Question about Toshiba 42HPX84 42 in. HDTV-Ready Plasma Television
We have two black lines coming down from the tpo of the screen each about one inch long wide and ten inches long. I s this anthing that can be fixed? I t started about 6 months age off and on with onl one line and the past 1-2 qweeks both lines.
  • 48 Answers
SOURCE: Toshibsa Satelite P30 Laptop
That usually means that the polished silicon plates no longer make good contact with the LCD glass. It is rare you can fix this yourself. But you can remove the LCD by removing any small covers or rubber feet from screen side of the lid.Power off machine before going further. From there remove all the screws and remove them. Just remove the screen gently and look behind it and you will see printed barcodes with numbers. One of them is a part number. Ebay that number and find out how much you can get one for. Be sure the sell has a good rep and a return policy. Order one in and replace it yourself. Or take the parts you have and a repair shop may not charge much to replace the screen you have.
email me if you need any more assistance or reassembly.
Posted on Jan 07, 2008
mewms_14904
  • 1027 Answers
SOURCE: Screen Problem
Unfortunately the fix is a new lcd. The tab welds at the top of the lcd are not allowing that portion to work correctly. As these tabs are fused to the lcd you will need to replace the lcd. My Toshiba M105 is almost the same.(I Have 4" Gone) on the right side. so to use it I clicked and dragged my system tray from the bottom to the side. And shrunk my web pages to utilize tthe good portion.
I suppose I should replace it but being only 18months old the LCD's run about 160.00 USD.(sometimes I just hook up an external monitor.
Posted on Apr 16, 2008
Mark_Webber
  • 472 Answers
SOURCE: JVC TV 27" Black line on top of screen
This is for the original problem.. Not the second post.
It's a problem in the horizontal deflection circuit. The parts will be available, but you will be in for some daignostic repairs also to find out why it failing or if it has failed on it's own.
There should be a few caps near the IC (an LA7840) that could also be causing the problem. Click the link, it will make it easier to locate the part inside.
This is the kind of repair best left to a TV tech, but get it done now and it won't cost anywhere near as much as it will later.
Posted on Apr 18, 2008
jerryg50
  • 1667 Answers
SOURCE: black line problems
Some components in the vertical deflection amp have been going out of spec with age.
The set may no longer be worth to spend money to service it because of its age. However, if you wanted to invest the money, the set is serviceable. Considering its age, the CRT may be soft, and there are many other older components that can soon fail.
I would be considering a new set.
Jerry G.
Posted on Apr 22, 2008
SOURCE: lines coming down from the top of screen
Those lines are beaming in from the planet Alenod. For the moment you'll only be annoyed by those lines. But when those lines finally expand the entire surface of your screen you and everything in your viewing area will vaporize. Gosh, If I were you I'd chunk it as quickly as possible and buy a 47" Vizio! They're on sell at Sams! Pleeze hurry!!
Posted on Sep 17, 2008
How can i fix gray line in center of screen of my vizio e320vp
Check lvds cable and ribbon cables going out of t-con board going to the lcd panel.
Nov 14, 2011 | Televison & Video
Screen went black with a vertical rainbow line down the middle
Failue of the vertical section, could be the drive, the power to the section or even some discrete componets. Unless you are familiar with electronics , get some help to ceck out on these circuits, could not be major but to get themain culprit will require good probing.
Jun 29, 2010 | Panasonic PT-56TW53 56" Rear Projection...
Black Lines
My Hitachi TV Flat screen 42 EDT 4 1A has a one inch black line from the top to the bottom of the
screen on the left side. What or how do I fix it. I did blow it out with a air compressor as suggested by a local repairman.
Nov 09, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Black line problems
Jerry G.
Apr 18, 2008 | Toshiba 36A40 36" TV
42 inch magnavox #42mf230a/37
One of the driver IC'S has gone bad. Need to replace just the driver IC or the board that the IC is on and that should solve your problem. If that doesn't do it, then the BAD NEWS IS THAT THE PANEL IS BAD. Replacement is you only option then. Good luck. GURU JAY.
Mar 16, 2008 | Televison & Video
Lines coming down from the top of screen
Mar 05, 2008 | Televison & Video
LCD monitor problem
what is the solution for this? my husband just turned his pc on when we got home and there are line blue lines running up n down in the black
Oct 11, 2007 | Computers & Internet
Toshiba 42HPX84 42 in. HDTV-Ready Plasma Television Logo
21 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
