Question about Magellan RoadMate™ 1212 Car GPS Receiver
My Magellan 1212 won't even power up using the car charger, what can I do?
There is a reset button...you need to take a ballpoint pin and push the button in for a few seconds...it should power on
Posted on Sep 15, 2010
I was having problems with the car charger CA-051, then, I used a T-Mobile charger, at first time worked, after that, the GPS Maagellan was dead. Is it possible that I have to order a new battery? or I...
Using non standard chargers is probably the problem. If the battery has suddenly become sogged since using this charger then it may have done more damage than you want to know about.
Was it the correct polarity +ve Tip? was it the right amperage?
Magellan are specific in recommending you only use their charger and with reason, its correctly made for it.
You can try the new battery angle, but get advice on the charger.
As a small note.. Car chargers do NOT fully recharge batteries in GPS. Use an AC or USB charger. The car charger is a maintenance power supply. Always fully charge the unit prior to use and do not plug to car power until engine has been started.
These are standard rules with all non hard wired GPS and phones, ( but not always in the manual, have to have service and new sales someway!)
Please rate my help++++Thanks for using FIXYA
Aug 11, 2010 | Magellan RoadMate™ 1212 Car GPS Receiver
I need a manual for my magellan roadmaster 1212
You can view and download the instruction manual in PDF format by clicking this link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Thanks for using FixYa.
Jul 19, 2010 | Magellan Roadmate 1200 Car GPS Receiver
Broken screen Magellan roadmate 1212
Hi.
It is actually much cheaper to buy a new unit than to repair it.
It cost around $150 and above, depends on how crack it is and what model of magellan you're using.
Jun 09, 2010 | Magellan RoadMate™ 1212 Car GPS Receiver
Magellan 1212
With Magellan? You want free updates? If Magellan doesn't offer them then you are out of luck. At least on the legal software end of things. That's all I'm saying about that
Mar 31, 2010 | Magellan RoadMate™ 1212 Car GPS Receiver
My magellan roadmate 1212 will not stay on unless plugged into
if its not charging the battery, the meter will say full even though the battery is dead..its a very common problem with alot of gps with the usb as a charging port. my solution is if this is still under warranty, i would send it back to magellan or where ever you bought it, because sooner or later the usb port is going to totally fail and wont even start up if plugged in and your going to be left with an expensive paper weight.
Jul 29, 2009 | Magellan RoadMate™ 1212 Car GPS Receiver
Missing SD Map Card on Magellan Roadmate 1212
Unfortunately even if you do find a card it will not work with your unit because the cards have to be for that unit.If it is from another unit the codes will not allow it to work. The only option I know of is to purchase your map for that unit and put it on a sd card
May 09, 2009 | Magellan RoadMate™ 1212 Car GPS Receiver
Magellan Roadmate 1212 won't stay on when unplugged
Man, I DO commiserate with you on that one, but did you specify to them that the battery should be checked?
as that is probably your problem, now that I know the unit has been checked and the worst possible outcome
from your buying an extra battery is that you will HAVE AN EXTRA BATTERY for those times when you need
total portability.
So, make sure you try a brand new battery and if that solves your problem, then buy several.
Apr 17, 2009 | Magellan RoadMate™ 1212 Car GPS Receiver
Press MENU then select USER OPTIONS the select SYSTEM SETTINGS then select POWER then select NEVER. This will never let the GPS sleep.
Oct 18, 2008 | Magellan RoadMate™ 1212 Car GPS Receiver
Magellan RoadMate™ 1212 Car GPS Receiver Logo
85 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
