Question about Weather King Heating & Cooling
I live in a condo and have a central air/heating unit in my kitchen/hallway area. This past week, right before it turns on, I hear a very loud bang. It sounds like it is coming from inside the unit. It seems to be working properly though. It is from August, 2008. What could this be and is it dangerous?
  • 32 Answers
Might need to change the filter could be pulling it aganst the frame when turning on hard to say, have it checked out if you are worried it is dangerious.
Posted on Aug 30, 2010
What causes a loud bang from oven?
If you hear a loud bang the SECOND time you try to light an oven, it means you've just had a small explosion when the gas from the FIRST try ignited outside the heating tube. I would have a professional check your oven before using it again.
Jul 18, 2014 | GE Spectra JGBP35 Gas Kitchen Range
Placed in bedroom to heat large hall, office,dinning room, bathroom...making bedroom to hot
Placement of the heater is the problem. It needs to be in a more central location. Perhaps the hallway. That way, it heat has a more open area to travel and reach the areas you're trying to heat. Keep in mind though, it will always be hotter where the heater is located.
Be safe. Electric Space Heaters can start fires.
Mar 03, 2011 | Heating & Cooling
I have a fairly new GE Zoneline heating unit, and live in New England. This past winter, the unit has become VERY noisy, with loud vibrations, crackling noises and a fan that sounds as if it is on its...
This unit only has a warranty for 1 year. Have you followed the use and car instructions? If your looking to get the unit fixed follow the support link below and use the contact number for ge located on the right side of that page:
http://www.geappliances.com/service_and_support/contact/
Thank you,
Lee
Feb 28, 2011 | GE Zoneline AZ38H12DAD Split System Air...
Heat pump stops working in cold weather
Sounds like there is a problem with your unit. The cooling tower doesn't have anything to do with the compressor other that the delivery of water to your heat pump. The compressor is probably shutting off on a low pressure because the water is cooler than in summer. I think the heat pump you have is low on charge or has a defunct TXV.
Jan 11, 2010 | Weather King 12AJA4801AH Air Conditioner
My Amana (distinctions) central heat and air unit -loud noise
If this s an Oklahoma Tulsa area call. KOOL BREEZES 918 6878813 for a diagnostic check.
Dec 05, 2009 | Heating & Cooling
Central A/C unit has a leak
The air handler has either a drip pan with exit pipes on the side or a drain pipe and any of which could be clogged.. Find out were the water is supose to exit,, and at that end - tape a strong wet vac to suk out any clog or debris..
Rate well ;o)
Jul 22, 2009 | Heating & Cooling
No heat through vents
Does your condo have more than one thermostat? if so there are powered dampers that open and close to direct heat where it's being called for. You may have dampers stuck/inoperative.
Mar 22, 2009 | Omega Trane Furnace Draft Inducer Blower ...
Unbalanced cooling or heating
You need to balance the system. It's a matter of adjusting the dampers or registers so that you have a little less air flow near the T-stat and more to the other end of the house. Likely you have a return vent near the T-stat. That return draws air to it and likewise the T-stat. If you are getting a lot of air out of the registers on that end of the house damper them to force more air to the other end of the house. Do not close them entirely though. You may have to play with it a little to get it right. I hope this helps. Please remember to rate Fixya rate me.
Feb 23, 2009 | Ruud Central System Air Conditioner
Heating & Cooling Logo
Top Weather King Heating & Cooling Experts
Donni Steen
Tim Whalen
Brandon Berry
Brandon Berry
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
