Question about Canon MultiPASS MP390 All-In-One InkJet Printer
Canon MP390 Printer won't copy, print, ect. LCD light blinks with message 'Check Printer". No paper jam that I can see. Also carriage does not stop for new ink cartridge change (have to grab it). WSould new peint head fix this dilemma???????????
  • 1 more comment
  • virginia0428 May 22, 2008
    I have the same problem. Printer cartridge moves out, stops at a certain point, heads back to its home position, and reports a paper jam.
    Printer was working fine, then one day the printer started printing even though a sheet of paper hadn't fed. Immediately afterward, the printer gave the Paper Jam alarm, even though I could not see any paper jammed in there. If there IS a minute piece of paper stuck between the rollers, I cannot reach it!
    I figured that the roller(s)? were dirty, but I cannot get the printer to even do a roller cleaning, as it is stuck on the paper jam problem.
    So I've tried to wipe up any leftover ink with a dry wash cloth; still no luck! I've even tried to wipe up the gray roller with damp Q-tips in the brief time that the roller (and subsequently the cartridge) moves before the paper jam alert happens.
    One solution reported here was to clean the encoder strip. Is that the sort of see-through gray plastic film thing, or the rubber band looking thing?
    Also, any suggestions on how to look under the little white rollers for minute pieces of paper?
    Thanks!
    Virginia
    Frisco, TX
  • Anonymous May 27, 2008
    Message "Check Printer" and the Alarm Light are blinking all the time. No paper jam.. What should I do???
  • Anonymous Mar 25, 2014
    explanation how to loosen cartridge carriage
  • Canon Master
  • 1,113 Answers
Not a head problemm, more like the carriage cant slide or cant read its position on the rail.
/clean the thin plastic strip(encoder strip) that runs threw the carriage and the length of the rail
Posted on May 08, 2008
Carrage won't calibrate - more details
Hello! There are many types of error in Canon Printers like P07,P08, E15etc. So please notify the error or check it through your computer notification. After you see the error number (s) please send me a message. Let me try my best for you. Thanks
Jun 20, 2012 | Canon PIXMA iP4700 InkJet Photo Printer
Check print cartidge light keep blinking and the light on copies showing empty while there is paper in the tray
Issue: The Check Paper and Check Print Cartridge lights blinkIn this error condition , the following blinking lights pattern displays on the control panel:
  • On/Resume light : On
  • Check Paper light : Blinking
  • Check Print Cartridge light : Blinking
  • Black Start Copy light : On
  • Color Start Copy light : On
Figure 79: The Check Paper and Check Print Cartridge lights are blinkingc00864299.gif
    hpweb_1-2_minus.gifCauseThe carriage is stalled or jammed. A message indicating that the carriage is stalled might appear on the computer.You might also experience the following symptoms:
    • The product will not print.
    • The carriage is stuck and does not move.
    • The product makes loud grinding noises.
hpweb_1-2_minus.gifSolutionsSolution one: Turn the All-in-One off and then on againFollow these steps to turn the product off and then on again.
  1. Press the On/Resume button (c01602202.gif ) to turn off the product.
  2. Wait 15 seconds.
  3. Press the On/Resume button (c01602202.gif ) to turn on the product.
  4. Check the lights on the control panel to make sure that they are no longer blinking.
  5. Try the intended task again.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
Solution two: Make sure that the front panel overlay is installed correctlyIf the front panel overlay, or bezel, is incorrectly installed, the product may indicate a false carriage stall error condition. If the product has not been set up before, follow these steps to ensure correct installation of the front panel overlay.If the front panel overlay is already installed, and your printer has been working for some time, do not attempt to reinstall the overlay. Press firmly on the overlay to ensure proper installation of the overlay adhesive or pins.
Oct 07, 2011 | HP PSC 1210 All-In-One InkJet Printer
Light is flashing on Resume on my HP Deskjet F2110 All-in-One printer scanner copier. What does that means?
Regular paper, envelopes, or specialty media may get stuck or jammed in the printer. Follow the instructions below to find and remove jammed paper (or other media) from the printer. If the HP All-in-One has a paper jam, first check the rear door. If the jammed paper is not in the rear rollers, check the front door.
