Consent ui for administrative applications has stopped working
  • 808 Answers
Its the error in ur registry so make ur registry clean using reginout registry cleaner
Posted on Aug 30, 2010
Wt is [unfortunaly, system ui has stopped working
Your android is running on low memory. Transfer some files to sd card or delete unnecessary files. Also clear data of applications at 'Manage Applications' on your menu.
Nov 23, 2014 | Kocaso M M9100 9-Inch 8 GB Tablet
try to install it with administrative rights i mean right click on file and choose run as administrator
Feb 15, 2010 | Microsoft Windows Vista Home Premium with...
Maxdata desktop pc has install problems & runs very slow
I may be completely off base, but you should look into how much free disk space you have on the drive, and whethere it is less than 15% disk space free.
Windows will not defrag if there is very little space free. In that case, you can use disk compression, defrag then remove the compression. Or uninstall thngs you don't need, then defirag.
But if you are up against it with very little space left, you will continue to have problems.
Good luck,
-a.
Jan 25, 2010 | Computers & Internet
File system error and Consent UI
Administrator is an account of your computer, all the activities are held in administrator account. Although there is no password set for administrator account but if anyone in your family or relative must have set up a password,that's a different thing. I suggest you to install your windows again,in order to reset your administrator password.
Oct 10, 2009 | HP Pavilion a1700n PC Desktop
Consent UI for administrative applications has stopped working
Consent.exe is part of Windows Vista UAC (user access control). If you are having problems, try going back to a restore point and see if you can add/remove programs. If you don't have a restore point where you can do that, then you will have to use the recovery CD which will require the admin password. If you didn't set a password, it could be blank, just try pressing Enter.
Aug 31, 2009 | Microsoft Windows Vista Home Basic Edition...
Access violation at address 0052D602
Sorry If this doesnt help your problem but here is some info that might help
Consent.exe is part of Windows Vista - it's the User Access Control (UAC) executable.
There is a known malware version of this executable. Do a search on your hard drive (within Windows Vista, obviously) for all consent.exe files - make sure you include hidden and system files in the search criteria.
Once the search has completed, right-click on each file and check the file properties.
There is a MalWare version of Consent.exe
Right Click ALL of the ones you find and look for
Microsoft details in Properties
  • File Names Used: 3
  • Paths Used: 8
  • Common File Name: CONSENT.EXE
  • Common Path: ?:\windows.old\windows\winsxs\x86_microsoft-windows-lua_31bf3856ad364e35_6.0.5728.16387_none_ef1113b929fe5371\
  • Vendor Information: Microsoft Corporation
  • Product Information: Consent UI for administrative applications
  • Version Information: 6.0.5728.16387
  • CONSENT.EXE may use 3 or more path and file names, these are the most common:
  • 1 :%windir%\winsxs\backup\X86_MICROSOFT-WINDOWS-LUA_31....A1C2
  • 2 :?:\windows.old\windows\winsxs\backup\X86_MICROSOFT-WINDOWS-LUA_31....A1C2
  • 3 :?:\X86_MICROSOFT-WINDOWS-LUA_31....A1C2
  • If you find a consent.exe anywhere else in the search results, I'd delete that file. Run a thorough anti-virus scan of the harddrive. I'd also download spybot and run it as well as downloading Ad-Aware from Lavasoft and using it to scan as well.
    Spybot and Ad-Aware can find different spyware/malware, which is why I recommend running both products.
    Once you've done all that, reboot the system. That should fix the problem.
    Jun 22, 2009 | Microsoft Windows XP Professional With...
    Windows vista home premium laptop gives me the following message.
    What program are you using to run the backup?
    This has to do with the user account control in vista, and there is a fix out there that recommends you disable UAC, which I don't think is such a hot idea. (links here, here and here) another informative article here.
    I suspect you could have a malware issue that is compromising your system. Please follow through with the first four steps of these malware removal protocols, then check things out and see if you can run a manual disk scan through to completion. If you're then experiencing the same behavior, let us know the results, and we can take it from there.
    I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
    If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
    Jun 09, 2009 | Microsoft Windows Vista Home Basic Edition...
    I keep getting a box that pops up say that consent for UI has stopped working.. I'm unable to uninstall programs on my laptop. I have vista.. how do I fix it?
    hi,
    This is a known problem in windows vista (it is actually a security feature)
    You can do either of following:
    1. Disable UserControl from control panel.
    2. If above doesn't works then change the registry settings [HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Policies\System --> EnableLUA = 0]
    3. if this even doesn't works, then, reboot your pc in safe mode (continue press F8 number of times after finishing booting screen on reboot, you'll get safe mode) and disable User control from control panel.
    Hope this helps.
    Thanks.
    Mar 16, 2009 | Computers & Internet
  • Paths Used: 8
    May 08, 2008 | Computers & Internet
    Computers & Internet Logo
    62 people viewed this question
    David Payne
    David Payne
