Question about GE 25.2 cu. ft. Side-by-Side Refrigerator with Dispenser TFX25ARBWW
Ice chute frosts up?? - GE 25.2 cu. ft. Side-by-Side Refrigerator with Dispenser TFX25ARBWW
  • GE Master
  • 1,606 Answers
This is caused by a rusted plunger and solenoid . To replace them ( in a kit pt # WR62X10055 ) , remove the top plastic hinge cover of the freezer door , and disconnect the plug there . This removes power to the door . Use a small screwdriver or butter knife , under the dispenser control panel , and pry outward . Disconnect the 3 plugs . Remove the 4 screws on each corner of the white dispenser switch body , and slide foreward . The solenoid and plunger are at the top right , held on by 3 screws . Replace with the kit . Cleaning the plunger will not help . The kit needs to be replaced . ( note .. when reinstalling the white switch holder , it slides back in , on a slight track , so the dispenser board will pop back in flush . When re-installing the dispenser board , put the top in first , then pop the bottom back in place ) . Don't forget to plug the door back in .
Posted on Aug 30, 2010
  • 33 Answers
Check the door gasket. if the door does not seal well it will leat the warm air in and the condensate will freeze in the ice box and chute. also check the flap at bottom of the chute. they get broken stuck or lost and allow warm air in to the chute witch freezes the condensate and frosts the chute. good luck!
Is it safe for ice makers?
No of it frost up you most likes have an air leak around the chute area...check the seals...good luck
Jun 24, 2015 | Samsung Refrigerators
Ice sticing in ice dispenser chute
only use ice from the ice maker, some frost is normal, but , lower temp in freezer
May 19, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice dispenser frost build up - Amana refrigirator
This sounds like your ice may be melting and freezing around the chute. You may need to replace that rubber gasket on the chute. Otherwise, if you use a lot of crushed ice, that will build up badly on the chute and you can manually clean that off. I hope this helps you!
Aug 14, 2009 | Amana 25.8 cu. ft. Side-by-Side...
GE Profile 26.6 cu. ft. side by side is frosting in the shoot
Oddly enough, the problem is with your ice dispenser. What happens is that the door at the bottom of the ice chute is probably not sealed. This is likely because there is a solenoid that is supposed to hold that door open when you push your cup against the dispenser arm, and THEN, close it again when you release. If the chute door is not sealed, warmer, moist air from outside the refridgerator will be canstantly drawn up the chute where the moisture will freeze as frost. Gradually, this frost builds up in the chute until there is no longer enough room foir the ice to fall. You can usually look up at the chute from outside and see that the door is not sealed. In my case, I left it unsealed because the door would not open to let the ice out. It took me about 3 months to figure out that this was causing my frost-clogging problem. The solution is to replace the solenoid that is supposed to open and close the chuite door. If you remove the despenser panel, you will see that this solenoid is probably all rusted up and not working. The following link will allow you to enter you model number and see a diagram of the offending area. http://www.pcappliancerepair.com/model-display.php
Jun 10, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Whirlpool side by side ice maker freezes up. can't get ice out of
Can you give more details?
If the ice chute is frosting up, chute door is not sealing, air , with moisture, is getting in and freezing. An ice cube getting trapped by the door will cause this also. Either case, replace door and delay mechanism.
May 01, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice dispenser chute
most flaps have a solinard that opens and closes the flap,if you can replace or get in there to lube it you should me ok,let me know more-mike
Sep 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Sep 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
Ice maker frosts over on the chute
This would indicate a problem with the ice chute door seal. Have it serviced. Air leakage would cause the frost-ice buildup.
Jun 01, 2008 | Whirlpool ED2FHSS Side by Side...
Ice Jam in Chute - Whirlpool IDI SxS
first check would be to see if the flapper door is closing all the way in the dispenser area. best way is to remove the ice bucket and shine a flashlight from the front up into the disp door area and look for light around the door from inside the chute.
another check would be to make sure the door delay mechanism is connected an not allowing the dispenser door to close to fast trapping a cubes in the door and causing an air leak in the chute..
Keep in mind if you use alot of crushed ice frost build up is faster than with just cubed.
Dec 10, 2007 | Whirlpool ED2FHEXN Side by Side...
Bottom of ice maker/dispenser frosting over
Open the freezer door and look down the ice chute while you shine a flashlite up the dispenser cute from the outside. If you see light around the chute door, it needs to be replaced or something is wrong with the mechanism. The problem you describe is almost always air leakage around that flap.
Post back if you need more help.
Nov 17, 2007 | Whirlpool GC5SHEXNS Side by Side...
Refrigerators Logo
215 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
