Question about Canon PowerShot A430 Digital Camera
My memory card is locked. how do i unlock it?
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Aug 30, 2010
After locking memory card, do I then unlock it to take pictures and will that then erase the memory card or can you tell me how to so
Locking the memory card prevents you from taking and adding photos to the memory card. It also prevents you from deleting photos from the memory card.
If you want to erase all the photos off the memory card. unlock the memory card, go to the camera's Menu and scroll through the settings ti Format the memory card, then format the memory card.
Apr 10, 2013 | Cameras
My memory card is locked am not given lock number how to remove lock 2gb micro
Look closely at the memory card itself. There should be a tiny picture of a lock indicator on the card and a little tab to click or move to the lock position. There should also be a picture of an unlocked lock to signify which direction you need to move that little tab in order to unlock the memory card. Try sliding it to the unlock position to solve your issue.
Sep 12, 2011 | SanDisk 2GB microSD Memory Card
My micro sd card lock how can unlock micro sd card
Locked Memory card.
Note:- Locking of memory card is a RANDOM process.(means it gets locked on its(memory card) "OWN')
1.Whenever a card gets locked,its mainly due to the following reasons.
(I)When you insert it into a uncompatible mode.
(II) when some unsupporte files are placed.
(III)When its for specific mobile.
100% working solution for LOCKED MEMORY CARD is :-
1.Use Unlocker(its like a pendrive device with 9V battery ),and its IC is programmed in such a way that it tests every possile code.
2.The one that sets mades the memory card Unlock.
3.BUT you cant know what the CODE was.
4. Data can NEVER be retraced.
Noye :-Buy an Unlocker available @ Rs.200.But you may not get the same problem often so take it to the retailer it will costaround Rs.20 for unlocking .
Aug 29, 2011 | Nokia 5130 XpressMusic Red Unlocked Import...
The memory was lock. but i want to unlock it
id1102_e3sdhc.gifSOLUTION 1 - Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.
NOTE: If you are using a microSD/microSDHC card or a miniSD/miniSDHC card, insert the card into the standard SD adapter.
SOLUTION 2 - Toggle the lock switch.
If the lock switch is not on lock:
1. Slide the switch up and down. Repeat this 3 times.
2. Let it stay on the Lock position for 30 seconds.
3. Slide the switch up to unlock the card.
4. Try to transfer files into the device.
Dec 30, 2010 | SanDisk 4GB microSD High Capacity Memory...
My memory card suddenly says locked, why and how do I unlock it
Thanks for using Fixya.
(i) Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.9632f20.gif
(ii) Toggle the lock switch.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jun 06, 2010 | SanDisk 1GB microSD Memory Card
Unlock 1 GB micro sd memory card of Kingston Made
check the adapter maybe its switched to locked mode sanjan
Aug 17, 2008 | Nokia 5300 Grey Cellular Phone
Unlock memory card
There is a little 'lock' switch on the side on the card with a lock symbol. Slide the switch to the unlocked position to unlock your card!
Aug 06, 2008 | Cell Phones
Memory card locked
I had the same problem - just put the lock button of the card to the lock position and than again to the unlock position
Jul 06, 2008 | Canon PowerShot A450 Digital Camera
Canon PowerShot A430 Digital Camera Logo
207 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
