Question about Vacuums
Manual for seam master sewing machine model 301z
I need a free manual for a singer 4016 sewing machine
Try writing to Singer and asking for a manual for your model....or Google the Singer model and include 'manual'. I can direct you to Smith Corona; www.willrepairservice.com. for any part, manual or repair for an electric typewriter.
Nov 16, 2014 | SewShop.com Singer Model 4016 Instruction...
Can I get a manual for singer model 776 sewing machine?
try going to google and put in singer sewing machine and model number and it should pull up some sites
Jul 25, 2014 | SewShop.com Singer Model 776 Instruction...
My machine flashes C4 when i want to sew
Clean the bobbin case area thoroughly, and probably the feed dogs, too. Start all seams by holding the top and bobbin thread ends together behind the presser foot for the first few stitches. If you have lost your manual, pick up a new one, free, at http://www.singerco.com
Mar 21, 2014 | Singer 7256 Fashion Mate Sewing Machine
The reverse won't work on my singer 9018 sewing machine
STITCHING IN REVERSE
• To reinforce beginnings or ends of seams, push in
reverse lever
(1). Machine will straight stitch in
reverse for as long as you hold the lever in.
• For continuous reverse stitching, push lever in and
slide it to the left to lock. Unlock reverse lever by sliding
it back to the right and letting it return to its normal
position. if you need a manual let me know,,
Nov 25, 2012 | SewShop.com Singer Model 9018 Instruction...
What is the difference between a sewing machine and a serger?
Well..... A serger (or overlock) sews a different, and usually more complex stitch. Where a sewing machine usually only uses two threads to make the stitch, a serger can use two, three, four or even five threads and will sew around the edges of the work piece, as well as trimming the edge of the work just ahead of the sewing area, or as you feed the work in, the trimming takes place first. Sergers also make a stronger seam, attributable to more thread / stitching in the seam. Sergers are versatile and quick, but one drawback is the fact that sergers make a chain stitch instead of a lock stitch, like a machine with a bobbin, and lock stitches can be pulled out, like the stitching that used to close dog food bags and bags of charcoal. A lock stitch is just what it sounds like, it can't be pulled out. You only get a lock stitch with a machine that uses a bobbin, and sergers don't use bobbins. That fact makes serging desirable for the speed of production. Changing bobbins takes up a lot of time, even if you are using pre-wounds. Hope this helps!
Sep 10, 2011 | Vacuums
I have a vintage manual singer sewing machine and would like to view a manual
Do you have a model number on the Singer machine? Many Singer sewing machine manuals are available here: http://www.singerco.com/accessories/instruction-manuals . Enter the model number and click search. For example, the manual for the Singer 27 (made in ~1911) and 28 is here: http://www.singerco.com/uploads/download/268_27_28.pdf .
I hope this helps.
Jun 25, 2011 | Singer Vacuums
How to get Brother sewing machine apart to replace spool spindle.
To be honest the best thingon such instructions is the manual which is provided along with the machines,but many people don't have it , probably because they have lost the manual orthey have got the machine as a used one and forgot to take the manual alongwith it.
Please follow the belowinstructions :-
Close to the end of theHandwheel , there is usually a spindle, at the back of the machine.
This is where you need to restthe spool on and you would notice it sitting perfectly.
In case the length of the spindleis less , then pull it up gently with your fingers.
Also there are machines these dayswhich have easy to replace facilities , so the spindles just slide intothe machine for safety norms when you put the machine away.
Therefore , all you need to do it pullit up and it would be fine.
An example of a manual forbrother's sewing machine can be found in the below link which would give you anidea of how exactly it's done.
http://bit.ly/j2BdsP
Hope this helps ..:)
Jun 11, 2011 | Vacuums
I need a manuel for my sewing machine . it's the sophia model
Sophia Model sewing machines are made by the company Babylock. If you got to there website (www.babylock.com) you can look in the yellow tabs across the top of the page where you will find the downloads tab. Hold your mouse of this tab then scroll down to the manuals section. There you will find the manual for a Sophia Model Babylock sewing machine. Hope this helps.
May 06, 2011 | Vacuums
Vacuums Logo
71 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
