Question about Dryers
Westinghouse LD505E Tumble Dryer - Dryers
  • 33 Answers
SOURCE: replacing the belt
Here is a belt supplier
Tilt the unit and see if you can get to the drum and motor assembly, if not then You will need to remove screws on the right or left side of dryer to open access to motor and drum. The belt diagram should be accurate for this dryer.
Posted on Sep 24, 2008
  • 40 Answers
SOURCE: westinghouse ld505e lights up for will not start
Try opening the door, spin the drum by hand, then qi\uickly close& press start. If this works, then the capacitor has failed. About $30, easy to replace.
Posted on Aug 17, 2010
heatman101
  • 43501 Answers
SOURCE: Replace belt Westinghouse Dryer Model LD505E.Can't
Here you go...
Westinghouse Dryer Belt Diagrams and Replacementheatman101
Posted on Sep 12, 2010
SOURCE: I have a Westinghouse LD505E
Trying to fix an appliance yourself could void your warrenty. I would probably call the repairman and just pay the price.
Posted on Dec 29, 2010
hunter19_46m
  • 7482 Answers
SOURCE: westinghouse ld505e clothes dryer runs
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks.
If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the
wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed
component. The switch is inside the dryer main housing near the door frame.
Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Check for continuity you should have none with door open, and should have a reading when closed.
If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause
heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the
thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape
or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged
with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's
plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace an element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Apr 12, 2011
How do you start a Westinghouse dryer Ld505E sensor dryer
if their is no start button push in on the main timer knob on some dryers
Dec 30, 2016 | Westinghouse Dryers
I have a Westinghouse Sensordry LD505E Dryer which has suddenly stopped heating up
Either your dryer vent is clogged or your heating element / ignition coil has failed. It's called a hot surface igniter
May 19, 2014 | Heating & Cooling
Dryer drum bearing and glides
it sounds like a pocket object has gotten traped between the drum and the gasket.to the cabnet ,with the power off use a thin dull object like a butter knife see if you can find it.
Dec 03, 2013 | Dryers
My Westinghouse LD505e suddenly stopped working during a drying cycle and it won't start. Would anyone be kind enough to guess what could be the problem and advise a solution. It's 4years old
Probably a blown fuse due to a heater element problem or maybe a bearing problem. I recently worked on one and did a movie which shows the fuse location and all:
More here
Oct 21, 2012 | White-Westinghouse Dryers
Westinghouse dryer ld505e on/off button wont stay on when l push it
If it has dampness sensor strips inside the machine they may be coated with dryer sheet wax or some other mess. Clean them with windex and retry. As the clothes rub against these sensors the dampness causes the dryness board to keep the machine a going. if no dampness is detected the dryer shuts down. Supposely to save power.
Jun 18, 2012 | Westinghouse Dryers
User Manual Westinghouse LD505E
go to www. fitness.manualsonline.com or www. retrevo.com or www. manualsfactory.com
God bless you
Jun 03, 2012 | Dryers
Barrel of westinghouse dryer Model No. LD505E won't turn
This is posted in wrong section--TV---try reposting in large appliance section
Mar 22, 2012 | Televison & Video
Westinghouse ld505e lights up for will not start
Apr 02, 2009 | Dryers
Dryers Logo
111 people viewed this question
Top Dryers Experts
