Question about Bosch HBL 755 Stainless Steel Electric Double Oven
Our hbl755 bosch double oven won't turn off. The upper oven looks like one of the elements will continue to heat even when there is nothing telling it to do so. Unplugging the unit is the only way to turn it off now. I have removed the front panel and disconnect a couple of relays but unsure what relay controls what element or what tells the relays to turn on.
  • 2 more comments
  • foxislandsol Aug 30, 2010
    The link shows product brocures but not service manuals for troubleshooting. Do you have a link to troubleshoot the specific relay or replacement part that would be causing the problem? Its a HBL755
    I am capable of testing with a volt meter and am familiar to what a relay does. I have a wiring diagram that came with the unit. I just don't know what relay is making the inner element on the top oven stay on. There looks to be a relay that is not being used.
    thats the wrong unit. Its a HBL755
    A wiring diagram came with the unit and it shows the Upper element in the top oven is relay K9. There is no K9 on the power board. I need to find out if it is the power board, relay board, or the relay board in the facia.
  • Bosch Master
  • 43,501 Answers
The problem with relays welding togetheris not a new one...they are too light for the load on them...after arcing many times to start and stop the element they weld together...
To find the right one look at the wiring schematic and follow thw wires... it would be best to check the relay with an OHM meter to confrim it is bad... in fact by using an OHM meter it would not take long to find the bad one...
You can buy a cheap OHM meter at Walmart for around 20 bucks...
Heatman101
Posted on Aug 30, 2010
    President:
  • 1,070 Answers
Welcome to FixYa
Dear User
Check the oven thermostat for continuity in "off" position. If the circuit is closed then the thermostat is bad.
Here is the Breakdown Diagrams click here..Hope you got it..Thanks for connecting FixYa...
  • Bosch Master
  • 12,061 Answers
Hi, well the only thing that can cause this is a shorted controller switch, or a faulty controller, sometimes it can be the thermostat, jammed on,or even a jammed relay, or relay driver.
However to have even a remote chance of a DIY repair one simply MUST obtain a service manual, this shows you how to troubleshoot and isolate a problem for repair. As many Symptoms may have widely differing Causes.
As a professional, I always advice that one should seek a professional, usually it ends up actually being fixed, and cheaper in the long run. Plus there is NO chance of electrocution.
below is your Bosch service link, you can get a manual from here or arrange for a service call.
http://www.bosch-home.com/us/bosch/customer-care.html
Bosch HBN7052 - main fuse tripping even after replacing the heating element
It appears there is too much current (electricity) being drawn towards the element, seeing once you replaced it, it worked fine for 5 minutes and then tripped again...I believe the problems lies within the wiring going towards the element, or the thermostat that controls the amount of current coming towards the element. Instead of turning off at a desired temperature, its not and continuing to heat up to the point of tripping the fuse. Try replacing the thermostat.
Dec 01, 2013 | Bosch Ovens
Tip
Common heating faults with Bosch HBL 5052 double oven
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Bosch fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the BOSCH element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your BOSCH fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your BOSCH oven thermostat
4, A quite common and easily overlooked answer is if your BOSCH oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Bosch HBL 5052 Electric Double Oven
Tip
Common heating faults with Bosch HBL 5056 double oven
on Jan 19, 2010 | Bosch HBL 5056 Electric Double Oven
The broil unit in the upper oven of a GE double oven does not work. The heating unit has continuity, 17.5 ohms, when connected, but that should be the resistance of the unit itself with all switches off....
the broil element doesn't get 240 volts,it's 120.also you should have the oven unplugged,pull out the element and read it out or at least one wire has to be removed from the part you're checking for continuity
Oct 02, 2010 | GE Ovens
In the upper oven, the lower heating element started sparking when turned on, and now it looks like it has a 'bubbled' area (about inch long) on it and it looks bent on one area. I guess I need to...
Hi, Yes, that element is toast...
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Sep 20, 2010 | GE JKP27 Electric Double Oven
My HBL452 double oven is slow to heat both upper
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Dec 01, 2009 | Bosch HBN 452 / HBN 456 Electric Double...
Oven will not turn on. but stove top works fine. model#jgbs07pea2ww
A common problem is the heating element goes bad. I have had this happen and you can see a spot on the heating element which looks different from the rest of the element (a clue).
Many ovens have two heating elements. Upper and lower. Now I am no Julia Child, but I think bake turns on just the lower heating element? And broil turns on just the top heating element????
So I suppose you might have it on bake and it is not working. Might try broil and see if that works. If yes, then you are getting power through all the controls to the upper heating element, so good chance just the lower heating element is bad.
If you don't get heat to either the upper or lower heating element, then I would suspect the wiring or a control.
So far as the heating element, you should be able to remove it and using an ohm meter, get some sort of reading if it is good (I have no idea what though). Or open circuit if bad.
Also the insulation on older ranges can "melt" back exposing live wires! This is of course very dangerous and the wiring should only be replaced with high heat range wiring which I assume you could get at an appliance store?
Or the contacts on a control/switch could be bad. I would test this with a continuity tester or ohm meter.
Many appliances have a wiring diagram down low somewhere. Or might find it online.
Nov 18, 2009 | GE Profile JTP56 Electric Double Oven
My upper oven/ convection function on my dacor ecs230b will not heat
Bake and convection bake settings both use the bottom bake element to heat. It would be unusual for bake to work without conv. bake working. You also have pure convection which uses a different element surrounding the conv. fan on the back of the unit. If you press a feature and nothing happens it's the touch pad. If it comes on then turns back off it's probably the ERC (clock). If it comes on and wont heat only in pure conv. possibly an upper relay board or element problem.
Sep 22, 2009 | Dacor ECS230 Epicure Electric Double Oven
Thermador SC301T heating elements not working (top and bottom). elements look fine, oven turns on but elements stay cold.... any help would be appreciated. thanks, Tony
Its the thermal safety switch. When it trips - it cuts any power from reaching BOTH elements. Open the oven door - at the top wehere the oven latch is - remove the long black panel. In the middle - on the right is a small cylindrical switch...push down on the top - in the very center...it will rest the switch (like a circuit breaker) and then reassemble. Just did it on mine (2nd time) and it fired right up. Good luck
Jul 09, 2009 | Thermador SC302T Electric Double Oven
Fan oven not heating
its the element not the stat
Mar 10, 2009 | Bosch Ovens
Bosch HBL 755 Stainless Steel Electric Double Oven Logo
363 people viewed this question
Top Bosch Ovens Experts
ashburton
paulcarew
Are you a Bosch Oven Expert? Answer questions, earn points and help others
