Question about Philips 50PF9731D/37 50 in. Plasma Television
Have a 50PL9126D/37 it all of a sudden will not come on ! The power button comes on blue and then justs keeps on flashing? No sound or picture? Is it worth fixing or junking ? Only 2 1/2 yrs old!
  • Philips Master
  • 17,130 Answers
Unless a good check up is called for we cannot decide on the estimation of the fault and cost.
Since there is a total failure of the pictture and sound , the blue light blinking to indicate a protection, shutting perhaps power to the main boards, the hunt must begin.
Within your reach check if any visible signs of capacitor leakage or being bumped up ontop to indicate a loss of electrolyte. If so replace these capacitors.
next look around for any dry soldering in the power board and teh main boards/the convergence boards. If so solder and check.
Finally test the voltages from the power supply and the protect from the mP board. check for the shut off voltage,and look for the shorting component, it can vary from a capacitor to the IC and to the driver.
If test indicates or a release of the shorted component resumes power, the suspect is centered.
If however the fault is around the IC then estimate , confirm before you order, as this is important.
Posted on Aug 30, 2010
My 50 inch Phillips tv model #50PL9220D/37 wont turn on? blue power light is just flashing ? what could be the problem?
Hello more than likely the lamp has gone bad. On that set you have to remove the back cover to check the lamp to see if it has broken. the picture gives you an idea and some instructions on how to change it. tks7bef3142-61c4-4329-b27d-2507769a830c.jpg
Nov 04, 2013 | Philips 50PL9126D/37B 50" DLP TV
Xenius 37" lcd blue light just keeps flashing
my 37" xenius tv started losing its picture to a stripe screen then started flashing red blue green .know wont come on at all .wht part do i need to fix it please
Aug 07, 2012 | Televison & Video
I own a 50PL9126D/37 50 in DLP TV I bought used and the picture is dark so I took it apart because I was told it could be dusty or could be the lamp. After I cleaned the inside screen VERY carefully with a...
Dlp tvs have dark pictures,first thing u must be alway change the tv projection lamp.Specially,if u bought used,because u don't know how long the projection lamp been inside that tv already.After u change the projection lamp,still have problems or hear alots of clickings sound too.This problems the board call the Ballast board is it dead too.This Ballast board only job are just to ignite the tv projection lamp only.
Jun 08, 2011 | Philips 50PL9126D/37B 50" DLP TV
I have a Philips model number 50PL9220D/37 and it turns off after about 30 seconds and a red light on the left hand side of the power button comes on. Not sure what to do.
I have a Philips model Problem with the Philips 50PL9126D/37B 50 in. HDTV DLP TV I have a Philips model number 50PL9220D/37 and it turns off after about 30 seconds and a red light on the left hand side of the power button comes on. Not sure what to do.
Apr 22, 2011 | Philips 50PL9126D/37B 50" DLP TV
Philips Model 50PL9126D\37 Turn TV on and after a
Ur LCD inverter board is dead,must change to get ur picture back.It usally a long board.
Jan 21, 2010 | Televison & Video
I have a Phillips 50pl9126d/37 it wont turn on picture or sound blue light in the front flashes 6 times fast looked at the bulb and it doesnt seem broken ie( no glass bits inside broken off) otherwise...
I currently have this problem also. However my TV is blinking 6 times fast and then 5 times slowly. I was told by a TV repairman that it was in fact the bulb or lamp. I plan to replace it, soon, I will keep you posted hopfully it works.
Dec 11, 2009 | Philips 50PL9126D/37B 50" DLP TV
50 inch phillips hdtv model:50pl9126d/37, no picture...
Unplug for one hour then plug back in---worked for me--computer resets
Mar 18, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Philips TV, Model # 50PL9126D/37
Check to make sure all the ventilation opening on the tv arent plugged. if not, then you will have to make sure all the fans inside the tv are working properly.
Sep 23, 2007 | Televison & Video
Philips 50PF9731D/37 50 in. Plasma Television Logo
115 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
