Question about Sharp Televison & Video
I lost the tv remote for my LCD tv it does not have a menu button so I could scan channel what can I do
  • 33 Answers
There are alot of universal remotes for cheap out ther that work well with shap tv's. I have use many with sharp. GE RCA SONY ect...That will solve the remote problem. you can unplug for ten min and pug back in. sometime that will make it go to set up menu or let you select auto program. good luck
Posted on Aug 30, 2010
I have a Sharp TV model LC-32SB24U. I cannot access the menu screen because I lost the remote control. Is there another way I can change channels without a remote?
The Sharp LC-32SB24U has menu, input, volume up/down and channel up/down buttons on the top of the TV. When you access the Menu using the buttons on the TV, the Input button is the same as the Enter key. The volume up/down buttons map to the left and right arrows. The channel up/down buttons remain up and down. The Menu button is the closest to the power button (on the right). The volume buttons are the ones on the left.
Make sure that the input is set to TV to change channels. Then you need to program the available channels, access the Menu and navigate to Setup (left/right arrows). Press Input to enter this sub-menu. Then use the Up/Down arrows to select CH Setup. Press Input again to enter. Now you can set the channel source and let the TV scan for channels that have a strong enough OTA signal or are unencrypted cable channels. These are the top two options in the Channel Setup menu. The details are available in the manual which is available here: http://static.highspeedbackbone.net/pdf/Sharp_LC37SB24U_LC32SB24U_Manual.pdf . For OTA channels, you may need to check the signal strength under the Antenna Setup - Digital option in this Setup menu. OTA Digital signals will not be tuned in if the signal strength is low. It's an all-or-none tuning; amplifiers and external antennas may help. See tvfool.com for details of transmitters and the recommended antenna for your area. (Warning: damaged amplifiers can become filters and block the signal on some channels. Replace the amplifier if it is damaged.)
If you look to replace your original remote with a universal remote, you'll need one that was programmed more than 6 months after the TV was released. That may be 12/2005 based on the manual copyright date. Look for a remote that has a Menu and Input or Source button and check all of the codes to find one that matches all of the features on your original remote. Amazon has an OEM remote for the LC-32SB24U; remotes.com also has a replacement remote available that has been programmed for the TV. (On remotes.com, search for the LC32SB24U.)
I hope this helps.
Oct 26, 2015 | Sharp LC-32SB24U 32 in. LCD TV
All channels permanently deleted accidently, can I restore them
Auto tune the channels as found in the manual
  1. On your remote, press Menu.
  2. select Channel and press OK on your remote.
  3. select Auto Tuning and press OK on your remote.
  4. select Yes and press OK on your remote.
Nov 10, 2013 | LG 32LD350 32 in. LCD TV
Manually input channels. Lost remote to tv.
You can navigate the menu using the buttons on the tv. Go to the setup menu and you can do a channel scan. You can get remote from Shopjimmy.com,Ebay or Samsung.
Aug 31, 2011 | Samsung Televison & Video
I hook my antenna to the back and I'm not receiving a picture
I'm assuming your Antenna is connected to your TV with a co-axial cable? If so, please make sure you have run the Analogue/Antenna/Air channel scan correctly:
1. Switch the TV on
2. Press the "MENU" button on the Curtis remote supplied with the TV.
3. Press the RIGHT arrow button five times to highlight the "Channel" menu
4. Press the "ENTER" button or the DOWN arrow once to open the "Channel" menu
The Air/Cable option should be highlighted.
5. Use the LEFT/RIGHT arrow buttons to set the "Air/Cable" option to "Air"
6. Press the DOWN arrow to highlight "Auto Scan"
7. Press the "ENTER" button or the RIGHT arrow once to start the automatic channel scan.
When the scan has finished, the TV should automatically return to viewing mode. If not, just press the "EXIT" or "MENU" button on the remote to close the menu.
You also need to make sure the correct INPUT/SOURCE is selected on the TV:
1. Press the "SOURCE" button on the Curtis remote
2. Use the UP/DOWN arrows to highlight "TV" in the INPUT SOURCE menu
3. Press the "ENTER" button on the remote to select "TV" and close the INPUT SOURCE menu.
This should be all you need to do to watch your TV from an antenna source.
Please post back if you are still unable to get it to work and need further assistance.
Regards,
BElectric
Dec 30, 2010 | Curtis LCD2424A 24 in. LCD HDTV
I pressed the menu button on my remote control went to channels went to antenna scan and lost all my channels how do I rectify this problem?
go back to the menu and do a channel scan for cable or if you have a cable box connected change to the input the cable box is connected to with the SOURCE or Input button
Dec 06, 2010 | Westinghouse SK-26H520S 26 in. LCD HDTV
I lost my remote, how can I reprogram the channels?
2 ways you can buy a new remote from mr remote.com or use your buttons on the set by hitting menu and go to channels and scan channels
Jan 01, 2010 | Polaroid FLM-3734B 37 in. LCD HDTV
Channel button on tv and remote control dosent work
The channel buttons on the tv and remote only navigate through the channels programed into the tv. You will need to go into set up and scan for channels or manually add channels you wish to receive.
clarkco
Mar 07, 2009 | Vizio GV42L 42 in. LCD Television
32 astar tv
the tv remote has what you call a menu button press it and the menu will come.if you are using a universal remote you wont be able to get any menu most universal remote dont have menu features.if you do not have the originald remote press channel up and down together on the front panel of your tv and you can use the remote to acess what ever you want or the volume up and down button on the front panel of your tv.good luck.
Apr 01, 2007 | Astar LTV-3201 32 in. LCD Television
Televison & Video Logo
128 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
