Question about Dometic RM2652 Refrigerator
Need new gasket around freezer door. model no. RM2652 and the product no is 921144122. New to know where to find this item.
  • Dometic Master
  • 43,501 Answers
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Aug 30, 2010
ICE BUILD UP IN A MAYTAG MODEL MZF34X16DW UPRIGHT FREEZER
I have had a few of these, and others of the same ilk.
Your problem should be air leakage into the machine.
Take a thicker piece of paper, not cardboard, and try to slide it around the gasket where the door gasket contacts the front of the freezer.
The gasket should be firm enough to prevent the paper from sliding. Wherever you can move the paper, you could have a air leak.
Most of these have no adjustment in the latch to tighten the door. Sometimes a new gasket will solve the problem, sometime a new door will.
P.S. Twice I have tied a new freezer to a refrigerator dolly to move it and have accidentally warped the door, and they cannot be straightened. :-(
God bless your efforts.
Jul 07, 2017 | Maytag Freezers
Top of the door of Defy freezer ( in & outside)has condensation on it when opening the door. We've just had new gaskets fitted so this shouldn't be a problem? Must we worry about it?
Hello Marion Rae,
Absolutely ... worry!
GASKETS are NOT A guaranteed availability item.
Condensation has no place in your FREEZER & the entire purpose of the "GASKET" is to PREVENT IT...!!
It will soon form as solid frost on the "EVAPORATOR"
and reduce its performance...
The NEXT defrost cycle should remove it..
but if the problem worsens you could over-fill
your defrost pan... and experience WATER PROBLEMS.
You SHOULD be able to FEEL full and firm gasket all around your FREEZER DOOR... NORMALLY I tell people to test for it by doing the "DOLLAR TEST"...
YOU don't need to test... you have CONDENSATION your
gasket is FAILING to accomplish it mission.
Worry is poor (not great) advise...
Have the work performed correctly...
BEST advice... ACT.
PUT IN YOUR MAKE & MODEL number
Check out the associated videos on these part sources
appliancepartspros
Search Over 2 1 Million Appliance Parts
partselect
PartSelect Appliance Parts and Repair Help
repairclinic
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Carnac the Magnificent
May 08, 2017 | Refrigerators
Need new gasket
http://diygaskets.com/search.asp
If you model number is correct these guys will have it.
Aug 25, 2012 | Freezers
I have an Estate refrigerator by whirlpool Corporation, model # TT18DKXRQ01 with a 12-07 mfg. date. When you open the refrigerator door, as it closes, the freezer door always opens and closes. Apparently...
I also own a model # TT18DKXRQ01 Estate refrigerator and my freezer door pops open when I close the refrigerator. As you stated, this is caused by the magnet in the freezer gasket not being strong enough to hold. As far as I know, they do not make a stronger freezer gasket but even if they did, it would probably be too costly considering that a standard gasket replacement costs $80.
My solution was to install an adhesive child safety lock on the top of the freezer near the door handle. I purchased the 'Safety 1st Lock Release Fridge Latch' model # HS038 from my local Walmart store for around $5.
You may find this solution to be slightly inconvenient at first but you will get used to it. It sure beats losing food because the freezer door was accidently popped open.
Product information:
http://www.safety1st.com/usa/eng/Products/Home-Safety/Latches-Locks/Details/482-HS038-Lock-Release-Fridge-Latch
Oct 13, 2010 | Estate Refrigerators
ICE DOOR SEAL IS LOOSE AND NOT SEALING CAUSING FROST BUILDUP
This is the step you will use to repair your ice door seal that is loose.
There are screws under the fold of the freezer door gasket that holds the brace for the gasket in place. Lift the rubber gasket to expose the screw head, one section at a time. Just loosen the screw, and do not take it completely out.
As you loosen the screws, one section at a time, carefully remove the old gasket. At the same time, fit the new gasket into the groove. Make sure your new gasket is lined up properly.
