Question about Zyxel P660HW-D1 Router
ZyXEL P660HW-61 Hi, I am facing an issue with the above mentioned model. Though the model (as can be seen on the equipment) is P660HW-61, the router menu displays P660H-61 and the wireless LAN related menus are absconding. However, if I disable the ethernet connection and log into the router menu through the WLAN, I can see wireless menus. Only in this case, the Signal seen by my laptop is "Very Low" everytime. I have installed the firmware V3.40 P11, but of no help. Please help.
  • samataz1000 May 10, 2009
    Everything started when I tried to upgrade the router into a newer firmware.
    Having done that, I no longer have the wlan menu as well as for the wifi.
    I contacted zyxel support in the uk but the responce was below my expectation.
While your computer is directly connected to the router, try to change the channel to 1,6 or 11. Try to enable wireless security and disable firewall on your computer. try to turn off other wireless device that may cause interference on your network
Posted on May 08, 2008
Cant find security key
ZYXEL PRESTIGE HTTP n/a 1234 ZYXEL PRESTIGE FTP root 1234 ZYXEL PRESTIGE TELNET (none) 1234 ZYXEL PRESTIGE 643 CONSOLE (none) 1234 ZYXEL PRESTIGE 652HW-31 ADSL ROUTER HTTP admin 1234 ZYXEL PRESTIGE 100IH CONSOLE n/a 1234 ZYXEL PRESTIGE 650 MULTI 1234 1234 ZYXEL PRESTIGE 900 HTTP webadmin 1234 ZYXEL PRESTIGE 645 HTTP admin 1234 ZYXEL PRESTIGE P660HW MULTI admin 1234 ZYXEL ZYWALL 2 HTTP n/a (none) ZYXEL ADSL ROUTERS Rev. ALL ZYNOS FIRMWARES MULTI admin 1234 ZYXEL PRESTIGE 660HW MULTI admin admin ZYXEL P-660HW-61 Rev. PRESTIGE 660HW-61 HTTP n/a 1234
Dec 27, 2011 | Zyxel P660HW-D1 Router
I forgor the Password of the router Model Number zyxel:p-6600hn-fl so could you please tell me
http://www.retrevo.com/support/Zyxel-P-660HW-D1-Wireless-Routers-manual/id/14715dj396/t/2/
Hi above is a link for your manual, download and it shows you in there.
Most often a hard reset will return the router to factory specs, and to logon with a browser you must then enter a login and password, usually they are admin and admin but differ from router to router.
If however you mean you WAP/WEP logon password, this is a different matter, again it requires a reset, and re-doing the internal WAP/WEP password setup again, this time noting down the "Key".
This too is all explained in the manual.
Apr 28, 2011 | Zyxel P660HW-D1 Router
I HAVE FORGOT MY PASSWORD ROUTER ZYXEL P660HW-61
Hold down the reset button on the router for 30 seconds and that should reset it all to factory setting including the password, which should be on the bottom of your router
Mar 26, 2011 | Zyxel (91-004-361002) Wireless Router
Need to buy a replacement power adapter for this model, can you tell me what the dc output and connector size is - Zyxel P660HW-D1
Dc output is 12v and 1amp.
You can buy power adapter for Zyxel P660HW-D1 from nearest computer shop or from internet.
It's power adapter needs 12v and 1 amp.
Let me know if you need further assistance.Thanks for using FixYa.
Jun 13, 2010 | Zyxel P660HW-D1 Router
Hi, how can i get nat open on my ps3 whit my zyxlel router
http://portforward.com/english/routers/port_forwarding/ZyXEL/P-660HW-D1/P-660HW-D1index.htm
Use port forwarding to sort out ya problem, find you router, and it will show you what to do.
www.devicemanuals.com/guide/.../ZyXEL/ZyXEL-P-660HW-D1-3-40-User-Guide-TkRjNU9EUT.html - 21 hours ago
User Guide above.
Mar 30, 2010 | Zyxel P660HW-D1 Router
Can`t conect to the wifi
Try resetting the router and then see if the WLAN will lit up.Maybe it just disabled on the router. have you tried accessing the router's setup page to see?
Sep 08, 2009 | Zyxel P660HW-D1 Router
Where do i find th security key or passphrase on a zyxel 660hw-61 to use my laptop
From User's Manual: In order to configure and enable WEP encryption; click Network>Wireless Lan to display the General screen. Select Static WEP from the Security Mode list.
For Passphrase: Enter a Passphrase (up to 32 printable characters) and click Generate. The ZyXEL Device automatically generates a WEP key.
Click Here to Download the User's Manual in PDF format.
Feb 19, 2009 | Zyxel P660HW-D1 Router
Can't connect my Ipod touch to my router?
i had the same problem too with my'n. My issue was on of my setting's was set to block that wi-fi connection. Try switching your setting for finding internet connection from automatic to manual. that should do the trick!
Dec 20, 2008 | Zyxel P660HW-D1 Router
P660HW-D1 Router not working wireless
Problem with the Zyxel P-660?   I experienced:
1. laptop would see the wireless 660HW briefly and then it would disappear.   2. laptop would not see wireless at all. 3.  same issue with desktop when using USB wireless 11g dongle 4. no problem on wired connection (ethernet)
EASY solution!   if Zyxel is set to scan for a channel it will want to work on channel 13 nearly every time in a busy environment.
HP laptops and many receivers cannot recieve on 13 -  highest channel is 12.
Pick on setting for the Zyxel which matches an available channel on your receiver.  Problem solved.
Nov 20, 2008 | Zyxel P660HW-D1 Router
Performance and speed of internet
Its not your router you need to optimize. Its the computer!
Dec 03, 2007 | Zyxel P660HW-D1 Router
Zyxel P660HW-D1 Router Logo
1,148 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
