Question about Norcent Technologies LM-762 17" Monitor
I HAVE A NORCENT LM 762 I PLUGGED INTO A WINDOWS 7 COMPUTER AND ALL IT SAYS IS OUT OF RANGE .I DONT KNOW WHAT THAT MEANS AND HOW TO FIX IT
5 Suggested Answers
CompuGuy44
  • 432 Answers
SOURCE: Norcent--screen flashing repeaditly
Could be a short in the monitor video cable.
Posted on Jun 30, 2007
budmrtn
  • 11361 Answers
SOURCE: Where can I buy a replacement inverter for Norcent
You can try here: http://www.lcdparts.net/DI3D.aspx
You need to get the numbers as printed on the PCBA to see if they have it in stock.
Posted on Feb 22, 2010
robocop
  • 90 Answers
SOURCE: My OCD LOCKED keeps popping up on my LM-965W
I am having about the same problem with my monitor. The solution I was given, was to take my monitor to a repair shop and have them mess with the rubber behind the buttons, because they are sticking. Or save your $ and do it yourself.
Posted on Jun 04, 2011
  • 1684 Answers
SOURCE: I need the ac adapter
That model uses a 12v 4 to 5 amp power adapter. Here is a link here you can get one.
http://www.ccl-la.com/catalog/product_info.php?products_id=48
I hope this helps, if so please rate my solution.
BuddyMc
Posted on Oct 06, 2011
How do i fix my monitor from automatically pulling up the "brightness" menu and adjusting (on it's own!) it to the lowest level?
check to see if the tiny switch that controls that setting is stuck or is shorted out. if it's OK then it could be a Capacitor going bad, of a resistor is getting hot and letting current or voltage changes that effect that control.
Oct 29, 2014 | Norcent Technologies LM-965W 19" LCD...
Norcent Technologies LM173SB 17 in. Flat Panel LCD Monitor Won't work with Windows 7
I ran into this very problem myself, the issue is that the monitor only supports 1280x1024 resolution MAX. Windows 7 cannot detect this monitor and so it does not know it is limited to this resolution, so Windows 7 is putting out a higher resolution at startup, thus the monitor tries to autodect for a second but then just goes blank because it doesn't understand (and can't display) the signal. The only solution is to use another monitor and adjust the resolution to 1280x1024 or lower, but I run into a problem where as soon as you remove the other monitor and restart, WIndows tries to "plug & play" the monitor all over again at startup. So you're best bet really is a newer monitor unfortunately, I only use my old Norcent monitor with my XP computer.
Aug 29, 2012 | Norcent Technologies LM173SB 17 in. Flat...
My OCD LOCKED keeps popping up on my LM-965W Norcent LCD display how do I fix it. I have no manual or instruction book.
Jul 13, 2010 | Norcent Technologies LM-965W 19" LCD...
No sound coming from monitor
Make sure your stereo cable is connected properly and in system speaker icon is showing and it is not mute.
Dec 31, 2009 | Norcent Technologies LM-762 17" Monitor
I need the drivers for the LM-965WA Monitor
As far as I know, you don't need a driver for a computer monitor.
Oct 12, 2009 | Norcent Technologies LM-965W 19" LCD...
I cant get the right resolution on my Norcent monitor
If the company said you need a driver, how come the monitor don't come with a CD to install the Driver? How come they did not point out how you can get the Driver? Look in Device Manager under "Monitors". Does it say "Plug and Play"? If so, you don't need any monitor driver. Try adjusting the resolution on the desktop also, right click in desktop, properties, settings, adjust the slider...
Aug 12, 2009 | Norcent Technologies LM-962 19" LCD...
I took my PS3 on vacation with me and when I got home today hooked it back up to my Norcent HDMi tv and now it says it's out of range. How do I fix this problem?
Ime assuming you mean the video settings are not supported by the tv, Turn your ps3 on and continue to hold the power button until you hear the beeps. It will reset your display. Get back to me if that doesnt work.
Aug 04, 2009 | Norcent Technologies LM-965WA Monitor
Monitor issue
Look to Caps on the inverter if its an LCD or flat pan. monitor.. Weve seen this be4..
Jan 13, 2008 | Norcent Technologies LM-762 17" Monitor
Brightness fades
This is a Common problem MOST if NOT ALL, problems like this with this type of fault it is invairably a problem with the Power Supply, in the PSU Electrolytic capacitors dry out and often cause this type of exact problem... It is a relitively simple fix, by replacing the caps with new ones... Any good shop should be able to fix for a modest fee.. OR if ya know anyone handy with a soldering iron maybe they could do it for you there are generally about 4 - 6 to replace... in the PS section, just do them all to be safe..
Jul 29, 2007 | Norcent Technologies LM-762 17" Monitor
Open Questions:
Norcent Technologies LM-762 17" Monitor Logo
Top Norcent Technologies Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Piyal Perera
Piyal Perera
Robert Struzinski
Are you a Norcent Technologies Computer and Internet Expert? Answer questions, earn points and help others
