Question about HP Computers & Internet
I follow the instruction to the router "Wireliess-G 2.4 GHz" and follow the instruction to type "admin" as a password, but faill.
  • HP Master
  • 27,725 Answers
Type admin as user and password as password
hope this helps good luck
Posted on Aug 30, 2010
Dir-601
Follow this instructions:1. connect via hard wired connection using your PC (network cable)2. open your internet explorer or any browser.3. type the numbers 192.168.1.1 or 10.1.1.1 on the address bar4. you will be routed to your router's settings, type admin for USERNAME: and admin for PASSWORD.5. look for the basic setup/settings6. look for the wireless settings7. under your SSID comes the WEP or WPA-PSK option8. that is your wi-fi password, then modified it and remember the password you use for you will need to enter it on your pc when you are connecting via wireless connection.you can select ASCII for password. it should be alpha numeric or combination of letters and numbers.9. select save and apply. then you are good to go.
thanks for choosing fixya.com and kindly rate this post.
Jan 03, 2012 | D-Link D Link Dir 601 Wireless N Home...
Trying to set up a d-link DIR-601 where do i find the pin
Are you pertaining to your network key?These are the steps for you to modify the passcodes fields via router settings.
Follow this instructions:1. connect via hard wired connection using your PC (network cable)2. open your internet explorer or any browser.3. type the numbers 192.168.1.1 on the address bar4. you will be routed to your router's settings, type admin for USERNAME: and admin for PASSWORD.5. look for the basic setup/settings6. look for the wireless settings7. under your SSID comes the WEP or WPA-PSK option8. that is your wi-fi password, then modified it and remember the password you use for you will need to enter it on your pc when you are connecting via wireless connection.you can select ASCII for password. it should be alpha numeric or combination of letters and numbers.9. select save and apply. then you are good to go.
Router guide kit manual
what is the make and model of your router? you can start exploring the router page by simply following this instruction, you can also set the wireless setting by this;
Follow this instructions:1. connect via hard wired connection (network cable)2. open your internet explorer or any browser.3. type the numbers 192.168.1.1 on the address bar4. you will be routed to your router's settings, type admin for USERNAME: and admin for PASSWORD.5. look for the basic setup/settings6. look for the wireless settings7. under your SSID comes the WEP or WPA-PSK option8. that is your wi-fi password, then modified it and remember the password you use for you will need to enter it on your pc when you are connecting via wireless connection.you can select ASCII for password. it should be alpha numeric or combination of letters and numbers.9. select saveand apply. then you are good to go.
Dec 25, 2011 | Computers & Internet
What is the security code for my router
if it is asking for the username and password, use this:
USERNAME: adminPASSWORD: admin
if you are pertaining to the wireless codes, follow this instructions:
Dec 25, 2011 | Linksys Computers & Internet
How do i set a password
Setting the router's administrator password
All Belkin Router's ship without an admin password. If you require an admin password then follow the below instructions.
Setup steps:
  1. Connect the computer to one of the four LAN ports on the router.
  2. Open a web browser on the computer.
  3. In the address bar of the web browser, type http://192.168.2.1
  4. Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
  5. Click on System Settings under Utilities on the left-hand side of the opened page.
  6. You will see a feature called, "Administrator Password". Type in your current password (default leave blank).
  7. Click "Apply Changes". Your new password is now active.
Note: Do not forget the new password and keep it somewhere safe. If you forget your password, you'll be unable to access your router's settings. If you forget or lose your password, you'll need to "Perform a hardware reset on the router". This will reset the password to its default, as well as erase any and all other settings you may have changed.
Aug 12, 2011 | Belkin Computers & Internet
My friend gave me a linksys wireless -g 2.4 ghz speed booster router but need a password and he cant figure it out?? what do i do ?
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on wireless then wireless security then WEP note down that password it is your password to connect wifi. . Let me know if you need further assistance. Thanks for using FixYa.
Sep 11, 2010 | Linksys Wireless-G Broadband Router
When i type in the router network ip address http://192.168.0.1 the box opens and i type in admin for username and leave the password blank it just clear's everything and ask for username and password...
Type "user" for the username instead of "admin" & leave the password blank. This should work.
Here is a link to a list of the D-Link default passwords:
http://www.default-password.info/d-link/
Oct 27, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
What is uesername & password
access it with following link
http://192.168.1.1
or
http://192.168.0.1
type user name as "admin"
and password is "admin" or blank or "password"
then u can enter in router configurtrion menu.,
Jun 14, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
I follow d user guide instruction but fail
-Try pressing the reset button at the back of your router for 15secs or it you notice a change on the light release the reset button.
-Try again typing in the username = admin and leave the password blank.
Dec 19, 2008 | D-Link AirPlus DI-524 Wireless Router
Computers & Internet Logo
51 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