Step one: Check for and remove any paper stuck in the paper In tray
  1. Remove all loose paper from the paper In tray.
  2. Press the RESUME button.
    • If the paper jam is cleared, skip to Step Four
    • If the paper is still jammed, continue on to the next step below.
  • If more than one sheet is stuck in the printer, remove the paper, one sheet at a time by taking hold of a sheet in the middle of the stack and, with both hands and firm, even pressure, pull the sheet towards you. Usually, removing one or two sheets from the middle of the stack will release the pressure and the rest of the stack can be removed.
  • After removing the paper, check to make sure no scraps of paper are stuck in the printer.
    • If the paper jam is cleared, skip to Step Four.
    • If the paper is still jammed, continue on to the next section.
  • Step two: Clearing a paper jam from the back of the printer
    If the paper jam is not accessible from the In tray, follow the instructions below to clear the paper from the back of the printer.
    1. Unplug the HP All-in-One.
    2. Press in the tab on the left side of the rear door to release the door. Remove the door by pulling it away from the HP All-in-One. Figure 1: Removing the rear door
      CAUTION:If the paper tears when removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If all of the pieces of paper are not removed from the HP All-in-One, more paper jams are likely to occur.
    2. Replace the rear door. Gently push the door forward until it snaps into place.
    3. Press Cancel to continue the current job.
    Step three: Lift the front cover and slowly remove any jammed paper
    1. Unplug the power cable.
    2. If necessary, pull the input tray down to open it. Then, lower the print cartridge door. Figure 2: Lowering the print cartridge door
      CAUTION:If the paper tears when while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If all the pieces of paper are not removed from the HP All-in-One, more paper jams are likely to occur.
    2. Close the print cartridge door.
      Figure 3: Closing the print cartridge door
    1. Plug the power cable into the HP All-in-One.
    2. Turn the power on.
    3. Press Start Copy Black or Start Copy Color to continue the current job.
    Step four: Verify the print cartridge carriage can move freely
    2. Check to see if the print cartridge carriage can move freely from one side of the printer to the other. If the carriage is to the right and out of plain view, skip to Step Five. Do not try to force it to move if it is hung up on something. [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Image/common/note.png" alt="">
      NOTE:Be careful not to force the print cartridge carriage. If the carriage is stuck, forcing it to move will damage the printer.
      • If the carriage does not move, continue with the next step below.
  • Remove the print cartridges.
  • Step five: Reload and test the printer
    Once the jammed paper is removed, verify that the printer is still functioning properly.
    1. Reload the printer with plain paper.
    2. Perform a self-test by pressing and holding the Resume button until the printer starts printing. A test page should print.
    NOTE:Do not put more than 35 sheets of plain paper in the document feeder tray.
  • Gently move the print cartridge to the far right of the printer.
  • Remove the paper from the paper In tray, but do not remove the drawer.
  • Remove the rear access door.
  • With your fingers, rotate the rollers "up" three full rotations.
  • Push the rear access door back into the printer until it snaps firmly into place.
  • Replace the print cartridges.
  • Plug the power cable into the HP All-in-One.
  • Turn the power on.
  • Step six: Service the printer
    Perform all the steps mentioned above. If the problem continues, service the printer.
    Cause Paper jams can be caused by several factors. Follow these guidelines to prevent further paper jams.
    • Insert paper into the paper tray only until it meets resistance. Do not push it farther in.
    • Make sure that the paper is flat in the paper tray and that the guide is adjusted to the width of the paper.
    • Do not add paper while the product is printing.
    • Remove printed pages frequently.
    • Do not use paper that is too thin, too slick, or that stretches.
    • Do not use torn or creased paper. Used paper might cause jams.
    • Make sure that the rear access door is securely fastened.
