Rank: Wiz
Rating: 83%, 794 votes
http://books.jvcservice.com/Download/497591006/MB282IEN.pdf
the manuals link pdf page 14
Note on Region Code
DVD players and DVDs have their own Region Code
numbers. This System can play back only DVDs recorded
with the NTSC or PAL color system whose Region Code
numbers including “3.”
EX.:
If a DVD with the improper Region Code numbers is loaded,
“REGION ERR” appears on the display and playback will
not start.
“CONSUMERS SHOULD NOTE THAT NOT ALL
HIGH DEFINITION TELEVISION SETS ARE FULLY
COMPATIBLE WITH THIS PRODUCT AND MAY
CAUSE ARTIFACTS TO BE DISPLAYED IN THE
PICTURE. IN CASE OF 525 OR 625 PROGRESSIVE
SCAN PICTURE PROBLEMS, IT IS RECOMMENDED
THAT THE USER SWITCH THE CONNECTION TO
THE ‘STANDARD DEFINITION’ OUTPUT
Troubleshooting
If you are having a problem with your System, check this list
for a possible solution before calling for service.
General:
Adjustments or settings are suddenly canceled before
you finish.
There is a time limit. Repeat procedure again.
Operations are disabled.
The built-in microprocessor may malfunction due to
external electrical interference.
Unplug the AC power cord
and then plug it back in.
Unable to operate the System from the remote control.
The path between the remote control and the remote sensor
on the System is blocked.
The batteries are exhausted.
No sound is heard.
Speaker connections are incorrect or loose.
Headphones are connected.
No picture appears on the screen.
The video cord connections are incorrect or loose.
No picture is displayed on the TV screen, the picture is
blurred, or the picture is divided into two parts.
The System is connected to a TV which does not support
progressive video input.
Incorrect color system is selected (see “To set the video
output selector” on page 7).
The left and right edges of the picture are missing on the
screen.
Select “4:3 LB /4:3 MULTI LB” for “MONITOR TYPE”
(see page 43).
trouble shooting guide for video setup
