Question about Whirlpool Duet Front Loading Dryer Rack W10121663
I have a whirlpool duet dryer.. I need to know how to put in the rack for the tennis shoes.. HELP
    Scholar:
  • 91 Answers
Hi dear.Here is some help from the user manual.I hope that helps.Thanks. DryingRack
To use the drying rack
Do not remove the lint screen.
1. Open dryer door.
2.
Place drying rack inside dryer drum, positioning the back wire
on the ledge of the inner dryer back panel. Push down on
front edge of drying rack to secure over the lint screen.
3.
Put the wet items on top of the rack. Leave space between
the items so air can reach all the surfaces.
NOTE: Do not allow items to hang over the edge of the rack.
4.
Close the door.
5. Select a timed drying cycle and temperature, or an air cycle
(see following chart). Items containing foam, rubber, or plastic
must be dried on a clothesline or by using the Air Only
temperature setting.
6. You must select a time by pressing MORE TIME or LESS
TIME. Reset time as needed to complete drying. Refer to the
following table.
7. Press (and hold) HOLD TO START button (about 1 second).
NOTE: You must remove rack for normal tumbling. Do not use
automatic cycles with the drying rack.
This chart shows examples of items that can be rack dried and
the suggested cycle, temperature setting and drying time. Actual
Rack Dry Setting Temp. Time*
Wool Sweaters
Block to shape and lay flat onthe rack.TimedDryLow 60
Stuffed toys or pillows
Cotton or polyester fiber filledTimedDryLow 60
Foam rubber filled
N/A Air Only(noheat)90
Sneakers or canvas shoes N/A Air Only(noheat)90
drying time will depend on the amount of moisture items hold.
Posted on Aug 31, 2010
SOURCE:
Put tennis shoe in with clothes and now will not rotate. Light says sensing
its load it to heavy and out of balance??? take the shoes out
Nov 28, 2010 | Whirlpool Dryers
How do I use the dryer rack?
The dryer rack is used for laying out clothing that you don't want to get tossed around. Example: Sweater or tennis shoes. It sits in a groove behind front door and sits in groove at back of tub.
Sep 27, 2010 | Samsung Dryers
Whirlpool duet dryer GEW9200L will turn on but will only "click" when push button in. Timer light starts flashing. Wife was drying a load of towels with her pair of tennis shoes in it on the last load that...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 17, 2010 | Dryers
Dryer will not restart after tennis shoe getting stuck in it
Make sure door is closed firmly. Try to Press and hold the START Button for 4-5 Seconds.
Good Luck and have a nice day.
Jun 29, 2010 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Clunking noise, like a tennis shoe, top right rear of dryer
HI sounds to me like your drum support is worn, it would make a thumping sound. You have 2 you should replace them both.
If you are needing a part - call this toll free number 1 877-489-5610, I have used them many times, they are the best. Best of all overnight shipping!
Sep 23, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer twists and knots up clothes
Many times, many types of Dryer have a variety of paddles. There are so many different ones, without your model, it's hard to know which your has, however, I have known many people that have had these problems.
  1. knots clothing;
    Solution: I have heard and seen a couple tennis balls or even a soft pair of tennis shoes used in the dryer whilst drying clothes keep this from happening. (again, the paddles make all the difference) I myself have always had Maytag, but even they are not what they used to be, however, the shoe trick works when we dry our large blankets and comforters.
  2. Length of drying time;
    Solution: Gosh, there could be many issues, but the first, I would think you either have too small exhaust tube, or it is kinked, smashed or the wrong type. Even the smallest of kink or flattening on many exhaust tubes will greatly effect the output of the exhaust. The only other thing could be overall length of exhaust, and possible clogging in the tube. Have a idea for a fix there as well. (if this is the rpoblem.
If you would like further discussions or ideas, please post here, and be sure to add as much info on dryer as you can, including year purchased and model number.
If the drying time has anything to do with my immediate thoughts (had similar problem when I just moved and reinstalled my own Maytag) I have a great fix to keep it from happening.
Whirlpool has been a good name for some years, in fact, they own Maytag now, so I am sure we can solve your issue as long as it isn't a problem with your particular unit itself as they do make a lemon evey now and again.
Aug 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Dryer makes pounding noise when drum spins
Hi, Is this a whirlpool brand dryer? They have a rear roller noise when rollers go bad. It sounds like tennis shoes in drum.
Let me know if I can help
May 11, 2009 | Dryers
Tumble Drier does not heat - Its a white knight. What would be the likely cause and is it repairable?
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
Nov 01, 2008 | Dryers
Whirlpool Duet Front Loading Dryer Rack W10121663 Logo
701 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