Continue around the freezer door, unloosening the screw, taking out the old gasket and fitting the new one in.
Tighten the screws into place. This may have to be done once the entire gasket is fitted into place.
Check the seal by closing the door. You should have a nice, tight seal.
Good luck.
  • Step 4 Tighten the screws into place. This may have to be done once the entire gasket is fitted into place.
  • Read more: How to Fix a Freezer Door Seal | eHow.co.uk http://www.ehow.co.uk/how_4855248_fix-freezer-door-seal.html#ixzz0rY7rn3O8
  • Step 3 Continue around the freezer door, unloosening the screw, taking out the old gasket and fitting the new one in.
  • Read more: How to Fix a Freezer Door Seal | eHow.co.uk http://www.ehow.co.uk/how_4855248_fix-freezer-door-seal.html#ixzz0rY7gYaZ2
  • Step 2 As you loosen the screws, one section at a time, carefully remove the old gasket. At the same time, fit the new gasket into the groove. Make sure your new gasket is lined up properly.
  • Step 5 fix-freezer-door-seal-1.5-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep5 span.image a:first').attr('href','http://i.ehow.com/images/a04/k5/eg/fix-freezer-door-seal-1.5-800X800.jpg'); }); Keep the gasket clean to last longer. Check the seal by closing the door. You should have a nice, tight seal.
  • Read more: How to Fix a Freezer Door Seal | eHow.co.uk http://www.ehow.co.uk/how_4855248_fix-freezer-door-seal.html#ixzz0rY7JfY8i
    Jun 22, 2010 | Refrigerators
    Frost in freezer
    sears parts direct can send you a new door gasket. they dont need the size only the model #. p.s make sure gasket is soaked in warm water before you install it .this make it easier to work with.
    Feb 24, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
    My freezer section has a lot of frost crystals built up and the freezer door has stuff dripping onto the side of the door. Its also icing up inside the refrigerator around the ice maker
    The frost build up is the result of moisture sublimating out of the materials stored in the freezer. Sublimation, when it get bad appears as freezer burn on meat while bread etc will dry out.
    Check the fan, it is probably blocked or operating below CFM rating. Over filling a freezer with product will also cause this problem, you need air to circulate around the items in the freezer for it to operate properly. If this checks then check the door gasket, it should hold a thin sheet of paper without any problem, if the paper falls out you probably should replace the door gasket. Don't forget to check the freezer temperature, it sounds like it is at about 0 +-10F which would be OK in a side by side.
    Nov 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
    Seal around freezer door
    You will be best off buying a new gasket for the unit.
    Dec 21, 2008 | Whirlpool ER6AHKXPQ Top Freezer...
    I need to change the freezer seal on my refrigerator. But they did not send me any directions on how to do it.
    most of these have a hardened plastic female channel thats tough to see . it is a part of the door and consealed under the old gasket. it has a hollow groove . usually the new gasket has a flat side with a dart or double dart piece sticking out . this dart or arrow side runs the entire side of the gasket and smushes into the door groove channel.. usually you start on a corner firmly pulling out the old dart and gasket from the channel groove. clean the old channel with mild detergent and a little brush. wipe down. lightly oil door groove channel with a little veg oil on a rag and get ready to mash the new dart onto the channel all the way around. it takes great finger strength and mashing one thumb on top of the other to get enough pressure but it can be easy on some. good luck .be sure to clean door sill mating surface and wipe with oily Veg oil rag so new gasket stays clean and doesnt stick. it may take a few days to break in and level out. be sure your snug all around when done. lay out new gasket nice and flat in warm room before you start.
    Oct 26, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
    Dometic RM2652 Refrigerator Logo
    151 people viewed this question
    Top Dometic Refrigerators Experts
    John Tripp
    John Tripp
    Charles T Nevin
    Charles T Nevin
    4stevetaylor
    Level 1 Expert
    Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
