 people viewed this question
Jerry Greenberg
Jerry Greenberg
