Reset Default Settings
My son pressed a couple of buttons on the remote and now skyworth comes up when tv is turned on and the picture is distorted so that peoples heads are cut off. Any help you could give me on how to correct the problem would be greatly appreciated
    Brigadier General:
  • 6,966 Answers
Initially, have you tried a full hard reset? If not, pls unplug from the mains. Most current devices would reset and revert back to factory default settings (assuming no internal hardware fault) when unplugged for a considerable period of time (fa couple of hours at least or preferably overnight).
Alternately, pls check if you have "Zoom" enabled.
Hope this be of initial help/idea. Good luck and kind regards.
Thank you for using FixYa.
Posted on May 08, 2008
My picture fills the whole screen to the point people look distorted
Look on your TV remote. Look for a button that reads "Aspect". While watching TV push the Aspect button until the picture is they way you want it.
Sep 01, 2014 | Samsung La32d400 32" Hd Lcd Wide Screen Tv...
Picture has become too big for screen
Used ur tv original remote,look for a button like View Mode,Picture Size,Aspect Ratio,Zoom.Pushes one of these buttons to changes the picture sizes to fit ur tv screen.
Jun 05, 2011 | Toymax Skyworth SLTV-2663A 26 in. LCD TV
My plasma has the screen distorted after my son pressed something on the remote. It is like the picture is three times the size.
Ur tv are to much zooming in mode.Look on the remote control for a button that said like VIEW MODE,ZOOMING,PICTURE SIZES.Press one of these buttons to changes ur tv picture sizes.
Feb 26, 2011 | LG 50PG20 50 in. Plasma HDTV
People faces and a lot of other items on the screen are not natural looking, kind of like a manaquin. Stripes are distorted. It is brand new and I was wondering if the problem is the tv or something else....
On this television you would need to remove the Comcast digital cable box. This tv does not need it. Then you will press the menu button and choose either the channel or the setup category. You will then need to locate the auto ch memory or ch setup subcategory. Then you will select it by pressing enter after scroling down to it. Next you will scroll down to automatic search or ch search and press enter. Select search start for just digital channels and press enter. It may direct you to select yes and then enter. After the television is done searching the 135 channels it will come back to channel 2.1 or the lowest channel you receive. You can then go through your channels with the ch button on your Sharp remote control. The picture can further be adjusted with the av mode button on your remote if you press it repeatedly if you remote control has one.
Apr 17, 2010 | Sharp 19 in. LCD HDTV
Hard to get started when powering up to watch.
definitely, something wrong with it. TV shouldn't take more then a few seconds to start, I suggest, while it still under warranty, give Sharp a call to get it fixed.
Nov 27, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Only the red light comes on
Whats up Wade?
This is DVD MIKE with Perfectimagess.Try this first .Unplug the TV for a while and press the On/Off button which is supposed to perform a "reset".After that, plug the TV back in. It should come on and the Timer light off. The picture and colors might be distorted, but pressing the Perfect Focus button on the remote control resolves this right away.
The problems is a black picture or the TV won't turn on. The Timer light stays lit even though no Timer has ever been set. The colors converge and the picture is pinched. I don't think all of the expensive repairs are necessary, My TV did go out after a week of non-use while out of town (I was out of town, not the TV). I don't know. I'll post more if I learn more. I hope this helps Wade,
Vacuum the dust off of the circuit boards and inside the cavity. TAKE CLOSE UP PICTURES OF THE CONNECTORS BEFORE DISCONNECTING FROM THE CIRCUIT BOARDS. (IF YOU HAVE TO.) TAKE OUT CIRCUIT BOARD MOUNTING SCREWS. AND REMOVE THE BOARDS.
VACUUM THE DUST. LOOK- SMELL AND CLEAN THE GROUNDS, AND CAREFULLY CLEAN THE BOARDS. ASSEMBLE. DOUBLE CHECK CONNECTIONS WITH PHOTOS,
AND PLUG IN, TURN ON AND HOPEFULLY ITS ALL GOOD.
WADE WORK WITH ONE HAND AS MUCH AS POSSIBLE SON!!
DVD MIKE
May 14, 2009 | Akai PT4298HD Rear Projection Television
TV is stuck in expanded picture mode & won't return to normal
seems to me as a Sony TV. The sony tv has this feature ready in the menu. you can do zoom out ,standard etc,
But the real problem comes when the tv is turn off and then you get back to turn on the tv (lets say next day)and you find the same big heads.
what you have to do is going to the menu same thing but this time look for an option is called picture size default. This option make learn the memory what size you want custom when tv is turn on.This function is in the same page as the picture size page (refer to the user's manual) but has to be the default mode where you want the change.
The problem with sizes now days is some shows fit perfect some others not. and besides that the cable box has those features too(change size of the screen)
What i do in this sony tv to start first is keeping it in the standard size in the tv menu and i defaulted too.
when some size adjustment is needed i do it in the cable box remote control .Once again this example i do it in SONY tv, Maybe you have to post the problem again if the tv is different brand.
Apr 15, 2009 | Hitachi 51F59 51" HDTV Projection...
Distorted picture on channels not HD
on your remote there might be a pics size button so try pushing that if you got it
Mar 29, 2009 | LG 30FS1D TV
Toshiba 32 inch tv picture is distorted
have you tried pic size on the remote to adjust the image. normal is the factor default.
Jan 29, 2008 | Toshiba 32AF43 32" TV
Televison & Video Logo
463 people viewed this question
Top Televison & Video Experts