    Jun 17, 2011 | HP Deskjet F2210 InkJet Printer
    Hi, my HP D4360 DeskJet printer isn't printing. Both the power and resume lights are on and blinking, as well as both the ink lights. Any advice would be much appreciated. Thanks
    The power and resume lights blinks due to two reasons. 1) If there is any kind of paper jam in the printer.Then its internal assembly cannot move so the lights blinks.So clear the paper jam if any.Open the cover and check if any paper jam.also there is a access door at the back to check any paper jam.The back plastic door can be opened to remove paper jam. But if you are confirmed that there is no paper jam then the other possibility. 2) The printer cartridges are faulty and needs replacement.There are two print cartridges in the printer.One color and one black.Any of the one can be faulty or in some cases both are faulty.But before replacing cartridge remove the cartridge and clean the brown dotted circuit on cartridge then reinsert the cartridges and check.But if this does not solve the problem then replace the cartridge one by one and solve the problem. Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
    Aug 05, 2010 | HP D4360 DeskJet Printer InkJet
    6A00 found paper in place where cartridges sit and wait for a print job. Cleared the paper but still won't start. I have checked in all other possible places and no paper or scrap of paper to be found. Is...
    Hi
    Error 6A00
    The 6A00 is a Canon generic code for paper path jam.
    Solution 1:
    Move the printhead carriage back and forth a few times.
    Solution 2:
    Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
    Solution 3:
    Press the ink pads down in the purge unit.
    Mar 07, 2010 | Canon PIXMA MP830 All-In-One InkJet...
    Epson R320 "General Error" message - unable to clear
    If you are getting a 'carriage jam' error as soon as you turn on your Epson printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
    Fix 'Carriage Jam' : Open Door, clear carriage jam,
    and then press OK to continue' error message
    Turn off the printer and open it to see where the paper is stuck.
    Manually move the carriage toward the opposite side.
    Check the paper path and remove any piece of paper or any other object that is stuck in the path.
    Reconnect the power cord and turn on the printer.
    http://www.fixya.com/support/t5192341-epson_photo_1400_paper_feed_ink
    Feb 22, 2009 | Epson Stylus Photo R320 InkJet Printer
    Hp psc 1610 printer ... error message alternates between carriage jam and out of paper
    i cleaned the clear file strip behind the carriage by rubbing it between my fingers and my printer started working again. before that i had paper jam and carriage jam and it wouldn't do any printing or copying.
    Nov 08, 2008 | HP PSC 1610 All-In-One InkJet Printer
    Locked In Copy Mode--Error Message: 6A00
    Hi
    Error 6A00
    Solution 1:
    Solution 2:
    Solution 3:
    Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
    All The Best: Pineworks
    Sep 06, 2008 | Canon PIXMA MP600 all-In-One InkJet...
    Printer is not working
    Try pushing the print head carriage with a bit of gentle force. It is getting stuck, and hence the error. You may have to open side and top covers to reach this. Note: this is not the cartridges, but another device that moves back and forth on the slider carriage.
    May 15, 2008 | Canon Office Equipment & Supplies
    Problem with HP 7450 and "Paper Jam"
    hi, mezz
    try this
    There are 2 different types of flashing patterns with those two lights on the printer.
    Resume light and power light BLINKING ALTERNATELY
    Problem: Paper is jammed in the printer.
    Resume blinking SIMULTANEOUSLY with power light
    Problem:
    The print cartridge carriage is stuck.
    Solution:
    1. Open the top of the printer.
    2. Remove anything that is blocking the carriage path.
    3. Turn the printer off.
    4. Turn the printer on.
    Problem:
    There is something wrong with the printer. (I didn't write it, I am pulling this from actual HP tech documents, so don't blame me on this one) :)
    Solution:
    If the printer will not turn off, unplug the power cable from the electrical outlet or wall outlet.
    Unplug the power cord from the back of the printer.
    Wait about 30 seconds.
    Plug the power cord back into the wall outlet.
    Plug the power cord to the back of the printer.
    oke, post in me back
    tq
    cropp
    Jan 24, 2008 | HP Photosmart 7450 InkJet Printer
    Canon MultiPASS MP390 All-In-One InkJet Printer Logo
    212 people viewed this question
    old marine
    old marine
