Question about Car Audio & Video
Kenwood cd reciever model 241-Sa, fitted by halfords, am receprion very poor, interferance. What do I do? Thanks
    Novelist:
  • 150 Answers
1) The most likely cause of bad AM reception is a bad antenna
or a broken antenna cable, somewhere behind the dash.
Because FM is roughly 100x the frequency of AM, it requires
a much less efficient antenna, and the signal tends to jump over
small wire gaps or breaks.
2) The next likely problem is the reception area. AM is much less penetrating than FM, but it does go around things like
buildings, while FM tends to reflect off of them causing nodal
interference. AM also goes beyond the horizon, FM does not.
FM may work underground and in garages, on the other hand,
and AM may not. AM reflects from the ionosphere and travels
great distances at night, FM does not.
but
AM is much more sensitive to atmospheric noise, electrical
noise, thunder storms, ignition noise ... etc, and AM sound
quality is by design much lower.
3) Make sure that your antenna is rated for both AM and FM,
some are not. Theoretically, a simple antenna needs to
at least 1/4 wavelength long at the receiving frequency.
While this theoretical distance represents around 3 ft at FM
frequencies, it is hundreds of feet for AM. Because such a
large antenna is not practical for cars or portable radios,
other technology is required to make up for this.
3) Many car radios have a tuning capacitor on the back, which
could be mis-adjusted. This capacitor makes the antenna
look much longer, than it actually is in an electrical sense.
4) When you say the radio gets interference, is this cackle
and hiss like a weak station, or are you getting motor
ignition noise, ie. clicks at low RPM ==> annoying
whine at high RPM ?
This would be caused by the car or by poor installation,
not by the radio itself.
How does the radio work with the motor turned off?
5) The radio itself could of course be also defective, because
the AM and FM parts are totally separate and different. This
could be due anything from internal mis-alignment of the
mixer and IF stages, to a cracked circuit board or a bad
chip or transistor.
Martin
Posted on May 22, 2008
    Genius:
  • 1,224 Answers
You need to buy a regular car antenna or replace the one you have
but also this model number is not listed in kenwoods mauals i have
please check model number so that i can find your device and give you proper help
Posted on May 09, 2008
Is it a VW AUDI Ford Gallaxy? with the aerial inbeded in the glass or a bee sting on the roof?
You may need a power antenna feed. part# PC5-90
or if your car has a electric aerial is it working?
or is your fixed aerial damaged?
Modern AM reception is usually quite bad. We are used to the high quality sound from other formats and FM, AM has a very compressed frequency range so will always sound poor in comparison. The interference could be due to poor earthing or suppression on the electrical equipment in the car. Usual suspects are ignition, wiper motors and fans. A suppressor between the +V and earth usually help, fitted as close to each device as possible. The devices causing the interference can be pin pointed by turning one electrical item on at a time and seeing if it causes a problem. Another issue is that a lot of modern vehicles use the rear screen demister as an aerial, which can cause bad reception and interference. An external aerial is always best.
Kenwood KDC 241 SA car radio 'Protect'.
you could have a shorted speaker wire, a blown speaker; or the output ic in the deck itself could be bad.
Mar 03, 2010 | Car Audio & Video
HALFORDS JUST CAHNGED MY CAR BATTERY AND NOW I AM
here is a link on how to reset your kenwood radio using a universal code from kenwood, it doesn't work everytime, but worth trying. you do need a kenwood remote though..good luck
http://www.ehow.com/how_5164864_reset-kenwood-cd-player-code.html
Aug 12, 2009 | Kenwood KDC-W4534 CD Player
Instructions for Kenwood CD Receiver with USB Interface(car radio
CLICK HERE for a PDF version of your manual
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jul 04, 2009 | Kenwood Car Audio & Video
Have changed car have tuned radio /cd into new car but when radio or cd is playing it cuts out and call comes onto the screen every few minutes
hello i rang halfords where i bought my cd/radio and they suggested i have a look at the back of my radio in case any loose wires that were not connected to anything were touching the metal of the car and when my husband checked there were 2 so he isolated them and problem solved thanks. margo26
Jul 28, 2008 | Kenwood Car Audio & Video
Kenwood kdc-w4031 problems
How do I play dvd or vhs on my tv?
Mar 30, 2008 | Audio Players & Recorders
Sony cd changer cdx-646...no card remote commander to release security code
Hi the CDX-646 is not coded. it must be your head unit thats coded.what model is the head unit?
you can get your code @ www.carradiocode.co.uk
for 33.50 if its one of the models listed you will nedd the remote comander tho.
Mark
www.blueice-electronics.co.uk
Feb 24, 2008 | Sony CDX-646 10-Disc CD Changer
Wirering diagram for a kenwood cd reciever kdc-241sg
Buy car radio adapter(harness) from Best Buy, Circuit City.
atdlee@netzero.com
Feb 19, 2008 | Kenwood KDC-MP235 CD Player
Car Audio & Video Logo
153 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
